Old 29th May 2007, 17:43   #1
saurabh711's Avatar
Post Storing a Indica diesel for 6-8 weeks
I am an IT guy and had recently bought an Indica Turbo in March 07. I would probably be traveling to the US for a short term assignment for around 6-8 weeks. I need to know what all I need to do to my car so that when I come back its still in good condition and can start off right away.
I don't want to come back and then see that I have to do a long list of things before it can run again. Help!!
Thanks,
Saurabh
saurabh711 is offline   Reply With Quote
Old 29th May 2007, 17:58   #2
theMAG's Avatar
Thanked: 1,572 Times
Disconnect the battery and jack up the car so all 4 wheels are off the ground
Old 29th May 2007, 17:59   #3
for 8 weeks, nothing much needs to be done, disconnect the battery terminal & cover the car.
before storing, inflate tires a bit more than normal, avoid parking on moist surface.
i have parked my indica for 8+weeks due to projects, & it started in one shot after return.
arunforu1 is offline   Reply With Quote
Old 29th May 2007, 18:28   #4
ad75's Avatar
Thanked: 20 Times
fill up the fuel tank too
ad75 is offline   Reply With Quote
Old 29th May 2007, 19:23   #5
saurabh711's Avatar
Disconnecting just one terminal should be enough right? And how much more air should I pump in my tyres? I mean by how many PSIs? 5-6 points?
MODS: Could you please change the title of the thread to "Storing an Indica diesel for 6-8 weeks"
Last edited by saurabh711 : 29th May 2007 at 19:24. Reason: Requesting change for inital post
Old 29th May 2007, 20:22   #6
akroy's Avatar
Thanked: 29 Times
Not one terminal...pls disconnect the negative terminal....keep airpressure 2-3psi more than normal...
Top up the fuel tank...if the car is in open, cover it up....
if it is in an apartment, appoint somebody who will come and clean it up twice a week....
Abhi
akroy is offline   Reply With Quote
Old 29th May 2007, 22:18   #7
condor's Avatar
Thanked: 4,897 Times
Guys, that would mean 6-8 weeks of dis-connection and lack of use & recharge. Wouldnt this kill the battery ? Or atleast, reduce it's life ?
I would suggest - top up the diesel, have some one idle it for about 10 mintues every week atleast.
Old 29th May 2007, 22:34   #8
theMAG's Avatar
It would actually mean reduced rate of discharge (due to no load -compared to connection where there will be leakage of charge even if the engine is off over 6-8 months) and the prevention of acid solidification on its terminals that would in turn reduce the efficiency of current flow and has to be later cleaned with baking soda and a tooth brush to reinit the conductivity of the battery to original levels.
Best solution - if anyone's around.
Old 29th May 2007, 22:48   #9
Thanked: 20 Times
Take adivice on fuel matter from an expert. My friend got his 800 ruined (rust in fuel tank) after he left it unattended for 9 mnths.
swathyd is offline   Reply With Quote
Old 29th May 2007, 23:00   #10
gr8guzzler's Avatar
Thanked: 38 Times
Guys, can you please explain a bit on why these steps need to be taken? Thanks!
gr8guzzler is offline   Reply With Quote
Old 29th May 2007, 23:18   #11
drifter's Avatar
So that the tyres donot deform due to being stationary for too long.
And filling up, to avoid rust formation. But unlikely in such a short span of time, but it doesn't hurt to take precautions.
Drifter
drifter is offline   Reply With Quote
Old 29th May 2007, 23:27   #12
Zappo's Avatar
Thanked: 2,079 Times
saurabh, i have at least twice left my car standing for 4-6 weeks in the last 2 years. On both occassions I disconnected the battery completely and covered the car. For a longer duration (say 6-7 months) even lifting the car off the tyres helps. However its not needed for 1-2 months IMO.
Do not forget to cover the car as well as you can. You may leave one window half inch rolled down if safe. Also while disconnecting the battery follow the order of terminals to release as given in the manual. You will again need to follow the order when you reconnect it back later.
Edit: After disconnecting the battery the central locking will not function. Ensure that all the doors have been manually locked before you leave.
Zappo is offline   Reply With Quote
Old 30th May 2007, 07:11   #13
condor's Avatar
Guys, considering that this is a diesel, is it better to do regular idling than to make her hibernate.
@Zappo, what car did you leave idle for that period ? And that was a good point about the central locking.
Old 30th May 2007, 09:41   #14
do not fill up tank......just leave minimum, as diesel tends to settle tar & gum at bottom if left for too long, so leave only minimum5-6 ltrs, tires would not loose too much pressure in 8weeks, so just pump up 3psi mre than regular.
Disconnect earthed(-ve) terminal, cover up the vehicle, no need to jack up for 8 weeks, as this time is not long enough to cause severe pressure loss causing permanent deforming.
after you come back:
1. connect battery terminal
2. start the vehicle
3. keep it idle for 5-10 minutes, then accelerate in nuetral to the point such that battery sign in i/p goes away.
4. go to a fuel station, refill & get tires inflated to correct pressure.
Old 30th May 2007, 12:58   #15
DieselFan's Avatar
Thanked: 234 Times
I agree with all what Arun has said above. Diesel cars should not be topped up with Diesel. No need to jack up the car just have the tire pressure of 1 or 2 PSI more than the recommended pressure.
I have left my car for over 3 months multiple times and that has not affected my car at all. Even my battery lasted for 6 years (Can you beleive it).
DieselFan is offline   Reply With Quote
FIAT Punto E+ Diesel - 6 weeks, 4000 kms update KuttappanAbhi Test-Drives & Initial Ownership Reports 42 28th March 2011 12:00
Storing Diesel Verna for 2 months amitwadhwa Technical Stuff 5 28th July 2010 12:21
My Indica V2 Turbo DLX (two weeks, 1000km and 1 service later) teknophobia Test-Drives & Initial Ownership Reports 11 12th August 2008 11:07
Indica Xeta LPG or Indica Turbo Diesel?? nobreaks Hatchbacks 12 1st September 2006 23:29
Could it be in next weeks TOP GEAR?? Shan2nu Shifting gears 1 21st January 2005 15:17
