Old 12th May 2007, 14:27   #16
v1p3r's Avatar
Thanked: 27 Times
Well logically you could turn your airbags off. There must be a separate fuse in the fusebox for the airbag controller module, and if you take that out, it won't work.
Old 12th May 2007, 15:36   #17
MaserQ's Avatar
Thanked: 51 Times
Originally Posted by doctorkats View Post
air bags save lives.it should be made compulsory for all cars.
i hope someday the govt and car manufacturers team up to make it affordable on all cars.
that said they save lives only when the passengers are wearing their seatbelts.
@paras:i'm sure you're joking right?
Well said!! It took a doc to say that. Its only when our near and dear ones get into an unfortunate situation that our Indian mentality does a re-think on safety issues.
Better safe than sorry.
MaserQ is offline   Reply With Quote
Old 12th May 2007, 15:55   #18
heelntoe's Avatar
does the octy have weight sensors in the passenger seat or an airbag deactivation button?
it could save some money if there is no one in the passenger seat.
heelntoe is offline   Reply With Quote
Old 12th May 2007, 16:15   #19
paras211's Avatar
Thanked: 57 Times
i ment it in a scarstic way for the insurance guys who should be covering the cost .
This is what the typical Indian mentality is all about. Sorry to say this but money cant buy happines or lives
__________________
well money can buy airbags and hence lives .
paras211 is offline   Reply With Quote
Old 12th May 2007, 18:47   #20
Akshay1234's Avatar
Thanked: 7,242 Times
i think you can switch off the passenger side airbag with a button in some cars.
Old 15th May 2007, 01:15   #21
Godfather's Avatar
Thanked: 65 Times
No.. No airbags can be switched off with buttons.. Like v1p3r said.. You will have to remove the fuse..
Godfather
Godfather is offline   Reply With Quote
Old 15th May 2007, 01:28   #22
heelntoe's Avatar
Godfather
no, he said passenger airbag. some cars have buttons that deactivate the pass airbag in case there is an infant or a rear facing child seat in the front seat.
Old 15th May 2007, 01:35   #23
Godfather's Avatar
Thanked: 65 Times
Thanks heelntoe.. I was not aware of this..
Godfather
Old 15th May 2007, 01:39   #24
aah78's Avatar
Thanked: 1,749 Times
Godfather
that's right - generally 2-seaters and pick-up trucks have this option!
in the event of a crash, an airbag will not activate unless the seat belt is used. so if you don't have a passenger (or the passenger isn't wearing a seat-belt), the passenger-side airbag will not inflate.
sometimes you have an indicator to notify whether the passenger side airbag is deactivated, sometimes you don't.
do not play around with your airbag electronics and fuses unless you're qualified to do so - they can be activated inadvertently - causing physical and monetary damage. merely removing the plastic part on your dashboard marked "SRS Airbag" might cause it to inflate!
aah78 is online now   Reply With Quote
Old 15th May 2007, 01:45   #25
Godfather's Avatar
Thanked: 65 Times
What about Curtain airbags..(present on the side windows) in case of a front collission will these deploy?? even though there is no one sitting behind...
Godfather
Old 15th May 2007, 10:00   #26
Rtech's Avatar
Thanked: 221 Times
This talk, even if it is only in passing, about deactivating airbags by pulling a fuse is ridiculous! A person spends the better part of 5 lakhs (minimum) to by a car which is equipped with an airbag, and then, in the hope to save a few bucks, people give idea's on how to deactivate it!
In the recent Mumbai accident, the only survivor in the Swift lived because of the airbag. Can someone put a price on that? Also, can that car ever be repaired that one should worry about the costs related with replacing an airbag!
Guys, seriously, there may be some nut out there foolish enough to do this!
Old 15th May 2007, 12:33   #27
heelntoe's Avatar
Godfather
i'm not sure but i think the curtain airbags deploy only in the case of a side impact.
Old 15th May 2007, 23:40   #28
Godfather's Avatar
Thanked: 65 Times
Nah!!.. What was told when we bought the Prado was that the curtain airbags will also deploy during a front collission...(depending on the impact i guess)
Godfather
Old 16th May 2007, 00:21   #29
heelntoe's Avatar
Godfather
then i hope the engeneers have enough sense to deactivate the curtain airbag when the front passenger airbag is deactivated.
also, i don't think the curtain airbag relly hurts the occupants as much as a front airbag because of the way it deploys.
Old 16th May 2007, 00:26   #30
Godfather's Avatar
Thanked: 65 Times
I checked in the Prado..and there is no switch available to deactivate any airbags.. Not that i want to deactivate them.. just out of curiousity i checked..(before people start flaming me) and also there is no mention of the same on that industrial sized book of that vehicle..
So i was just wondering if this is limited to some vehicles..
PS: I am more happy if the airbags deploy in an accidential situation.. Atleast its safe.
Godfather
Toyota Fortuner crashes, Air bags did not deploy *EDIT* Another similar case Pg.7 wanderer4x4 Road Safety 172 8th May 2018 17:38
Scorpio VLX mhawk 4WD with Air Bags EDIT - 43000 kms update 4x4addict Long-Term Ownership Reviews 110 11th April 2013 16:16
Are air bags covered by insurance? bhp Indian Car Loans & Insurance 32 17th December 2011 01:44
Malfunctioning Air Bags amit The Indian Car Scene 5 3rd August 2004 16:45
