Old 15th May 2007, 08:01   #1
vivekiny2k's Avatar
Thanked: 184 Times
Default paint query
Hi folks,
I bought some paint spray can to fix some scratches and faded points (quite bad) and did it today. but it gave me patches of coarse and glossy finish. the color looks perfect now but the reflection is awful.
the paint is still kinda wet (soft). is there a way i can make it shine? in once place where there was a small patch it came perfect. but i had to do the whole trunk lid and it didn't work the way i thot it would.
PS: the can costed <5$ and I had to fix the scratch anyway. I am in no mood to go for an expensive option for this car.
vivekiny2k is offline   Reply With Quote
Old 15th May 2007, 08:34   #2
harry15's Avatar
hey i dont know much about painting but i think you get the shine after the clear coat . so maybe you should try and put a layer of clear coa
t and then it will shine
harry15 is offline   Reply With Quote
Old 15th May 2007, 20:21   #3
sreedotk's Avatar
Thanked: 22 Times
My Advice is to get some rubbing compound and some hard wax polish and give your self a work out. The rubbing compound should even it out and the polish will give it the gloss
I guess you are in US that is why you are in DIY mode?
sreedotk is offline   Reply With Quote
Old 15th May 2007, 20:25   #4
vivekiny2k's Avatar
Thanked: 184 Times
yes, And I am planing to buy a new car anyway. This one got scratched in my last move, on the car trailer. I shud have driven it
Can/should I apply rubbing compound on my new coat of paint? or shud i try clear coat?
Old 15th May 2007, 21:45   #5
Jaggu's Avatar
Thanked: 8,685 Times
option 1: let the paint dry, then use finest water paper and do a clear coat (tricky job coz u require access to spray paint facility for clear coat)
option 2: let the paint dry, couple of hours or max a whole day, then get rubbing compound and smoothen and even out the repaint and then wipe clean and apply good coat of wax (less tricker job)
Old 15th May 2007, 21:58   #6
vivekiny2k's Avatar
Thanked: 184 Times
I believe they have a spray can of clear coat as well in the stores.
Old 15th May 2007, 22:11   #7
Jaggu's Avatar
lucky you in "us of a", so get that and follow the instructions on the can or check with the shop guy
Old 21st May 2007, 07:23   #8
Rehaan's Avatar
Thanked: 25,038 Times
Vivekiny2k,
When using a spray can, you can kindof control whether you get a matt or glossy finish depending on how far you hold the can from the surface you are painting.
If you hold the can far away, the particles dry in the air and then stick to the surface, giving a matt finish.
If you hold the can closer, they hit the surface relatively wetter, giving a glossier finish.
Test this out first and see if it makes a difference (inside the boot / somewhere out of sight)
Secondly, you could try sanding with a very fine grit sandpaper (600++) and then spraying another coat on.
Thridly, give a clearcoat spray on a try.
cya
R
Old 21st May 2007, 08:06   #9
vivekiny2k's Avatar
Thanked: 184 Times
Vivekiny2k,
cya
R
yup, i figured that out by trial and error. and i did a clearcoat too. procedures say now i shud do a rubbing compound and then wax. but then it would be too shiny for the rest of the car. so i will stop for now.
will try finishing the whole car sometime later.
Crazy Custom paint jobs X-Machine The International Automotive Scene 67 18th October 2015 13:09
Innova Purchase Query + Query on Price Increase by Toyota SanMan SUVs, MUVs & 4x4s 7 30th April 2008 13:13
paint over paint DRC Technical Stuff 33 25th August 2006 12:05
What a paint job..S2000 with Clear Paint.. _Crazi4Speed_ The International Automotive Scene 6 20th September 2004 23:44
