| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Jan 2007 Location: Pune
| I am thinking of installing relay for my new Swift. My concerns are, 1. Would it consume more power and consequently will be load on Alternator ? 2. Is it a strain on electricals of the car ? 3. Is it recommended in a new car with delicate electronics like ECU and all.... Your comments pl.
__________________ - Abhay ======= You truly love your car if ... You visit her frequently just to check if she is sweating in the sun I do... |
| | #3 (permalink) | |
| Senior - BHPian | Quote:
Hope that solves your problem Cheers
__________________ Everybody is entitled...... to an opinion !! | |
| | #4 (permalink) |
| BHPian | I presume that you are installing relay because you are upgrading your head lamps. To my knowledge this relay will not over strain your electricals, ECU or alternator. In case you do not have the relay done for the head lamp upgardes, it will strain your battery.
__________________ Abhi Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves. |
| | #5 (permalink) |
| Yes, I am going for upgrade in headlights. Want to do it before rains start.
| | #6 (permalink) |
| Relay is used to supply more power to upgraded headlights (which consumes more power) without loading alternator or battery (as they say)
| | #7 (permalink) |
| BHPian | Well.... a heavy duty H/L relay wud be necessary incase you are upgrading your HL bulbs to 100/90W or 130/100W halogens!! Every new gen cars come with suitable light duty relays which will neatly safeguard the switching devices! But incase if you are planning to put the above halogens, heavy duty relays is an absolute requirement to sufficiently withstand the extra current which is pulled by the halogens! This is just to safeguard the lightduty switching devices & wiring harness provided by vehicle manufacturers!! It is not the relay that consumes more power... its the high wattage halogens that consumes more power!! Pulling more power thru a heavy duty circuit is definitely safer than pulling more power thru light duty circuit right??!! Thatz the logic!! It won't strain the other electricals of car badly! The extra power consumption will be easily compramised by the extra factor of safety levels of electrical system!! Get it done at the car dealers end itself! They know the circuit better and so will do the job without disturbing the important lines! Drive on!!
__________________ MISSED the action!!! :-( Guess another one has already started happening!! :-) |
| | #8 (permalink) |
| BHPian | [quote=nikkibike;451088]Get it done at the car dealers end itself! They know the circuit better and so will do the job without disturbing the important line Hi, No cutting of wires, just adding the extra wire & relay,[+ve to the bulb through relay contact's] I replaced the stock with GE100/140, total cost will be approx.Rs.650...... |
| | #9 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| I am thinking of installing relay for my new Swift. My concerns are, 1. Would it consume more power and consequently will be load on Alternator ? relays wont. but will help the upgraded bulb to consume more, hence load on battery and alternator will be more. safe to use 100/90 bulbs anything more is undue load on stock battery and alternator 2. Is it a strain on electricals of the car ? kinda yes 3. Is it recommended in a new car with delicate electronics like ECU and all.... if you can avoid for the first year great, but if you really need better lighting then go ahead Your comments pl.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #10 (permalink) |
| BHPian | Jaggu, Is there a way to bypass the original wiring and put an another one for high wattage bulbs and the dealer doesn't get to know about it? So, that the warranty still stands if there is some issue. I guess it is done in the case of music system, where dealers warns about the cut in the original wiring, so installers install a cutout to bypass it. |
| | #11 (permalink) |
| Newbie Join Date: May 2007 Location: ANKLESHWAR
| its good idea to install relay to uprade on halogen lamps. i have fitted in swift and does not create any problem. but pls select a good workshop to install and use branded wiring which comes with provision to fit it without cutting any wires. go for LUCAS brand wiring which comes with ready made socket just to remove and fit. no need to cut any wires. also it comes with booster relay so its very safe and wiring is also of good quality. but it cost more around 900 rs of wiring + relay. and pls do not install bulb more than 100/90 as its not safe for others on road. as already 100/90 is too much light for vehicals coming towards u,so do take care of them also and NEVER NEVER forget to give dipper after installing this capacity of bulb. for futhur help feel free to contact me |
| | #12 (permalink) |
| most of the new upgrade wiring kit dont require any cutting, it comes as a kit. will have coupler that connect to the existing bulb connectors for input signal for the relay and then another set of high wattage wiring along with connectors for the upgrade bulb. this wiring will have separate grounding that can be connected to battery terminal and grounded to earth. though this will take load off the wiring and switch cannot avoid load on battery and alternator which has to happen if you upgrade, as far as hiding away from dealer.. if properly done and tied up using good cable ties and all it will be not be very obvious to eyes. but yes the main wires going into battery is a give away to watchful eyes.
| Thread Tools | |
Similar Threads | ||||
| Knick sound from horn relay | nirmalts | Technical Stuff | 10 | 23rd August 2007 13:26 |
| Honda relay | greatmana2000 | The Indian Car Scene!! | 14 | 2nd February 2007 22:13 |
| Why relay for high watt lamps | DRC | Technical Stuff | 7 | 30th November 2006 17:16 |
| Relay : Bosch or PMP | venkatrx | Modifications & Accessories | 4 | 29th April 2006 02:35 |
| Relay for headlight | Akkiben | Technical Stuff | 7 | 14th December 2005 08:46 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111
