| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #31 (permalink) | |
| Senior - BHPian | Quote:
__________________ "You can discover what your enemy fears most by observing the means he uses to frighten you." - Eric Hoffer | |
| | #32 (permalink) |
| BHPian Join Date: Feb 2005 Location: Chennai
| I too am facing problem while down-shifting from 3rd to 2nd. I don't get any krrrrrr noise, but the gear stick simply wouldn't go to the left extreme. It gets so worse sometimes that i have to engage it back in 3rd momentarily and come back to 2nd to engage the gear properly. Any tips to get over this problem?? This is a brand new Swift. Any chance it will go away as i run more milege?? |
| | #33 (permalink) |
| BHPian Join Date: Mar 2007 Location: Bangalore
| OSS: You try out Doubleclutching - first bring to Neutral and than to gear 2. This should solve your problem for now. As your vehical runs in the gear smoothen out. You would definetely feel the smoothness after 5000 KM of Run. |
| | #34 (permalink) |
| BHPian | Okay, while reversing, never be in a hurry (unless you want to grab that parking spot before somebody else zooms in ;-)) Just stop the car momentarily, press the clutch, let the gearshift go to neutral, let the RPM come down to less than 1K (it takes less than two seconds), and then engage the reverse gear. You'll be fine. This is from personal experience! - KK. |
| | #35 (permalink) |
| OK; when i bring to neutral and before moving to 2nd, are you suggesting that i release the clutch and then re-engage again to move to 2nd, or it just a single clutching operation, with a momentary pause at neutral? |
| | #36 (permalink) |
| OSS-Yes you need to release the clutch as you get to neutral and then reengage and push the gear to 2. After some run in you can also momentarily pause in Neutral and then gradually go on to change the gear in a single stroke. Just my experience on my car, might help you too not guaranteed though. |
| | #37 (permalink) |
| BHPian Join Date: Apr 2006 Location: Karamattom, Aluva, Kotagiri, Yercaud, Hospet, Indore, Nashik, Pune (now)
| I have no issues shifting from 1st to 2nd in my Swift. To engage the Reverse Gear, sometimes I do have to clutch twice. Shifting from 1st to 2nd will not be as smooth as 2nd to 3rd or 3rd to 4th or 5th to 4th since the gear lever will automatically try to move to the middle position in neutral. So one has to exert a little extra force to push it to the extreme left. I guess this should be true for all other cars too. You have to just get the right technique that RX135 has already explained. |
| | #38 (permalink) |
| Senior - BHPian Join Date: Jun 2007 Location: Chennai
| I have found this with reverse on almost every car I've driven. It is not syncromesh; there is no need for it to be as it should not be engaged while the car is moving. A quick engage/disengage of the clutch spins those cogs, and the gear slips in nicely. I drove a VW golf about twenty years ago that was hard to get into 3rd from 4th. Just hard work. I raised it as a warranty issue, just before the warranty expired, and they said it was a known issue and all they had to do was to replace the mineral oil in the box with synthetic! I found this very hard to believe --- but it worked! |
| | #42 (permalink) |
| BHPian Join Date: Feb 2008 Location: Bangalore
| Hi Guys, See my thread with a very similar or rather identical issue albeit on a different car. But it has been suggested that it could be a syncromesh issue. Do let me know your thoughts. The link is below: http://www.team-bhp.com/forum/techni...tml#post862544 (Problem in shifting to lower gear) Regards, Harsha
__________________ If you're incompetent you have to be honest, and if you're crooked you have to be clever. |
| | #43 (permalink) | |
| BHPian | Quote:
I am surprised that you consider Swift as long throw - OK, I don't know what you are comparing to, but Esteem, Wagon R, Santro etc should have longer throws, I guess. In fact, I loved the meaty shifts of the Swift and it could give you precise, fast shifts if you chose to do it. It was all in the technique, as outlined in the previous posts. | |
| Thread Tools | |
Similar Threads | ||||
| Problem in shifting to lower gear | harsha.cs1 | Technical Stuff | 18 | 11th June 2008 20:17 |
| Swift 2nd Gear Problem EDIT: Now first gear problem | BUSA | Technical Stuff | 81 | 10th February 2008 11:58 |
| Quick shifting, 1st to 2nd... | doomsday | Technical Stuff | 128 | 23rd October 2007 15:45 |
| Car banged. Gear shifting problem! | maxbhp | Technical Stuff | 15 | 15th September 2007 12:48 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
