Old 16th May 2007, 12:39   #1
Rtech's Avatar
Thanked: 221 Times
Default Whats the problem?
Car: '05 M800 5 Speed
Problem: Engine and all electrics shuts off when idling if the headlights are switched on. After a few minutes, the electricals start up again and the engine can be started and the car driven normally. Try and turn on the lights and the same problem arises.
Possible causes:
- Short in the wiring maybe brought about due to frayed/rat eaten wires
- what other things should I look out for ??
Old 16th May 2007, 12:58   #2
ramie2400's Avatar
Thanked: 58 Times
remove the headlight bulbs and then try switching off/on.. this will confirm if any of the one bulb is malfuncuning or faulty.
Old 16th May 2007, 13:33   #3
gemithomas's Avatar
Thanked: 138 Times
have a look at this. must be a simmilar issue
http://www.team-bhp.com/forum/techni...-switched.html (Alto vibrates when Headligts switched on !!)
Old 16th May 2007, 17:41   #4
Jaggu's Avatar
Thanked: 8,684 Times
bulb holder, check if its melted. Battery terminals/earthing for the whole car as well as the head lights.
again it can be anything in the head light circuit, from switch to other bulbs like tail lights acting up.
Old 16th May 2007, 17:43   #5
Rtech's Avatar
Thanked: 221 Times
Thanks. Will check this today, (day)light permitting!
Old 16th May 2007, 18:01   #6
had the same problem in my indica once, not only headlights be it any electrical operated such as indicator , the engine would shut off, it could be strated after some time.
probable cause:
1. short circuit(possibly some wire getting earthed with body), difficult to locate.
2. faulty main battery cable connector(a fusible link), open -clean& retighten it or replace the fusible link.
got it done my self & now its fine.
arunforu1 is offline   Reply With Quote
Old 16th May 2007, 18:04   #7
Rtech's Avatar
Thanked: 221 Times
I checked the battery connections last night itself. They were fine. Will check the bulb holders and whatever visible wiring I can this evening.
Old 16th May 2007, 20:08   #8
Revvhead's Avatar
sounds like a short to me.
do your lights come on when only the ingnition is on but the car
is not started??
Revvhead is offline   Reply With Quote
Old 16th May 2007, 22:17   #9
Mpower's Avatar
Thanked: 1,687 Times
Check to make sure you have a good ground. Sometimes the ground cable is loose or corroded.
Old 16th May 2007, 22:22   #10
Rtech's Avatar
Thanked: 221 Times
Update: Went over this evening. First thing I did was remove the headlight bulbs and checked the connections. They had a lot of surface rust build up on them, along with a lot of sand under the rubber protective boot. No sign of frayed wires anywhere.
Cleaned all that up. Left the bulbs unconnected. Started the car up and let it idle. All fine. Turned on the AC. All fine still. Turned on the indicators and parking lights, no probs again. Then connected the headlights, one at a time. All fine.
Car ran fine in the 20 minute drive. So I guess corroded connectors was the issue, which is now solved. Thanks for the tips guys.
Old 17th May 2007, 00:05   #11
ramie2400's Avatar
Thanked: 58 Times
thats great,so the funda worked,some years ago the same problem happened with me in my dad's Tata Estate, so he did the same thing..congrats saved from getting charged from mechanics or the service people
Whats double clutching & whats the reason to use it _Crazi4Speed_ Technical Stuff 109 25th February 2016 08:49
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 85 2nd September 2009 18:47
NHC - BullKit Problem :EDIT: now detected to strut problem ibcool Technical Stuff 13 9th September 2007 12:02
Whats the fastest i.e whats the highest average speeds that you have maintained naveendhyani Street Experiences 1 3rd April 2006 18:09
Whats the fastest i.e whats the highest average speeds that you have maintained MKRAFT Street Experiences 1 3rd April 2006 17:25
