Old 22nd May 2009, 11:47   #16
Especially, Indica Turbo brakes lock-up very easily once they get wet. its as if the car wants to throw the driver out of the windscreen, its that bad
enzo10 is offline   Reply With Quote
Old 22nd May 2009, 11:53   #17
muralisk's Avatar
Not very sure if we can say exactly at what point the wheels get locked, but I guess we need to use our experience and instincts and take defensive action. In cold countries, there is always a danger of hitting a ice patch and siding away and there isn't much the driver can do.
When your wheels get locked, the steering would get quite easy and there would be no response on your car's movement.
On the other hand, it always helps to pump the breaks even when there is no need to do so, so that we can get this braking method into our subconscious and there by avoid locking wheels.
muralisk is offline   Reply With Quote
Old 22nd May 2009, 11:57   #18
greenhorn's Avatar
Thanked: 1,519 Times
enzo, I'm sure the wheels locking up while wet have more to do with the tyres than the brakes. I'm upgrading to better rubber the first chance I get.
What rubber is your car wearing? Mine is still running on stock S322's - havent havent lost grip while braking on the highway, ever.
but have pulled a few skids and wheelspins on local roads after the rains
greenhorn is online now   Reply With Quote
Old 22nd May 2009, 12:17   #19
true greenhorn, my mention of lockup was misleading. i meant excess grip. when the brakes are wet, they just stop the vehicle instantly however gently you apply the brake. dont face this problem in dry condition. mine is also running stock S322 at 32k kms still some 10k kms life left.
Old 22nd May 2009, 13:47   #20
pranavt's Avatar
Thanked: 274 Times
Best place to lock your wheels is in a muddy area. It's just too easy. With rains approaching, go to an empty area. Chances are, if it's open, there should be some mud.
Another place is underground parking lots which have tiles. But this can get a bit hairy since they're full of fat pillars and the security will not be too keen on allowing a newbie to learn driving where other customers park their cars.
Cement roads are also a good place. The best if you want to learn imo, since the tyres will actually have grip if not locked, as opposed to pretty much ice-skating in wet/tiled places.
Old 22nd May 2009, 20:59   #21
equinox22's Avatar
A lot depends on the surface on which the wheels lock. If it is snow then there are times when locking may actually improve the braking performance. On the other hand if the road is icy there is not much one can do whether the wheels lock or not.
equinox22 is offline   Reply With Quote
Old 22nd May 2009, 21:22   #22
bblost's Avatar
Thanked: 6,980 Times
I do this on my bike every few months.
A controlled brake test.
Take her to a good speed. Mark a spot a few meters ahead. I brake and get the bike to stop before I cross it.
Depending on road conditions, I let the front wheel lock up.
And cause the bike to drag itself with the rear trying to overtake the front.
On the car, I do a similar exercise, but don't push it till it actually locks itself.
Every time on my bike/car can become a practise run.
If the road is completely clear of everything, no shrubs on any any side. Road surface dry and clean.
I don't know what I am practising for, but when the time comes, I pray I am ready.
Old 22nd May 2009, 22:42   #23
i'll tell you what you are practicing for.
i've had this happen to me at least 3x while riding my old KB100. so i'm coming along at decent speed and suddenly from out of nowhere some idiot darts into my path, all 3 times there was not much road to swerve so i jam the brakes, mind you both drums. wheels "lock" (can i use that term for drums?). and the rear starts to try and get ahead of the front causing me to move sideways. but don't panic, grab the clutch, release the brakes, spread eagle my legs slightly, yea i think my feet may have even momentarily touched the ground and both wheels regain grip on the road, bike slowed down and still with the hand on clutch change to a lower gear. and i'm saved from what seemed like a certain crash!
silver_shadow is offline   Reply With Quote
Old 23rd May 2009, 10:13   #24
Thanked: 27 Times
I have an Indica Turbo with ABS. Only once in Mysore Road I got the chance to test the ABS because of an unexpected speed breaker appearing when I was at 90kmph. I stood on the brakes. The car behaved admirably, no locking-skidding, no rear-overtaking-front, I was able to steer and brake distance was minimal.
However on rains, I am kinda scared. The brakes seem to function roughly. A small movement of the brake pedal causes a relatively sudden stoppage compared to normal conditions. So on rains I normally drive slow.
Anyone has an idea why this happens in rains. I don't have stock tires too. I upgraded it to Michelin XM1+ with R14. (I'm a safety freak)
GenuineOptimist is offline   Reply With Quote
‘THE COLD STARE’ - I always heard about it, read about it. Now I know it - up close ExtremeTorque Travelogues 212 8th September 2010 10:49
Alto Xcite - Upgrade Manual Central Locking to Remote Central locking Laxminarayan Technical Stuff 1 28th December 2009 15:02
Central locking versus remote locking mb_jg Technical Stuff 40 2nd January 2009 20:08
DRIVER TALENT:- How do u judge a good track driver from a good street driver memo45_m Indian Motorsport 27 18th May 2006 07:42
