Old 14th May 2007, 11:34   #1
dilipkumar7278's Avatar
Thanked: 26 Times
Default Lancer diesel Timing belt Tensioner - Help!
Two days before I went for 80k service at the authorised service centre Geo Motors,Cochin.After service a grinding like sound is heard from the engine when idling.The service people say that the Timing Belt tensioner bearing has gone(the main bearing) and it would cost 3000rs.Is it normal for a Lancer which has done only 80k kms ?I regularly service the car and has never crossed 100kmph in that.So what it shows that no matter how much you care your car there is no guarantee that it will last longer.My friends Lancer which is being thrashed by everyone ,require normal oil change only.(His car is now around 90k kilometres)Any experts in the field please comment.Is 80k service anything to do with this,I mean ,do they inspect the timing chain ?When I gave the car two days back for service it was perfect...Please comment
Dilip
dilipkumar7278 is offline   Reply With Quote
Old 24th May 2007, 10:18   #2
Originally Posted by dilipkumar7278 View Post
.The service people say that the Timing Belt tensioner bearing has gone.......,I mean ,do they inspect the timing chain ?When I gave the car two days back for service it was perfect...Please comment
Dilip
lancer uses a timing chain? or a serpentine timing belt?....
what do you mean by grinding noise...is it like screeching sound or humming........?
a faulty bearing will cause increase in noise with incresed rpm, where as a belt needing tension adjustment will screech prominently on lower rpms.
belt produces screeching noise, wheras bearing produces metalic humming?.....
arunforu1 is offline   Reply With Quote
Old 24th May 2007, 15:19   #3
nikkibike's Avatar
Dilip,
Well... I wud say that you are a lucky owner having trouble with belt tensioner only at 80K kms! Well...its depends on the overall quality of that perticular piece went in to your car! It doesn't means that all belt tensioners which the manufacturer uses in assembly line are faulty ones!! IT HAPPENS sometimes!!
Most importantly make sure its belt tensioner that is faulty in your case!! The sound cud be of somethinge else too!! During service, the technician wud've opened the cover to check the status of belt. It may be something like the cover is improperly fixed and touching somewhere! So get it confirmed and replace the faulty part immediately!
Don't worry..Be happy... after all its being done on a 80k done car!!
cheers!
nikkibike is offline   Reply With Quote
Old 24th May 2007, 22:50   #4
Thanked: 26 Times
Thanks Nikkibike
Anyway they have changed the main bearing and charged me 4500rs.But I am not entirely satisfied.Some humming noise still there.HM service engineer has agreed to inspect the vehicle next week.
dilip
Old 24th May 2007, 22:56   #5
Thanked: 26 Times
Default Tensioner bearing
Arun
The noise is heard only when Idling.I first thought the sound is that of some plastic part touching the belt .Pressing accelerator reduces that sound.
Lancer uses timing belt and not timing chain whereas Pajero/Montero uses chain//
dilip
timing belt?....
Old 25th May 2007, 11:10   #6
nikkibike's Avatar
Thanks Nikkibike
dilip
THIS is a core issue! No service centres are good in satisfying customers whenever they find unidentifiable troubles! In such cases generally they try to 'push' the customers out by doing something and convincing them some or another way!
Dude...get it checked properly as early as possible!!! No matter the trouble is small or major... remember..major troubles of lancer's engine can loot your bank balance!!!!
Old 9th November 2007, 15:18   #7
jack33's Avatar
normally u have to change the timing belt,tensioner etc at 1lackms..but it's always better to do it a few kms before in indian condition..i have changed my belt, tensioner etc at 75k..
jack33 is offline   Reply With Quote
alternator belt damages timing belt??? jalsa777 Technical Stuff 21 8th March 2015 10:52
Timing (cam) belt vs chain sbasak Technical Stuff 33 10th November 2009 16:00
Trouble after timing belt change hamadrayad Technical Stuff 1 6th November 2006 20:05
Changing the Timing Belt .. ?? khaadu75 Technical Stuff 5 5th February 2006 19:38
