Old 15th May 2007, 00:41   #31
Godfather's Avatar
Thanked: 65 Times
i have achieved an average of 23.9 km/l in my laura (stock)
.. Exceptional.. This is close to what the Ford gives
and yes shifting to neutral works wonders ...
Shifting to neutral while travelling at 60kmph.. does it not increase the vehicle speed a bit and considered dangerous ???
Godfather
Godfather is offline   Reply With Quote
Old 15th May 2007, 00:42   #32
Thanked: 20 Times
I got 11.5 after 1st service in adventure, the reading was taken after doing 243 trip. 180 done on highway with lot of 4th gear driving. Had to drive in 4th and 3rd gear a lot . Was also going through undulated turmac, so less chance of shifting to 5th. Sharp curves etc caused frequent downshifts. Was not expecting more than 10, but 11.5 is acceptable.
Before 1st service had got 14.7 with 90 % highway driving.
swathyd is offline   Reply With Quote
Old 15th May 2007, 00:47   #33
karan561's Avatar
Thanked: 10,540 Times
Godfather[/quote]
it does increase the speed a bit ... but is quite manageable ... overall a good combi of light footed acceleration and good gear shifting is the key to great fuel economy ...
karan561 is offline   Reply With Quote
Old 15th May 2007, 00:47   #34
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Few links for a good read on DFCO (deceleration fuel cut off) or Over-run fuel cut off :
InsightCentral.net - Encyclopedia - Honda Insight Fuel Cut Mode
1994 Product Bulletin - M1.7 IGNITION AND INJECTION SYSTEM
ENGINE MANAGEMENT SYSTEM - MPi MEMS 1.9
Throttle FAQ
Old 15th May 2007, 10:32   #35
navin's Avatar
Thanked: 4,282 Times
Mclrean, I noticed that at no time on that video did you exceed 40kmph.
Old 15th May 2007, 10:36   #36
Thanked: 35 Times
Yes , which is the way I drive 90% of the time (the other 10% either we are testing the car after mods or on a TBHP drive) .. My car does have a speedo error , actually the true speedo reading will be around 60km/hr in 5th gear at 2000rpm .. At 1750 rpm it should be close to 50 ..
Old 15th May 2007, 11:25   #37
Thanked: 20 Times
Which car you owns, my adventure do 60 kmph at 1500 rpm, 80 at 2000 rpm.
Old 15th May 2007, 11:30   #38
Thanked: 35 Times
Its a baleno with a close ratio gearbox .. Thats why the difference in the speeds however I wont be in a position to comment on the correct speed unless I get the worm changed ..
Old 15th May 2007, 12:02   #39
normally_crazy's Avatar
Thanked: 394 Times
i have achieved an average of 23.9 km/l in my laura (stock) while returnin home(mulund) from nariman point @ around 11:30 p.m. shifting done in the range of in the range of 1200 - 1500 rpm. , and in the 5th gear driving @ approx 60-70 km/h
26.49 kgm of torque did the trick ....
Yes - I used to get these kind of figures from the TDi too. Infact after a T-BHP drive to Alibaug, while returning 4 of us got so engrossed in a discussion that we did not exceed 60 kmph in 5th gear...and just as I reached Panvel , my eyes fell on the trip computer and it showed 3.1 L / 100 KM.
normally_crazy is offline   Reply With Quote
Old 15th May 2007, 13:16   #40
zenx's Avatar
Thanked: 75 Times
boohoooohooo
Thats all this thread makes me do
In a 1.3, 10-12 in the City
I wanna get 15kmpl too
zenx is offline   Reply With Quote
Old 15th May 2007, 13:25   #41
Thanked: 35 Times
Simple , let akshay drive your car for a week and your dream will come true ..
Old 15th May 2007, 14:39   #42
n_aditya's Avatar
Thanked: 2,779 Times
I simply do what you have mentioned, shift at 1750 rpm or even less if possible. I don't know how good is this for the engine?
Riju, from what i saw last time i was in blore... u ought to quit pulling off in second gear... more so riding the clutch while doing so.
There'll be more damage to engine/clutch/gearbox while doing all this to conserve fuel. And of course your starter motor as well can get badly damaged... So use the first gear also kano... better safe than sorry. key to all the FE is also correct psi in all tires and free movement of all wheels etc...
Old 15th May 2007, 14:54   #43
rjstyles69's Avatar
Thanked: 795 Times
Adi what I did with the clutch was to only hear that muffler roar mate.Come on it was pretty new and I was just starting to enjoy the sound.
Now you ought say may car sounded much sweeter than yours .
Clutch ride hmmm , I just did it twice with you in the car kano. With T-BHP around how would I think of doing such a thing?
Old 15th May 2007, 15:32   #44
hari_rama's Avatar
wow u all manage so high FE????
on my last trip when i checked the mileage, it was 12.234 kmpl on highway trip with ac between 25% and 50% full time.....yeah i did a lot of overtaking in 3rd gear gng to around 5500 rpm....is there any trouble with my car?? i mean will the fe go down so much???the car has finished the second service....
hey i have a doubt....my car is runnin on 195/69 R14 tires...so wat would be the error in the meter readings??
i covered 460 kms (as on tripmeter) and the car consumed 37.6 litres filled from Reliance pump
EDIT : Though there had been many overtakin maneaouvres most of the time i was cruisin around 80 kmph
hari_rama is offline   Reply With Quote
Old 15th May 2007, 15:42   #45
rjstyles69's Avatar
Thanked: 795 Times
Was that a typo .
santro xing xp 9 kmpl ..help freakr Technical Stuff 41 24th December 2012 18:58
Hello Skoda - Did you read and analyze or merely read ? ajmat Indian Car Dealerships 48 11th March 2009 13:08
4 kmpl palio 1.6???? HELP!!! sajeeth Technical Stuff 66 6th October 2008 20:11
F.E. =150 Kmpl !! DCEite Shifting gears 12 30th March 2008 14:53
