Thread Tools
Old 24th May 2007, 14:36   #1 (permalink)
Default SWIFT - Shifting to 2nd gear problem
Anyone experience slight problem with gear shifter
When I shift from 1 to 2 - shift in not smooth at all.
It doesnt really have anything to do with tramissions
I am talking about the shifter feel from 1 to 2 gear.
It feels very lose / sticky and doesnt shift smoothly to 2nd gear.
Anyone experieced this?
eflanker is offline   Reply With Quote
Old 24th May 2007, 14:53   #2 (permalink)
I don't like the shift feel also. It does feel lose and easy and not chunky like it should. Its not tight and thick if you know what I mean.
srishiva is offline   Reply With Quote
Old 24th May 2007, 16:12   #3 (permalink)
I do feel the same. My Swift is Just 6 months old. First I used to feel that since I am a newbee at driving it was because i would not shift properly. But of late I too feel that my shifting is not a problem its the gearshift that has a problem. It some times gets stuck in the neutral while trying to shift from 1st to 2nd. shifting from 5th to fourth is also not smooth.
Anand_A is offline   Reply With Quote
Old 24th May 2007, 16:26   #4 (permalink)
DieselFan's Avatar
I think it is better than the Santro I had. My Santro used to slip to Neutral if I travelled on a huge speedbreaker.
DieselFan is offline   Reply With Quote
Old 25th May 2007, 10:14   #5 (permalink)
mail4ajo's Avatar
I think this normal in most Marutis, Just raise the RPM a little when you shift. The transition from first to second is not slick. I found it really bad in WagonR, even new cars.
Push the lever to the extreme left and then shift to 2nd.
__________________
*2006 Maruti Alto LXi - Closed Loop LPG kit - Disconnected now* *2003 HH Ambition* *1998 Yamaha RX135*
mail4ajo is offline   Reply With Quote
Old 25th May 2007, 10:38   #6 (permalink)
Oh, the swift shifter is good. It doesn't get stuck anywhere. Its just that its not in the league of say a Honda.
Old 25th May 2007, 13:08   #7 (permalink)
benbsb29's Avatar
Do this, and the gears usually do slot in easily. Trying to slot into second while maintaining the same straight line doesnt work IMO.
__________________
"You can discover what your enemy fears most by observing the means he uses to frighten you." - Eric Hoffer
Old 25th May 2007, 13:13   #8 (permalink)
DCEite's Avatar
I dont find any problems in 2nd gear. Its a long throw, thats it. The reverse and 5th are the main culprits. Just cant find 4th after 5th. Its been 3 years and no luck :(
DCEite is offline   Reply With Quote
Old 25th May 2007, 13:22   #9 (permalink)
zenx's Avatar
With my limited range of cars driven I will hazard a guess that this shift is a little trickier than most - u have to get in the correct rev range else it never just 'happens'. Tech gurus may be able to contest/explain this better tho.
__________________
Sameer, Bangalore
zenx is online now   Reply With Quote
Old 25th May 2007, 13:28   #10 (permalink)
rdas45's Avatar
Talking
No man, I have had my swift for a year now and I aint finding this loose swift like you are. Why dont you drive some other swift and check.
Instead I find it a problem shifting the gear in reverse with the sound going kkrrrkkkk. LOL..
rdas45 is offline   Reply With Quote
Old 25th May 2007, 13:45   #11 (permalink)
hrag's Avatar
I think this is a Maruti trait. I had the same issue in my Omni. The service advisor kept saying it will become smooth and easy with use - 42000 km and 3 1/2 years, 2nd gear was always difficult to get into.
hrag is offline   Reply With Quote
Old 25th May 2007, 14:06   #12 (permalink)
menonrajesh's Avatar
I believe what mail4ajo has written is so true. I do always the same and have never faced any trouble. A few times whenever the gear dont get engaged to 1st from neutral, while moving from stationary, I had to release the clutch and again engae it to 1st..But thats it..
I am not following the 'straight-line' gear engagement and used to route it thru the neutral by pushing extreme left or right..I would say, with a smaller shift, Swift is a boon in this matter compared to Wagon R, Santro etc.
menonrajesh is offline   Reply With Quote
Old 25th May 2007, 15:09   #13 (permalink)
Somtimes double clutching helps in such situations.
kiranpashtakar is offline   Reply With Quote
Old 25th May 2007, 18:17   #14 (permalink)
mail4ajo's Avatar
From a layman's idea, its because the clutch plate and flywheel are running at different speeds. Try boarding a bus or train while its in motion. I cant explain any better.
I have the problem in my Alto, Solve it by pressing the clutch fully or pressing twice.
I have been doing this at most times for down shifting. It gives a better downshift. Actually not required since our gears are synchromesh. But helps the get the plate up to speed before the shift. Works for me.
__________________
Old 25th May 2007, 18:44   #15 (permalink)
nikunj_cal's Avatar
Me too face problems sometimes shifting to reverse, no problems however to shift to second or any other gear !!
nikunj_cal is offline   Reply With Quote
Thread Tools
Problem in shifting to lower gear harsha.cs1 Technical Stuff 18 11th June 2008 20:17
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 81 10th February 2008 11:58
Quick shifting, 1st to 2nd... doomsday Technical Stuff 128 23rd October 2007 15:45
Car banged. Gear shifting problem! maxbhp Technical Stuff 15 15th September 2007 12:48
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
