Old 27th May 2007, 15:51   #1
thealtoman's Avatar
Thanked: 15 Times
Default alto related.....
hai guys,
i own an alto and i was wondering whether it is possible to restrict the useage of my car in any ways other than installing security equipments like immobilizers etc.
one of the mechanics at maruti suggested that ignition, mpfi system are all powered via the fuse box and that removing certain number of fuse will render such a possibility. i dont know upto what extend it is true.
please let me know if this or any other alternate methods can be used.
thealtoman is offline   Reply With Quote
Old 28th May 2007, 06:25   #2
mail4ajo's Avatar
Thanked: 261 Times
Originally Posted by thealtoman View Post
hai guys,
This is cumbersome process. Not feasible each time you leave the car. Install a good scurity system with shock and motion sensor. That should secure your car.
Another method is to use a RFID on the car. Not sure whether its being used in India. Common for expensive cars aboard. The new Maruti immobilser system is good. Almost foolproff. Car thieves have to device a new method to counter this.
mail4ajo is offline   Reply With Quote
Old 28th May 2007, 07:16   #3
akroy's Avatar
Thanked: 29 Times
Install the iCATS, the recently launched engine immobilizer....it is good...
And as mail4ajo suggested, your method looks cumbersome, it is better you install a good security system to protect ur Alto...
Abhi
akroy is offline   Reply With Quote
Old 28th May 2007, 11:22   #4
unknown_entity's Avatar
Default iCATS
I don't think you can install that ... comes fitted with all MUL cars. Don't know if it can be fitted later ... ??
unknown_entity is offline   Reply With Quote
Old 28th May 2007, 12:21   #5
thealtoman's Avatar
Thanked: 15 Times
Default okay
okay thanks guys for your valuable suggestion. now im gonna look out for some good security systems. do you guys have quotes for some of the best immobilizers?
Old 28th May 2007, 13:58   #6
akroy's Avatar
Thanked: 29 Times
Yesterday a colleauge of mine got a new Estilo... he was telling that you can install iCATS in your old car as well....I didnt enquire personally, I need to check....
Abhi
Old 28th May 2007, 14:15   #7
veyron1's Avatar
Thanked: 38 Times
That's actually only good with an incorporated wideband GPS. And only helps locate a stolen car- doesn't prevent theft; aids in recovery.
All systems have loopholes. If you're leaving the car parked for a long period of time, the best way to prevent theft is to remove your steering wheel. Takes 5 mins and a size 24 spanner. Not applicable for expensive cars. Else, use a gearshift lock.
Then there's another way. Little known, though. There's a device called the brake lock. Locks up your brakes. You can't even steal the car by towing it...
There are electrical methods as well, but not as effective.
The next best thing has already been suggested...icats...and yes, it can be fitted onto old Marutis as well...
veyron1 is offline   Reply With Quote
Old 28th May 2007, 15:07   #8
theMAG's Avatar
Thanked: 1,574 Times
Tried removing the wheels?
Old 28th May 2007, 16:17   #9
akroy's Avatar
Thanked: 29 Times
Nice idea Maggie, never thought of that as a security system
Abhi
Old 30th May 2007, 16:25   #10
I feel people are being too paranoid about the safety of their cars unless they live/park in really bad localities, in which case they shouldn't be owning a car anyways. If they belong to the local gundas category, they needn't be worried about their cars. No-one would dare touch their car.
The built-in steering lock should suffice the purpose, even if you intend to park your car for months at any 'decent' place. Gear stick lock can also help, in addition. As someone said, every system has loopholes, and no system can be of any help, if someone just tows the car away, placing all 4 wheels on some kind of move-able platform first. The alarms can be easily disabled by disconnecting the battery (directly open the bonnet first with the help of a jack) and/or the speakers.
Just invest in a watchman at Rs. 300 per month, or park where there's some security in place, already. In any case, spending more than 2-3% of the car's value on security is pointless, and if you drive a super-luxury merc, you can easily afford the garage/parking fees.
amu1983 is offline   Reply With Quote
Old 30th May 2007, 16:42   #11
rjstyles69's Avatar
Thanked: 795 Times
Well I wouldnt be surprised if he said, dismount the engine everytime you parked your car.
Best bet would be to check with your local dealer and get the iCATS installed in your car.
Old 30th May 2007, 19:49   #12
sumeethaldankar's Avatar
Thanked: 1,161 Times
Hi forget all electrical gadgets.Electronics are the weakest part of the car.
Get urself a string gear lock one that would lock ur gear shift as well as the handbrake.This would result in locking of all the 4 wheels.The gear shift will not permit the front wheels from moving as the gear will be in reverse and the handbrake will not permit the rear wheels from moving.This will make the car even difficult to be towed away by the cops.The only downside may be that to install the lock u would need to punch around 3-4 holes in the car chasis.U could try brands like Auto-Cop ,Scorpion or black cat
sumeethaldankar is online now   Reply With Quote
Old 30th May 2007, 21:29   #13
theMAG's Avatar
Not everyone can handle that - hence not suggested
Good idea. Then again, Microsoft had once said that the new activation mechanism in Windows XP would prove unbeatable to hackers.
Sluggish Swift, Edit: And other swift speed related queries pillainp Technical Stuff 90 8th September 2009 21:27
2 Tyres and Alloys related queries abhibh Tyre & Alloy wheel Section 9 22nd August 2007 19:20
BHP,kgm,CC. How are they related? ramzsys Technical Stuff 9 25th April 2007 10:16
Wanted : Quarter Mile Time Calculators and other Drag Related Software !!! mclaren1885 Technical Stuff 12 1st July 2006 18:38
Zen related doubts A S H V I N Technical Stuff 2 23rd April 2006 19:58
