| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #16 (permalink) |
| Senior - BHPian Join Date: May 2004 Location: Bombay
| No much problem in my Hondas or Endeavour...Mercedes sometimes has a tendency of starting the water in a slight delay but its 90% of the times together. I dont think the new C has rain sensors. My C has speed sensitive wipers where in the wiper increases to a higher level when the speeds are high, likewise when u stop at a signal the wiper switchs to intermidate mode if its on low or high.
__________________ ______________ __________ ______ __ |
| | #17 (permalink) |
| BHPian | well,I have this problem of the washer starting a bit later after the wipers start in the Esteem..but in the New Honda City,there's no such problem,and both - wipers+washer start exactly at the same time..also,I like the Honda washer spray..it throws the water evenly across the windscreen,while in the Maruti Esteem,the washer sends out a single jet,thus covering lesser area of the windscreen with water.. And yeah,as someone already mentioned..in the Esteem,it helps just to give a few flicks to the windscreen washer knob,and then pull on the knob fully to start the wipers..so that the windscreen is wet when the wiper/washer knob is fully pulled. cheers, Suraj
__________________ Driven by Dreams ! |
| | #18 (permalink) |
| BHPian Join Date: Feb 2005 Location: mumbai
| the New C class and the Skoda Vrs are both equipped with rain sensors ... a rain sensor is nothing more than a light sensor . it is attached to the windshield at the base of the rear view mirror i.e the place where the mrror comes in contact with the windshield Last edited by Mad Monkey : 18th July 2005 at 23:42. |
| | #19 (permalink) |
| BHPian | In my Esteem, the water hits the windshield about the same time the wipers start to move, but since the wiper moves from a horizontal position and the two jets hit the glass midway, the wipers do "scrub" a bit till they get to the wet area. The return sweep is ok. I found that by carefully controlling the duration which I pull the "wash+wipe" lever, I can ensure that only one sweep is done. I got good at doing this cuz the "intermittent" mode on my wipers has not been working for a while now ... The guys at MUL told me that it was electronically controlled (no timing relay) and that the "combination switch" would need to be replaced to fix it. Well... it costs 1800 bucks and it controls everything to do with the 2 storks on the steering column of the Esteem... seems a shame to replace that much functionality for a high price just to fix the "int" mode !I dabble a bit in electronics too... will check out what they've got in that thing-a-magic and post the details soon. - T u r b o C - |
| | #20 (permalink) |
| BHPian Join Date: Jan 2005 Location: NYC
| Well in the newer ikon 1.6's the spray comes first and then the wipers switch on and its not just the VW but the ikon also has the delayed wipe. The wiper switches on again after a delay of about 10 secs or so to wipe the drips that come down. |
| | #21 (permalink) | |
| Senior - BHPian Join Date: Dec 2004 Location: Windsor
| Quote:
__________________ Every weapon needs a master | |
| | #22 (permalink) |
| BANNED Join Date: Feb 2004 Location: Bombay
| Cars like the Skoda VRS, the Toyota Camry (new) and the new C-class come with rain sensors. Generally located in behind the rear-view mirror, it is attached on the inside glass by some kind of adhesive tape or holding mechanism. They adopt optical sensors that emit InfraRed light to the windshield. Once they come into play, they continuously detect the amount of light falling on it. When light reduces, they detect the moisture level present on the screen, using a pre-determined and calculated moisture presence on the screen before engaging the wipers. Revv |
| Thread Tools | |
Similar Threads | ||||
| Bosch Wipers - Mumbai | harishsegar | Modifications & Accessories | 49 | 4th August 2007 15:29 |
| Squeaky Wipers | whatcanthisbe | Technical Stuff | 1 | 26th June 2006 13:32 |
| Wipers for WagonR | cooldude1988765 | Technical Stuff | 1 | 25th June 2006 10:22 |
| Windshield wipers | tsk1979 | Modifications & Accessories | 3 | 4th August 2005 01:27 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
