Thread Tools
Old 29th May 2007, 11:30   #1 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Default Whats wrong with the suspension?
I own a Tata indica 2002, done almost 81K kms. At around 75000kms I was told that I would need new Shock absorbers(or dampers to be more technically correct) soon. I have been procrastinating that job since the shocks still have some life left in them, and I thought I will time it with the complete tyre change and Gbox job.
Over the past three days we did 900+kms of hill driving over not so good roads. Imaging going downhill at high speed, tail itching to break out, and then landing the front one tyre into a smooth pothole with a thunk. The terrain was such that the front was bouncing all the time and the roads were very very bad,
Somewhere on the Moradabad delhi highway the front left tyre got a puncture, and today morning when I was taking the car out I noticed that the front left tyre was flat. Changed the tyre and saw this
Don't worry about the strut, thats the plastic coating. Infact in both the wheel wells everything made of plastic(mudguards, flaps) is shattered due to the pounding by gravel(over the numerous Himalayan adventures in the unexplored roads)
I am worried about the shocker.
I don't know about the right one yet. Will get it inspected when I get alignment done.
Meanwhile can you advise me how serious is the damage? Do I need new shockers "Now"?
Since Tata sells one shocker for 2500 and I get 2 for 2300 outside(similar or same brand) , I will go to an independent garage.
Does anybody know a good suspension guy in Noida. In sec 16 most of the dudes don't even have the ramp to mount the car, and raise it for underbody inspection.
I also plan to get all plastic/rubber flappings replaced, but at TASS all that is expensive and I get the same lousy plastic.
So I need to find a good suspension guy.
__________________
Reclaiming.....!
Old 29th May 2007, 11:43   #2 (permalink)
veyron1's Avatar
Err...tsk, the pic ain't showing...
And since you say that the car has done 81K, it's high time for you to replace the dampers. Replace the springs as well. If you do get the suspension done up, change the following components.
Damper/spring combo, knuckle bushings, strut mountings, tie-rods/ends, centre-link, and complete fastener set.
Replacing the above would give a new lease of life to the car. Provided they're done by a good mech..
__________________
DAD
veyron1 is offline   Reply With Quote
Old 29th May 2007, 12:04   #3 (permalink)
Team-BHP Moderator
tsk1979's Avatar
veyron1, try doing a shift+reload?
I tried with multiple browsers the pic is visible.
I know the suspension needs work, therefore I don't want to go to TASS. They are good for regular work, but not for "expert jobs".
I think Noida members can point me to some "expert".
__________________
Reclaiming.....!
Old 29th May 2007, 14:18   #4 (permalink)
Sideways's Avatar
Ya Tanveer I think it's time for an overhaul. 81K is amazing, considering the fact that you've taken the car into the mountains etc. If you are going to keep the car, I would recomend a complete change of all components, just as Veyron has.
__________________
Action on the MMST race track, Chennai - 30th & 31st August
Sideways is offline   Reply With Quote
Old 29th May 2007, 14:27   #5 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Thanks for the tips guys. I plan to keep the car, and maybe take it to the mountains again. In the pic I see something badly twisted. I appears that the damper is being held by just the rubber. Is that the case?
After seeing this I cringe every time the car goes over a pothole.
__________________
Reclaiming.....!
Old 29th May 2007, 14:48   #6 (permalink)
ritayan's Avatar
tsk, it is just the rubber bellow which has come off, the damper is bolted on the top to the ripper bush (not in the Pic), get it checked but nothing to worry abt.
__________________
Vision without action is a daydream. Action without vision is a nightmare
ritayan is offline   Reply With Quote
Old 18th September 2007, 10:21   #7 (permalink)
Any good workshop in pune for getting NHC suspension work doen?
__________________
Aerodynamically speaking, a bumble bee should not be able to fly, but it does not know this, so it flies.
anandpadhye is offline   Reply With Quote
Old 18th September 2007, 11:24   #8 (permalink)
Amey's Avatar
Deccan Honda ??
Amey is offline   Reply With Quote
Old 18th September 2007, 12:41   #9 (permalink)
Deccan Honda? Sure, suitable for suspension charity work:-)
__________________
Old 18th September 2007, 13:27   #10 (permalink)
lordofgondor's Avatar
Hi tsk1979, there's this Star Auto Garage in Sec-16 market from where I have been getting my service/repair work done for the past 2 years. I won't say that these guys are experts, but they know what they are doing and have done a pretty decent job so far. If you go there, ask for Raju bhai as he is quite a knowledgeable fellow and pretty experienced on Tata and Maruti cars.
__________________
Not only is the universe stranger than we imagine, it is stranger than we can imagine!
lordofgondor is offline   Reply With Quote
Thread Tools
Whats wrong with my Corolla's Clutch and Engine? novice Technical Stuff 10 7th March 2008 12:04
Whats wrong with this K&N conical filter assembly rishibravo Modifications & Accessories 25 18th April 2007 18:48
Whats the fastest i.e whats the highest average speeds that you have maintained naveendhyani Street Experiences 1 3rd April 2006 18:09
no idea whats wrong gamerno1 Technical Stuff 22 3rd April 2005 01:38
whats wrong with the emoticons?? _Crazi4Speed_ Shifting gears 2 23rd June 2004 12:29
Powered by vBulletin
