Old 23rd May 2007, 09:41   #16
abhaybakshi's Avatar
Thanked: 71 Times
Originally Posted by kiranpashtakar View Post
Second gearbox o/h in 5 months sorry if I missed a point somewhere, but i think they have done a bad job on the first overhaul.
Unfortunately yes...this time I have catched ther neck for permanent solution on this through their service manager and directly from Gurgaon
abhaybakshi is offline   Reply With Quote
Old 23rd May 2007, 09:52   #17
Thanked: 71 Times
Car dropped at MASS. Gearbox o/h is being done. Will get my car back on Friday.
Old 23rd May 2007, 14:12   #18
risga's Avatar
Thanked: 46 Times
Smile
How much do you have on your odo? Ideally, they should have replaced the gear-box if you've covered . The o/h can never match the finish of the factory assembled one as they would have all necessary tools etc. Some special tools are usually required when dealing with such complicated assemblies. In the workshop, they seldom have all the tools or some of the tools are in bad shape.
Now that you've accepted the o/h, better to wait and see if problem is solved. However, if your problem persists, I would suggest that you approach Maruti Service people directly and ask for a new gear-box.
risga is offline   Reply With Quote
Old 23rd May 2007, 20:17   #19
Team Fiat's Avatar
The same noise appears in my car too TUK TUK but only while parking or when turning very very slowly we have checked the car in and out. In my car it comes from the left front side we checked the shocks every thing seems right checked the plates on the disc brakes to see if they were lose but all in vain its still there I think its something to do with the struts MASS said its ur wheel cap sir how dumb is that now when I go back Im going to chew their brains to solve this problem The eng doesnt shutter the clutch is great no vibrations what can it be ?
Team Fiat is offline   Reply With Quote
Old 27th May 2007, 09:08   #20
Thanked: 71 Times
Yessssssssssssssss !!!!!! The problem is resolved.... Here it is how they have done. Apologies all, it was not gearbox issue as was suspected.
MASS has replaced "Clutch Cover" which was vibrating making all kinda noises at slow speed. They have also done some pressure plates settings.
Team Fiat - You can check your clutch cover and pressure plates for such noise. I have gone through all since last one month and my Swift is super silent and smooth. (I pray it remains that way in years to come ...)
Also, do not hesitate to approach Service Manager directly after your car is checked by supervisor. Mount pressure on them to get it done in a better manner. (I always call Maruti toll free number and ask them to contact MASS at Pune for better attention..)
Old 3rd February 2009, 18:45   #21
aerohit's Avatar
Thanked: 580 Times
It it the upper strut mount (includes strust mount bearing)
Get it replaced.
No need to replace the Strut, just the mount.
aerohit is online now   Reply With Quote
Please help in identifying? EDIT : It's a Russian GAZ ! i_see Post-War 13 14th August 2016 16:45
Please help me in identifying this Honda motorcycle ferrariKSA Motorbikes 14 27th April 2011 00:51
Please help in identifying decent resorts/hotel around Mussoorie TSEA Route / Travel Queries 1 11th April 2010 04:59
$1M prize for identifying car acceleration problem bj96 Technical Stuff 0 3rd March 2010 15:40
Help required with identifying Background score... adit1329 Shifting gears 10 27th March 2006 19:46
