Old 20th May 2007, 19:59   #1
abhibh's Avatar
Thanked: 34 Times
Default Clutch problem or what ?
Just yesterday i drove my friends friend Esteem. It was a very nicely maintained car. Every thing was top notch except when i was gear shifting the engine used to rev when i used to press clutch to change gear.
Any idea whats the prob ?
Old 20th May 2007, 23:22   #2
danlalan's Avatar
Thanked: 135 Times
Hmmm...either accel cable is the problem or ..Could be the clutch also,Your releasing the Clutch too early and giving acc..that why it over revs...The clutch of that car must be releasing really late..right at the end.You must be used to your car's clutch so your releasing it half way.YUP his clutch needs replacement.
danlalan is offline   Reply With Quote
Old 21st May 2007, 14:33   #3
k36
k36's Avatar
Thanked: 19 Times
Check if the idling is set properly.
k36 is offline   Reply With Quote
Swift D-Clutch/Gear Problem : Competent Motors unable to solve the clutch shudder Eddy Technical Stuff 48 8th September 2013 23:03
Using clutch and designing clutch... The Wolf 4x4 Technical 55 9th May 2011 11:50
Problem with Clutch - Clutch cylinder replaced! Hats off to Talera Motors! Chevy_lover Technical Stuff 0 24th September 2008 14:13
Which is the right Sequence Clutch-Brake Or Brake-Clutch ankura12 Technical Stuff 2 9th July 2007 10:02
wet clutch vs dry clutch and slippers clutches devsus Motorbikes 7 16th May 2006 10:08
