Old 15th May 2007, 21:00   #61
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Will Samurai's car run as new after the repair/replacement of the problem above?
Yes the car should run as before .. No issues ..
Old 16th May 2007, 17:51   #62
Jaggu's Avatar
Thanked: 8,694 Times
@samurai: did the dealer give you an update?
Old 16th May 2007, 18:10   #63
Samurai's Avatar
Thanked: 15,776 Times
Yeah, I just spoke to Mr.Kamath. He too has read this thread.
Actually he agreed with Jaggu as in #53. He doesn't suspect any damage inside. He has ordered for a replacement crank shaft. He will open the engine further only after receiving it. I will visit when that happens.
He feels it is just a question of resetting everything back.
Old 16th May 2007, 18:13   #64
Jaggu's Avatar
phew.. good news atlast see ya at the next travelogue post
cheers
Jaggu
Old 16th May 2007, 18:15   #65
kpzen's Avatar
Thanked: 1,655 Times
Great work sir..!!
So the crankshaft isn't readily available.How much time has Mr Kamath asked for getting the crankshaft?
Old 16th May 2007, 19:48   #66
Revvhead's Avatar
samurai, i couldnt really make out the damage on the crank from here,
but, if the rotation of the crank was off thentheres a good chance of bearing damage as well, imo if there any any white metal/support bearing for the shaft ( i dunno i've never opened one of these), check them out, else the new crank you fit in will be gone soon
i would strongly advise you to at least get a compression test done, if you dont wanna open and inspect the pistons & liners.
Revvhead is offline   Reply With Quote
Old 21st May 2007, 16:13   #67
theMAG's Avatar
Thanked: 1,574 Times
Any new updates yet ?
Old 21st May 2007, 16:17   #68
Samurai's Avatar
They are hoping to receive it today, I will be called once they are ready to open it up.
Old 21st May 2007, 16:21   #69
Vid6639's Avatar
Thanked: 21,086 Times
keep us updated with pics please. I actually loved the balenos internals pics earlier.
Old 22nd May 2007, 13:08   #70
Samurai's Avatar
Today I visited the service center for an update. The crank shaft has arrived and they are going to get the engine down starting this afternoon. This being a busy season and all, it is going to take 4 days. This is a big problem since my BIL is getting married in less than a week. BTW, his brand new Alto had to be left at the same service center to fix a damage on the door, that takes 3 more days. Therefore Mr.Kamath gave me a loaner WagonR until I get my Baleno back.
Regarding the Baleno problem. The damage appears to be contained as of now. Although the bolt is broken at the tip, the flywheel is still held in place because secondary set of 5 bolts around the main shaft. When the center bolt got broken, the flywheel started wobbling. When the flywheel wobbles, the tension in the belt reduces and it probably started slipping. That explains the loss in power.
Once the engine is opened I guess we will learn more.
BTW, if the probem happened because of defective part, Maruti will replace it for free, but who pays for labour charges considering it is out of warranty?
Old 22nd May 2007, 14:16   #71
theMAG's Avatar
...but who pays for labour charges considering it is out of warranty?
The customer unfortunately, I guess - this not being a case where insurance could have been claimed
Old 22nd May 2007, 14:24   #72
tsk1979's Avatar
Thanked: 16,422 Times
Whenever I have had a warranty job done on my car, no matter what job, I did not have to pay for anything. I think when you get something done under warranty, you don't have to pay anything, right?
Old 22nd May 2007, 14:35   #73
Rtech's Avatar
Thanked: 221 Times
the problem here is that the warranty has expired, but Maruti are still covering the cost of the parts as goodwill. They are not obligated to cover this repair.
However, clarify with the dealership and find out how much the labour would be anyway. I don't think it would be too much.
Old 22nd May 2007, 16:28   #74
moralfibre's Avatar
Thanked: 6,533 Times
Since it involves opening up the entire engine I think it will cost a bit.
Old 22nd May 2007, 16:57   #75
Jaggu's Avatar
should be under or around 5k labor, plus consumables like seals and all
High Revving the Honda City Vtec GTO Technical Stuff 34 25th June 2009 23:17
S10 engine revving on its own 16v100bhp Technical Stuff 19 18th January 2007 21:20
Palio auto revving rammkp Technical Stuff 5 31st March 2006 08:25
A Story of two guys and two high revving machines GTO Street Experiences 11 13th December 2005 10:28
citroen revving up for India devarshi84 The Indian Car Scene 16 14th October 2005 19:59
