Old 18th May 2007, 21:05   #121
ess_a's Avatar
Ok its a bit OT- But just wanted to share. The max 'city' mileage that I have got from my stock Alto LX was 19.7kmpl!! (Without ac.)
ess_a is offline   Reply With Quote
Old 18th May 2007, 23:41   #122
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Originally Posted by elf View Post
Thank you McLaren.
The car made less noise. I made less noise.
So has it finally solved your intake growl problem ?
Old 18th May 2007, 23:45   #123
Vid6639's Avatar
Thanked: 20,984 Times
My seat of the pants reading? Must've got about 48 km/litre.
you have a fuel gauge by the seat of your pants?
48km/litre is not too bad. how many cylinders were u running 2 or 3?
Old 18th May 2007, 23:48   #124
Godfather's Avatar
Thanked: 65 Times
Yeah.. just hope that it works...It should rise and show the appropriate fuel when filled up..
Godfather
Godfather is offline   Reply With Quote
Old 18th May 2007, 23:56   #125
theMAG's Avatar
Thanked: 1,572 Times
The scenery seemed nicer. The grass was greener. The eyes were brighter. The taste was sweeter.
Then I switched from Floyd to Alanis.
Elf,
48 kmpl is a great figure-congrats. Since when did you transplant the Reva engine into your boots ?
Old 18th May 2007, 23:57   #126
elf
elf's Avatar
Thanked: 9 Times
Trust you bangy boys to solve my problem in an efficient way. Must be the petrol you sniff, as opposed to the brine that we do.
you have a fuel gauge by the seat of your pants? ...
Yup. What can I say - I like it naughty.
... 48 km/litre is not too bad. how many cylinders were u running 2 or 3?
None. I was sipping fuel from a 1 litre Coke bottle whilst pushing my car in the second from left lane. I finished the bottle after 48 kilometres.
The seat of my pants felt great when I finally sat down.
elf is offline   Reply With Quote
Old 18th May 2007, 23:58   #127
elf
elf's Avatar
Thanked: 9 Times
Originally Posted by Godfather View Post
Yeah.. just hope that it works...It should rise and show the appropriate fuel when filled up...
Yes. But one must worry about blow-back. It's known to cause explosions.
Old 19th May 2007, 00:15   #128
Godfather's Avatar
Thanked: 65 Times
Not if the blow back is internal
Godfather
Old 19th May 2007, 00:29   #129
elf
elf's Avatar
Thanked: 9 Times
Not if the blow back is internal...
Then it's just gas. Like this.
Let's get back to topic, shall we, gentlemen?
Old 19th May 2007, 00:31   #130
theMAG's Avatar
For an innocent 3rd party onlooker, it is still on the topic of extracting maximum from least.
Old 19th May 2007, 00:53   #131
navin's Avatar
Thanked: 4,282 Times
So to get 48km/liter you need to
a) cut off the stick shift
b) add a filter that is larger than the engine
c) attach the fuel line to a coke can
d) use 2 or 3 cyl of a 4 cyl engine (so really 2000rpm shown on th tach is 1000 or 1500 rpm)
e) keep the revs below "2000" what ever that is
f) move the tachometer to the seat of one's pants
g) Switch of the A/C
fugedaboutit! I'll stick to 9km/lit and use the money I saved from all those mods for fuel.
And you guys call us ICE guys crazy!
Old 19th May 2007, 01:03   #132
Godfather's Avatar
Thanked: 65 Times
ROTFLMAO
Godfather
Old 19th May 2007, 01:07   #133
elf
elf's Avatar
Thanked: 9 Times
Yup. Reduces weight. Losing your doors, bonnet, boot & glass would also aid greatly. Not to mention that ICE-SHICE you guys keep honking about.
Yes. That's to drown the noise that such large filtered owners might make without the aforementioned glass, doors, boot, bonnet, etc. The closed owner mouth reduces drag. No, not queens. Wind.
Nope. That's just for measuring purposes. One wouldn't know how much one had consumed unless one places liquid intended for consumption into a popular and convenient standard of measure. Such as the Coke bottle. Also used for nostalgic purposes, a la Corvettes of the past.
No cylinders were harmed during testing. Fuel was sipped by owner pushing vehicle, partially for refreshment & mainly for intoxication. It was hot today.
Also commonly referred to as R2K. Almost as bad as the anticipation to Y2K.
No, no, baba. That's the fuel gauge.
Only in Bangalore and only for petrol sniffers. It's too hot in Bombay just now.
Strike one for Greenpeace.
Old 19th May 2007, 01:21   #134
Thanked: 35 Times
Originally Posted by khaadu75 View Post
I dont believe what Im seeing .... 8 full pages of discussion on how to get a better fuel average --- that too being discussed by boyzzz who only can dream,eat,sleep CAMS - forging - free flows - and god knows what else !! Im confused ...
Its embedded in our blood. It sure is. First thing we are thought about a car is FE kya hey? Isnt it?
santro xing xp 9 kmpl ..help freakr Technical Stuff 41 24th December 2012 18:58
Hello Skoda - Did you read and analyze or merely read ? ajmat Indian Car Dealerships 48 11th March 2009 13:08
4 kmpl palio 1.6???? HELP!!! sajeeth Technical Stuff 66 6th October 2008 20:11
F.E. =150 Kmpl !! DCEite Shifting gears 12 30th March 2008 14:53
