Old 22nd May 2007, 14:55   #1
Thanked: 22 Times
Unhappy Help! Indigo .. does not go
I took delivery of Indigo LS (diesel) last week for my uncle. The problem I am facing is, With full(max - blower) AC ON and 4 people inside the vehicle do not pickup from second gear after you slow down. Example: I slow down for a speed breaker and I expect it to pickup from second gear, but it is very very very slow. Needs me to shift to first gear.
I have palio D and never faced this problem. Does indigo generally behave like this or is it this particular car. please let me know.
pach is offline   Reply With Quote
Old 22nd May 2007, 15:40   #2
Thanked: 103,332 Times
Yup Pach, the Indigo TDi does not pickup from the 2nd gear (like you would expect a diesel engine too). Among other reasons, the turbo-lag only makes this worse.
Its best to shift up to 1st and thats the only way to go about it. However, you will see a massive improvement once the engine crosses the 5000 km mark. It performs much better then.
Old 22nd May 2007, 15:51   #3
esteem_lover's Avatar
Thanked: 451 Times
Yeah, that was my impression too the first time i test drove the indigo. There was no taking off in the higher gears like we always expect to from a diesel. However i have not driven the run in indigos.
Old 22nd May 2007, 15:57   #4
.anshuman's Avatar
Thanked: 9,158 Times
Pach you are talking about the trbo lag in the indigo diesel,the turbo lag is felt below 2000rpm in tata indigo and indica turbo,the only solution to the problem is to downshift and try to keep the revs above 2000rpm.
Old 22nd May 2007, 16:02   #5
tsk1979's Avatar
Thanked: 16,418 Times
Actually this is the only place a DICOR scores over the regular indigo. The TDI is lifeless below 1800rpm, above that its whoosh.
So you need to adapt your driving style from a NA car to a TD car.
Old 22nd May 2007, 16:05   #6
anonymous's Avatar
Thanked: 15 Times
I also face the same problem and normally I do not change it back to first gear. It takes time to pick up and and everybody at the back are shouting but they have to wait, until my car picks up the speed.
anonymous is offline   Reply With Quote
Old 22nd May 2007, 16:49   #7
karan561's Avatar
Thanked: 10,493 Times
you will have to get use to it .... thats all i have to say ....
karan561 is offline   Reply With Quote
Old 22nd May 2007, 16:56   #8
Thanked: 22 Times
Thank you all for your replies. I feel better now.
Old 25th May 2007, 00:46   #9
kartikkumar's Avatar
Like everyone said, you just have to change your driving style to suit the engine characteristics. I moved from a petrol to an Indica and felt very frustrated for the first few months because it refused to move below 2000 rpm. And with the AC on, it seemed like I could push the car faster. Changing to first gear is your only option.
kartikkumar is offline   Reply With Quote
Old 25th May 2007, 01:07   #10
Thanked: 451 Times
i love that statement. LOL
But you guys have to make that small adjustment of moving over to the left side & letting other guys pass through. would be greatly appreciated by everyone.
cheers
Old 25th May 2007, 11:10   #11
theMAG's Avatar
Thanked: 1,572 Times
Originally Posted by pach View Post
...I feel better now.
You'd have felt a lot better if it were the Dicor
Old 25th May 2007, 11:52   #12
headers's Avatar
Thanked: 464 Times
ofcourse the option to go flat out on the speedbreaker exists..an the indigo comes with a rather decent suspension setup..
Also..the Palio D is a large 1.9 litre engine which is NA..hence low end pulling power is great.
"Help, indica does not start" solutions tsk1979 Technical Stuff 24 12th May 2013 21:16
Dell Inspiron 5150 - Does not boot - Need help laluks Gadgets, Computers & Software 23 1st February 2010 09:54
Car stalls and then does not crank-start -Help rakowli Technical Stuff 21 5th August 2009 12:16
Why Aveo Does Not Sell? Pls help Shyamtanu Sedans 61 20th November 2008 19:25
Indigo Marina conv to Indigo Advent vivek.singh.73 Modifications & Accessories 1 27th August 2005 09:26
