Thread Tools
Old 26th January 2008, 10:39   #16 (permalink)
I finally went back to Saini Hyundai (Hyundai Dealer's Workshop) to get the clutch overhauled & asked them to check the power steering pump thoroughly.
They have replaced the clutch plate, pressure plate, clutch release bearing & clutch cable & the clutch operation is perfect. Unfortunately the grinding noise. vibration & intermittent engine RPM increase still persist.
They removed the old power steering pump but could not find any fault in it. They installed a new power steering pump but it did not solve the problem. So they have refitted the old pump.
It has probably become a little bit of a mental thing with me but I do want to get rid of this problem. Where do I go from here? I asked if it could be a defective power steering pressure switch but was told this would have certainly resulted in a leakage.
Any suggestions will be sincerely appreciated.
__________________
The most exciting phrase in science is not "Eureka" (I found it) but probably "That's funny...."!
nura is offline   Reply With Quote
Old 26th January 2008, 19:53   #17 (permalink)
Lukeskywalker's Avatar
Hi Nura, I think even my Santro which has done about 45k kms needs the change of belts and clutch overhauled. Could you pls provide me the costs of replacement of these parts at the A.S.S?
Thanks,
_Hari
Lukeskywalker is offline   Reply With Quote
Old 27th January 2008, 18:08   #18 (permalink)
Some good news that I'd like to share. The noise, vibration & engine RPM problems disappeared after the power steering pump pulley was changed!
@Lukeskywalker - Belt-replacement including labour cost me Rs 900. Clutch plate, pressure plate, release bearing & cable replacement with labour cost Rs 3800. The jobs were done at Saini Hyundai, a dealer's workshop.
__________________
Old 27th January 2008, 19:00   #19 (permalink)
__________________
Thanks Nura, I was asked for around 8k for clutch replacement, hence my query. I'll check again with the Hyundai centre. Just discovered the santro clutch pedal has absolutely no resistance to offer when engaging it, also could not slot gears smoothly, there was a free service checkup by Gulf oil ppl at my apartment complex and on getting the car inspected, was told the clutch cable is cut, so needs to be replaced.
Old 27th January 2008, 20:10   #20 (permalink)
A clutch cable replacement should cost you about Rs 600.
__________________
Thread Tools
lancer power steering & speedometer problem trashishh Technical Stuff 3 13th May 2008 19:19
Problem with Contessa Power steering - Aftermarket fitment quicksilver Technical Stuff 10 13th July 2007 22:57
Stiff power steering : What could be the problem? kshastry Technical Stuff 8 25th May 2007 18:25
Power steering Problem - Ford Flair Vineet panwar Technical Stuff 2 4th April 2007 14:55
Fiat Petra -Problem with power steering. rishi_kapoor Technical Stuff 0 2nd May 2005 18:24
Powered by vBulletin
