Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 11th May 2007, 00:37   #1 (permalink)
Default Indica Xeta woes !!!
I bought an Indica Xeta GLS two days back and on the third day its back in the show room due to some technical snag. The problem that occured was the 'check engine' indicator was not going off during running. The car manual says that in case of any malfunction the 'check engine' indicator will glow during running but will not glow when powered on battery. The case with my car is that the indicator glows whether powered by battery(indicating no malfunction) or on starting the engine(indicating malfunction).
Does any one have any idea about this.......
The mechanic at the showroom first diagonized the problem with cam shaft sensor, but when that was fixed there was some problem with the timing setting. He claims to have replaced the cam shaft sensor altogether, but the problem persists. He now says that he will get all the electrical connections checked.
Will the rectification of problem require fiddling around with the engine?????
Hoping that the problem will be fixed soon, will the engine performence get affected.
help me !!!
pankaj_veerkar is offline   Reply With Quote
Old 11th May 2007, 01:08   #2 (permalink)
esteem_lover's Avatar
I hope it is not anything major, nevertheless keep an eye out for any cover ups. Buying a TATA is always a gamble (Hope i do not get burnt for saying that), so watch out & see to it that they rectify whatever the problem is , within the warranty period itself.
__________________
"Keep your friends close, Keep your enemies closer"
Old 11th May 2007, 01:42   #3 (permalink)
Zappo's Avatar
Ummm... I think you have ended up with a duffer mechanic. Xetas have a problem with that Check Engine thing. Two things buddy. One, even if a problem came for a split second that Check Engine will remain. This has been done in recent cars so that people immediately visit the service station and get it checked lest it aggravates. Most of the time they hook up the car with their comp which then starts checking parameters one by one and either oks them or flags any problem. After its through the error has to be explicitly cleared. The system asks whether the logged error should be cleared. If that is not done the car will keep flashing that Check Engine message irrespective of anything else done. So check whether he remembered to clear the error.
Now what could cause a split second problem that causes the flash but later on the computer detects nothing? After talking to a few Xeta specialist (one of my friend's new Xeta was showing this problem once in a while but nothing used to come out when hooked on the system) I realized that to increase the FE Indica runs a real lean mix. ECU and the engine has been tuned accordingly. However because of these it is also very sensitive to fuel adulteration. If any of the injectors feel choked for a split second the ECU flashes the check engine. By the time you reach the service station most often things are back to normal and system does not catch any problems.
My friends problem was solved when he chucked the pump next to his house and shifted allegiance to a well reknowned pump, albeit a bit far from his residence.
P.S. One technician told me that sometimes it can even be caused because a small few microscopic particulate matter entered one of the injectors from the tank. You can not even call that fuel adulteration.
__________________
Announcements are important.
  • Read the Advertising Announcement here.
  • Classifieds section has its rules. Read here
Zappo is offline   Reply With Quote
Old 11th May 2007, 06:42   #4 (permalink)
zenx's Avatar
Do a quick google on "check engine light" and be illuminated! You have lots of company all over the world. Yours truly faced that in a City once and had to pay for replacing the O2 sensor - still wondering if it was really the case given how much more (from what a very pro service station guy told me) Honda O2 sensors seem to apparently fail....
__________________
Sameer, Bangalore
zenx is offline   Reply With Quote
Old 11th May 2007, 11:38   #5 (permalink)
Infractions: 0/1 (4)
The Xeta is known to have this issue - caused by adulterated fuel.
hrag is offline   Reply With Quote
Old 13th May 2007, 12:11   #6 (permalink)
pugram's Avatar
Default Same problem - slightly different
Hi - I also had this strange experience.
I was travelling between chennai and Trichy on the GST Road on Friday. Absolutely no issues travelling at 110 -120 kph, as and when the traffic permitted.
Now at one stage i encounter some stop and go conditions. The car refuses to move on the 1st or 2nd gear. It literally shudders and the check light and other lights come on, albeit for a few seconds. But when i slip the clutch and increase the RPM above 2k, it moves and then goes on comfortably on the higher gears. There is a jerk the moment i take off my foot from the accelerator on any gear, whereas this had not happened before. This happened after 2 ~ 3 hrs of driving on the Highway and I managed to reach trichy, in one piece.
On my return, we left early (see nowadays chennai's become very hot with the mercury touching 42 deg C) to reach early. Absolutely no hassles till the time we reached chennai, the mercury shooting up. Now the car started acting up in the start and go conditions.
But for this, the overall experience was good.
I was just about to start a new thread on this, when i found this thread.
My questions:
1. Is this because of Bad fuel quality. This car is fuelled at a prominent BP fuel station in chennai and on my return had fuelled up at Reliance.
2. Any additives available to clear the Injector / FIP.
3. I thought the car (ECU) was acting up due to the high temp. And have always wondered why they had the ECU in the engine cabin, whereas it should be inside the dash with a provision for keeping it cool, similar to lots of electronic stuff.
Any suggestions / opinions ? .
Just hope Value For Money doesn't turn Value For Mechanic
Pugram
pugram is offline   Reply With Quote
Old 14th May 2007, 00:38   #7 (permalink)
Zappo's Avatar
Pugram, Xetas are sensitive to adulterated fuel, yes. However your problem had to do with overheating. When the car heats up too much it looses power and behaves like a ton of bricks. It feels like it would rather shut down than move. Even on 1st gear when you try to get moving it shudders and tries to shut down. This happens when the outside temperature is too high and the cars cooling mechanism is not able to cool the engine down even after putting in all its efforts. This problem is also experienced when you are stuck in a jam and continuously driving on the clutch in 1st gear with the AC on. A bad summer is only aggravating this problem a few folds more. I think in these scenarios the best solution is to stop somewhere and take a break. Better still lift the hood and let its cool down somewhat.
__________________
Old 14th May 2007, 00:41   #8 (permalink)
Sounds like a badly overheated clutch - do you drive half-clutch?
__________________
It is no measure of health to be well adjusted to a profoundly sick society.
- J Krishnamurti
Steeroid is offline   Reply With Quote
Old 14th May 2007, 00:47   #9 (permalink)
Zappo's Avatar
Steer I think it is more of a overheated car... clutch, engine and everything else. And even the diesel is susceptible to this. This friday I got stuck in a jam (billed in today's TOI as the mother of all jams) I experienced the same problem. In fact I was asking Tanveer about this problem as well. Then another friend of mine asked about the same in his Xeta and now Pugram. Could it be that Indicas are more susceptible to this problem?
__________________
Old 14th May 2007, 14:57   #10 (permalink)
saurabh711's Avatar
On my trip from Chennai to Coorg, driving non-stop till Mysore, I got stuck at a jam at Mandya (don't remember the city exactly), for about 30-45 minutes, bumper to bumper with AC on. My car (07 Indica Turbo) did not face any overheating problem. Probably now i'll take care and switch off the AC atleast.
__________________
2009 Honda Unicorn - 13.3 BHP
2009 Optra Magnum LT - 121 BHP
2009 Zen Estillo Lxi - 64 BHP
2007 Indica V2 Turbo DLG - 68 BHP
saurabh711 is offline   Reply With Quote
Old 14th May 2007, 19:36   #11 (permalink)
wolfinstein's Avatar
@ Saurabh
The car in question is not Indica Turbo its Indica XETA..! Please read the full thread..!
Could also be the Lamda O2 malfunction, The Air flow is either having a Leak or the Mixture is too rich..! This is a possibility over and apart from the Fuel Injector or Bad Fuel.
Ask the Mech to disconnect the Fuel filter and collect some fuel and see, if it is dirty enough change the filter and find a cleaner pump.
The strange factor I have seen in my XETA is that with Premium fuel like HP Power I get 1 Km less mileage per Ltr , compared with Regular Fuel from HP.
Don't drive on Petrol, So don't know what any other effects or causes could be..!
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 16th May 2007, 22:38   #12 (permalink)
pugram's Avatar
I was doing a highway run and i can assure you that i was not driving Half - clutch. I had to slip the clutch to get the car moving. Else it threatened to die on me
But I have made a longer trip in the same car and did not face any problems, except for strange noises at speeds above 120 kph (as per the speedo).
Again this year the weather is strange in the sense that chennai is facing a scorching 41 ~ 43 degree C continually and the humidity which is usually above 65% is around 40 %. That is why I suspect overheating (and ECU acting up due to the same)to be the primary cause. Yet to take the car to a service station.
@Zappo : What is the solution to this. Looking back, yes i made an almost non stop 6 hr trip with 4 fully grown adults in this car. But my speed was restricted to < 80 kmph most of the time, as the GST road was fully crowded with buses on account of karunanidhi's 50th year in the legistlative assembly blah.. blah... The temperature guage needle was in the middle all the times, which does indicate a normal position.
Old 17th May 2007, 01:45   #13 (permalink)
Zappo's Avatar
I know... your temperature gauge stays in the middle. The same happened to me as well. I think its the frequent declutching that causes this problem. As Steer said... predominantly a heated up clutch.
There is probably no direct solution to it. If this has already happened the only way out is to park the vehicle and let it cool for a while (pretty impractical in the jammed roads of a city) or else be cautious from the word go.
I now have become more cautious. In fact a tad overcautious. I now have this thread running at the back of my mind continuously that I have to be cautious about the usage of clutch in those jammed roads. Try crawling on the 1st gear rather than frequent usage of clutch in crawling traffic. You will realize that in 1st gear if you slowly release the clutch without the accelerator the car rolls at a very very slow pace. That is better than using light accelerator on second and then again immediate braking. Because that will require more clutch usage. Typically we all are loathe to drive on 1st and try to shift to 2nd at the first chance.
My idea is that in the current weather a 5-10 minutes of bumper to bumper crawl with intermittent usage of clutch heats up the damned thing. I never faced this issue till date. It seems to have come in with the onset of this dry hot summer.
__________________
Old 23rd May 2007, 08:42   #14 (permalink)
pugram's Avatar
The problem initially occurred on the GST road, where i was not changing the gears frequently. And this continued inside the city also. But this happens only after a long drive and spiritied drive (2 ~3 hrs @ an average of 100kph - Chennai to Tindivanam on the Golden Quadrilateral). Seems to be working ok in the city for shorter drives
Anyways took the car to VST motors, Chennai and they replaced the spark plugs ??
Have to take it on a long drive to check out.
Old 24th May 2007, 18:05   #15 (permalink)
Default mileage
I too have experienced lot of problems with my Xeta - particularly within the first 3 months of purchase. Plastic parts keep coming off inside the car. ery distressing is the mileage - city is 9.5-10 kmpl. Is this the same with others?
tomjoe is offline   Reply With Quote
Thread Tools
Indica Xeta - First Experience-How Xeta won the race nirmalkumar Test-Drives & Initial Ownership Reports 12 20th April 2008 17:41
Indica Xeta LPG or Indica Turbo Diesel?? nobreaks Hatchbacks 12 2nd September 2006 00:29
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
