Old 20th May 2007, 12:38   #1
karan561's Avatar
Thanked: 10,561 Times
Default SX4 on LPG ?
I am plannin to replace my indigo LS , i want to go in for the SX4(zxi) and wanted to add an LPG kit to it as my running is over 50-75 kms/day. Is it a wise descision ? And what about the FE ,pick up,and how to go about on this project & how economical will that be ... help me out guys
karan561 is online now   Reply With Quote
Old 20th May 2007, 13:04   #2
BUSA's Avatar
@ Karan 561 - It is not wise to replace your car with a brand new car which would be put on LPG and you will surely be out of waranty. The SX4 is a new car with a new engine, we are not aware of what problems it has so it wont be advisable to go LPG, instead i would suggest you to go for a Verna or Fiesta D at ~ prices. Better still wait for sometime the 1.6JTD 120bhp SX4 is coming.
Old 20th May 2007, 14:59   #3
theMAG's Avatar
Thanked: 1,574 Times
Karan561,
Busa is right in that one mustnt tamper with a brand new generation engine. Also as Busa said, if you're looking at low running costs and a C/C+ sedan, look at the diesels or the City CVT.
Old 20th May 2007, 15:22   #4
.anshuman's Avatar
Thanked: 9,159 Times
diesel is a better bet as availablity of LPG is a big headache.....and another thing you will spoil your warranty.
Old 20th May 2007, 15:30   #5
karan561's Avatar
any idea when is the SX4 1.6 D launching ?
or should i go in for the Swift D ? (way too crapmed)
i test drived the indigo DicoR recently , didnt like it , i found the TCIC engine smoother.
and FABIA ?? (wer is it anyway)...(did sit in the fabia @ autoexpo , not much of legroom in it)
i already have a laura , and a corolla , the indigo which i have is chauffer driven , so i need legroooooooooooom)
Old 20th May 2007, 15:36   #6
DCEite's Avatar
Thanked: 607 Times
Do you drive yourself? In that case Swift D is not a problem. The front seats are quite good infact.
You can also consider Fiesta TDCi / Verna CRDi.
DCEite is offline   Reply With Quote
Old 20th May 2007, 19:24   #7
navdeep's Avatar
Expect it next year around July. Maruti needs some time to get settled with manufacturing of D engines.
navdeep is offline   Reply With Quote
Old 20th May 2007, 21:49   #8
mail4ajo's Avatar
Thanked: 261 Times
I do not agree with the advise that LPG kit on the SX4 will cause any problems if installed by a competent installer.
In Italy and other countries, the most advanced cars run on LPG, CNG etc. Its a proven fact. In India, we do not have advanced kits cause it wont sell due to higher costs. Believe me, I saw the CNG fuel injection system with separate injectors in city buses in the US. If warranty is not your priority, you can consider this.
  • Currently you do not have an approved kit for SX4. It would take a while to have the kits approved by ARAI. So you will have to wait. I suggest you run for atleast 5-8K kms before you install.
  • When the kits do come, be sure to spend a little more and install a sequential closed loop system. I do not recommemd a open loop kit. They are not meant for a MPFI car as they may damage the CAT in the long run. Iam converting to low end closed loop system soon.
  • 1.6 SX4 diesel will not be out for sometime. The new plant is still limping with Diesel engine deliveries. They have an export commitment as well. Evaluate the running cost and ownership cost as compared to a LPG convert.
mail4ajo is offline   Reply With Quote
Old 20th May 2007, 22:12   #9
BUSA's Avatar
With a LPG Kit you can say good bye to the biggest boot in the segment
Cat? Can you elaborate a bit here.
Old 20th May 2007, 23:16   #10
esteem_lover's Avatar
Thanked: 451 Times
Yeah, the one that chases the mouse. LOL
I think he meant the catalytic converter
Old 20th May 2007, 23:18   #11
iraghava's Avatar
Thanked: 156 Times
Cat = Cat Con aka Catalytic Convertor.
Old 20th May 2007, 23:29   #12
BUSA's Avatar
Wink
I thought the same but wanted to confirm buttttt who uses it anywayz
Old 21st May 2007, 01:19   #13
karan561's Avatar
but who does these installs .... ? as in any reliable source ?
Old 21st May 2007, 01:26   #14
karan561's Avatar
I will not be driving this car much if il be drivin will be taking it to my gym to the max (which is hardly 1-1.5km)but have driven the swift D ... the front seats are okay ... but the rear ones is still a question mark . After having an indigo in the stable the space/legroom it offered has spoiled me enough ... so legroom needs to be a ++ , fiesta Tdci is a good deal thogh ... and i will be buying these cars @ silvassa ( DN registered) , so ;
SX4 (zxi) - around 6.97
swift D (ldi) - around 4.75
fiesta 1.4 tdci (exi) - around 7
had test drived the indigo XL but the dicor engine was a turn off ... the TCIC is way more refined .
Old 21st May 2007, 01:28   #15
karan561's Avatar
so really very confused at the moment ....
New WagonR Duo OR Chevy Spark LS LPG OR Hyundai i10 LPG? Oxy Hatchbacks 39 24th August 2014 08:02
Santro GL LPG or Spark LS LPG arunjeetsingh Hatchbacks 13 28th April 2010 14:37
LPG car for my parents (Old Alto or new 800 LPG) jits_1998 Hatchbacks 7 9th October 2009 11:19
Palio 1.2 fitted with LPG Kit - Petrol level keeps coming down in LPG Mode shineshine Technical Stuff 9 10th May 2009 04:52
Wagon-R: VXi+LPG OR LXi+Upgrades+LPG? EDIT: Now booked LXi sohu9 Hatchbacks 14 16th January 2007 13:37
