Old 17th May 2007, 12:38   #1
mobike008's Avatar
Thanked: 8,319 Times
Default High Beam Suddenly Conked Out
Guys, last night when i was driving back home from office. I changed the beam from low to high. There was a slight flicker and high beam light doesn't come on though the low beam works fine.
What could be the problem and resolution for same? I have phillips blue vision 90/100 replaced on my stock lights.
Old 17th May 2007, 12:47   #2
kpzen's Avatar
Thanked: 1,655 Times
Remove the bulb n check its not fuse..If its fine then relay could be the culprit..
I had a similar problem n in which the relay was the culprit..
Old 17th May 2007, 12:54   #3
mobike008's Avatar
If relay is the culprit? Do i need to change it then? It costs 800 bucks
Old 17th May 2007, 12:57   #4
iraghava's Avatar
Thanked: 156 Times
My issues have generally been the bulbs conking out, check them first like KP said.
Old 17th May 2007, 13:52   #5
akroy's Avatar
Thanked: 29 Times
I too faced the same on 2 occassion (either of the bulbs)...high beam gets conked off....Both the bulbs lasted 12 & 13months respectively...
Abhi
akroy is offline   Reply With Quote
Old 17th May 2007, 14:45   #6
mobike008's Avatar
Abhi
Mine are not even 6 months old . Will check it out in the evening
Old 17th May 2007, 14:48   #7
moralfibre's Avatar
Thanked: 6,532 Times
Its not about the age buddy. Some bulbs just dont work right.
Old 17th May 2007, 14:53   #8
akroy's Avatar
Thanked: 29 Times
, it can happen anytime... just like a normal filament bulb...
Old 17th May 2007, 15:02   #9
Jaggu's Avatar
Thanked: 8,686 Times
check relay and wiring, especially grounding and "no" relay wont cost 800 bucks, relay plus wiring kit and fitment does
Old 17th May 2007, 15:34   #10
gopz's Avatar
Just the relay would cost 400 bucks. Check if anything is burnt
gopz is offline   Reply With Quote
Old 17th May 2007, 16:14   #11
Jaggu's Avatar
does the relay and wiring has fuse inline? i had 2 separate fuse in my kit, check them first if so.
do a thorough check coz headlights can be a pain sometimes with failure, and always carry a set of spare if your brand has a habit of blow offs.
i had used philips rally and had no issues, though some people had warned against failure but i think its mostly the fake ones that have this habit.
slightly OT: does this blue vision one gives white or blue light?
Old 17th May 2007, 16:20   #12
mobike008's Avatar
White lights though not as bright as the xenons that we see on a Skoda
Old 17th May 2007, 17:06   #13
esteem_lover's Avatar
Thanked: 451 Times
If the low beam is working, then you have burnt one filament in the headlight bulb, replace the bulbs & you should be fine.
Old 17th May 2007, 17:09   #14
Jaggu's Avatar
he mentioned high beam not coming on which is an indication that both the headlights and that looks more like lighting circuit failure and not bulb
Old 17th May 2007, 17:22   #15
n_aditya's Avatar
Thanked: 2,780 Times
Looks like an issue with the relay and not the bulbs. Cant see how it is coincidental for 2 bulbs to fuse out the high beam filament at the same time.
I had a similar issue sometime back... i had just reached chennai after my visit to blore and the high beams refused to work. They were fine on the highway. So took the car to a mech and found out that one of the fuses in the relay had short-circuited. Replaced the fuse and the highbeam was just fine.
Advise you to check the relay. That looks like the culprit. If ur relay kit has fuses supplied they might have gone bust and need replacement. If the relay itself should be changed it would not cost more than 500 bucks including wiring kit. I have the lucas TVS relay kit with my Philips Rallye (100/130W).
Radiator fan conked off in my Fabia! mayank123 Technical Stuff 13 21st November 2014 08:48
Is driving with high beam inside city an offence? speedsatya Shifting gears 66 21st April 2010 15:44
Combination switch conked off. Can't find one in the market! FanaticOnWheels Technical Stuff 6 16th April 2010 12:34
BMW Nightvision & High Beam Assist karthik247 The International Automotive Scene 13 27th February 2010 19:14
Help needed - Desktop conked ntomer Gadgets, Computers & Software 36 4th November 2008 14:11
