Old 19th May 2010, 18:41   #46
tsk1979's Avatar
Thanked: 16,422 Times
When I meant engine mounts I meant engine/Radiator/Fan housing etc., mounts. Sometimes vibrations come under load.
I had this issue of selective vibrations in indica, and every time it was the mounts, sometimes gbox mounts, sometimes engine mounts etc., etc.,
Old 20th May 2010, 00:11   #47
Thanked: 116 Times
When I drove from office to home, I noticed a strange pattern - it started vibrating even without AC, and strangely vibrations reduced after I turned the AC off. But with AC on, the whole dashboard was vibrating, and it produced a humming sound.
I took the car to Hyundai Motor Plaza and they refused to check the problem without a prior appointment. And the earliest appointment, I could get was 31st May.
So I drove to sec. 16 market and showed it to a denter, whose diagnosis was that this is due to mis-alignment of radiator fan - same as the MGF guy. Looks like while stuck in sand, fan too must have been stuck and got misaligned. :-(
Nitin
ntomer is offline   Reply With Quote
Old 20th May 2010, 10:23   #48
Thanked: 116 Times
The radiator fan costs 4500 and according to MGF there is no way a misaligned fan can be repaired :-(
Old 20th May 2010, 10:27   #49
tsk1979's Avatar
If your car is not under warranty, I would suggest hitting the Sector 16 market. An original good quality fan will cost 40% less than Authorized service center price.
Old 21st May 2010, 11:20   #50
Thanked: 103,685 Times
If I park in a no parking area with my handbrakes fully engaged, how are they going to tow my car? Back to front? What if I lock the steering on the extreme position?
Atleast in Bombay, the towing guys are masters at unlocking your car (in 30 seconds or less). They would put the gear in neutral and release the handbrake themselves. If your steering is locked in full right position, all the better for them to push it toward the tow truck. If locked in full left position, they would push the car out in reverse. Worst case, I've seen two guys lift the front up & position the car perfectly for the towing mechanism.
Old 25th May 2010, 16:18   #51
Thanked: 116 Times
I tried in Sec. 16 market but nobody there was able to source the fan for a Getz.
I had no option but to take it back to MGF Okhla, which I did today morning. There the un-expected happened -they cleaned the fan and motor instead of replacing them and the vibrations are all but gone.
Only when the AC is running, the steering vibrates a bit. SA/mechanic told me that this happened in every car, and this very minor vibration is due to running compressor.
Is he right about that?
Also there is a very faint squeaking sound when I turn the steering. He told me that this is due to worn-out springs and bushes in my car and is not a cause of worry. There is no need to change these springs/bushes right now I can keep on driving the car. Is he right about this as well? :-) This sound is very faint, and is audible only when all Windows are up and no music is playing.
Nitin
Traffic Police menace - Towing away of vehicles. What are the legal recourses? Raccoon Street Experiences 41 25th November 2017 11:30
Mumbai Towing Service: Is this how our cars are towed? frankmehta The Indian Car Scene 133 8th March 2017 18:22
Towing a Vintage Car: Precautions to be taken meisnutz Vintage Cars & Classics in India 62 1st December 2013 16:03
24x7 towing service - Ashish Towing (Mumbai) GTO Mumbai 6 10th August 2011 02:54
Fight against Towing Scuderia The Indian Car Scene 13 9th June 2008 21:59
