Old 19th May 2007, 00:48   #16
mclaren1885's Avatar
Thanked: 35 Times
Infractions: 0/1 (10)
Clutch problems specially at low speeds should be a concern. However when the car behind is at a distance and the car in front is at a halt and you begin to tow, it gives a big jerk. I am thinking this is kind of harmful to the chassi as it is not designed to these jerks. At times these jerks are really violent.
Old 19th May 2007, 01:16   #17
elf
elf's Avatar
Thanked: 9 Times
Originally Posted by arunforu1 View Post
No damage can incurr on chassis while towing, unless you bump into tracting vehicle. ... I dont see anything damaging clutch while towing.....
Hello? Depending upon where you're towing from (on the vehicle towing & the vehicle being towed), the towing distance and the traffic & road conditions, you could end up damaging the monocoque structure of the Baleno due to the external strain on the frame.
And the Baleno does not have a conventional Ladder-on-Frame chassis.
elf is offline   Reply With Quote
Old 25th May 2007, 01:30   #18
vipul_singh's Avatar
Thanked: 256 Times
I had to get my Palio towed recently when it suffered damage to the radiator. The vehicle which the dealer used for towing was an Uno. I was sitting in the UNO on the way to the dealer, and I noticed that there was major damage to the chasis on the side the towing collar is attached. The seam between the wheel-well and the floor pan had started to come apart.
What I mean is that towing seems to cause a lot of stress on the chasis, and tat too much of it would cause permanent damage. Of course, the Uno is an '80s design and more modern vehicles are expected to have significantly improved chasis stiffness, but the argument still holds, I think.
vipul_singh is offline   Reply With Quote
Old 25th May 2007, 08:48   #19
Thanked: 11,020 Times
none of the garage cars have a proper towing bracket to distribute he forces. They use the towing hook which is meant for one off situations
Old 25th May 2007, 09:48   #20
Samurai's Avatar
Thanked: 15,766 Times
Most popular tow truck used by most service centers in Bangalore is the Omni. The most expendable car I suppose.
Old 25th May 2007, 12:16   #21
drifter's Avatar
What? An Omni can tow?
Drifter
drifter is offline   Reply With Quote
Old 25th May 2007, 14:08   #22
Zappo's Avatar
Thanked: 2,079 Times
Hmmm... the Autofin (Tata dealer) guys here use a 70-80s tracker... Trucker or some such thing that HM used to make ages back as their break-down vehicle cum tow truck. No doors, seats with massive holes in the foam... its one of a kind vehicle. I wonder how they manage to run that 25 years old vehicle even today! And that too as a two-truck.
Zappo is offline   Reply With Quote
Old 25th May 2007, 15:02   #23
Thanked: 245 Times
Drifter
Omni has got decent power and it will climb where even the 800's wont, its a rear wheel drive and can carry quite some load too.
Old 28th May 2007, 05:45   #24
mithun's Avatar
Thanked: 58 Times
Drifter
Omni has got a wonderful & strong chassis when compared to other costly counterparts and the low end torque is awesome.
Gypsy is another option.
Old 29th May 2007, 18:57   #25
vivekiny2k's Avatar
Thanked: 184 Times
when buying SUVs on toyota site, i noticed a two prep package as an add on which has improved cooling system and transmission system, indicating these are two areas which will take the beating.
in indian traffic conditions, clutch is another part that may fail (unless you are cruising on the highway most of the time).
regd the chassis, baleno's manual is the most accurate place to check.
vivekiny2k is offline   Reply With Quote
Old 29th May 2007, 19:07   #26
moralfibre's Avatar
Thanked: 6,532 Times
Originally Posted by low_bass_makker View Post
Why.........the car would be in neutral while towing........
Arre I meant the car which tows gets a beating on its clutch. The car being towed gets its chassis beat up if the car is not towed properly.
Old 21st July 2008, 23:45   #27
greenhorn's Avatar
Thanked: 1,516 Times
will something happen to the power steering ? its off when the car is being towed
Old 22nd July 2008, 08:42   #28
tsk1979's Avatar
Thanked: 16,420 Times
Nothing will happen to power steering. Its just that you will be required to put in a lot more steering effort since there is no power assistance
Old 22nd July 2008, 09:17   #29
Is there any specification for the rope used for towing? Or any rope/chain will do?
diabloo is offline   Reply With Quote
Old 22nd July 2008, 09:21   #30
greenhorn's Avatar
I thought a rigid bar was used!
Traffic Police menace - Towing away of vehicles. What are the legal recourses? Raccoon Street Experiences 41 25th November 2017 11:30
Mumbai Towing Service: Is this how our cars are towed? frankmehta The Indian Car Scene 133 8th March 2017 18:22
Towing a Vintage Car: Precautions to be taken meisnutz Vintage Cars & Classics in India 62 1st December 2013 16:03
24x7 towing service - Ashish Towing (Mumbai) GTO Mumbai 6 10th August 2011 02:54
Fight against Towing Scuderia The Indian Car Scene 13 9th June 2008 21:59
