Old 3rd August 2010, 17:14   #31
Thanked: 11 Times
Originally Posted by nura View Post
It seems the problem is finally solved.
In the old Santros (like mine), the crankshaft pulley turns the water-pump pulley & the water-pump pulley turns the power-steering pump pulley via another belt. In the newer Santros, the power-steering pump pulley is turned by the crankshaft pulley itself.
An ingenious technician at Saini Hyundai decided to replace my old system with the new one. He removed the new power-steering pump & refitted the old one. A pulley & belt had to be replaced & another pulley & belt had to be removed & discarded.
I am now poorer by another few hundred rupees, have an almost new power-steering pump in my kit bag & Team-bhp is heavier by another post.
As for the grinding noise, it has completely disappeared.
Hope this thread helps someone in a similar situation.
Hi Nura,
i think i am facing the same issue can u post a picture of the new system and the cost by each item.
good to hear that the issue resolved, one thing i wanna tell u the issue should be solved when u replaced the water pully.
thanks
svpatra is offline   Reply With Quote
Santro power steering problem & timing belt prob coolmob Technical Stuff 14 11th April 2014 18:57
Maruti Esteem - Non Power Steering to Power Steering udit78 Modifications & Accessories 14 4th May 2011 13:29
Power steering to manual steering? ramzsys Technical Stuff 18 11th August 2010 23:16
Need Help! Problem after changing to K&N stock filter in Swift ZXi Lotusking Modifications & Accessories 8 26th November 2007 15:09
Electric Power Steering Vs. Hydraulic Power Steering joseph5600 Technical Stuff 3 19th November 2007 20:56
