Old 29th May 2007, 21:17   #1
Thanked: 100 Times
Question Oil consumption after "flushing"
Hi All,
Recently I used flushing oil from ABRO for the first time in my Scorpio (CRDe).
I've used Mobil's Delvac MX after the flushing.Today after checking the oil level,I had to top it up (~ 200 ml).I've done close to 1500 kms after the oil change.
I wanted to know if it is normal for engines to consume some oil after flushing.
If not,has the flushing oil caused any damage this OR there is something else that I need to look into.
Thanks,
rb2399
rb2399 is offline   Reply With Quote
Old 29th May 2007, 21:23   #2
theMAG's Avatar
Thanked: 1,572 Times
Flushing removes the oil from places with minute clearances as well. So when the new oil is filled for the first time it fills up all these nooks and crannies. Unless you see oil leaked where you car was parked or the oil's leaking into the combustion chamber to get burnt with the fuel, there shouldnt be too much a cause for concern
Coolent Flushing.. humm Technical Stuff 1 10th October 2008 00:20
Second gen Gypsy (1000cc) compression ratio & oil consumption question xxaarraa Technical Stuff 1 19th November 2007 21:38
Oil consumption in a Baleno Floyd de Souza Technical Stuff 11 15th July 2007 16:55
