Thread Tools
Old 30th May 2007, 12:39   #1 (permalink)
DCEite's Avatar
Default Tyre puncture. No feedback from car.
Today while coming to office i had to deal with a punctured tyre. When i started from home, i did feel a lag, but the lag was very very minimal. I thought it was just because of the ac that i felt the car a little sluggish. The car(WR) has radial tyres.
But only after travelling for about 8 kms someone in the traffic pointed out to the tyre. I was really suprised to see the rear tyre punctured. I felt absolutely negligible feedback.
Does it happen with any of you. My 800 with non radial tyres used to give me so much feedback that it almost refused to move forward with a flat tyre.
Has that something to do with radial tyres? Its not even tubeless..
DCEite is offline   Reply With Quote
Old 30th May 2007, 12:41   #2 (permalink)
amtak's Avatar
which car is WR? Could you please help on this!
__________________
E V O L V E D!
amtak is offline   Reply With Quote
Old 30th May 2007, 12:44   #3 (permalink)
bottle's Avatar
was it the rear tyre ? last time once i had a puncture in zen but didnt notice for a while .. its only at low speeds i guess you feel some pulling etc
bottle is online now   Reply With Quote
Old 30th May 2007, 12:45   #4 (permalink)
iraghava's Avatar
This puncture was on a rear wheel yes? And the 800 punctures were usually on the front wheels?
__________________
There is a very fine line between "Hobby" and "Mental Illness".
Old 30th May 2007, 12:48   #5 (permalink)
DCEite's Avatar
Yes rear wheel.
Dont remember the 800 punctures, but it gives so much feedback that you know instantly that the tyre is punctured.
@Amtak its a wagonR
Old 30th May 2007, 12:48   #6 (permalink)
My car had a flat rear tyre in city limits and I did not get any feedback. Just as in your case, some autowalla pointed to me that the rear right tyre has gone flat. I did not feel a thing. For the records, I drive Palio 1.2 NV.
__________________
Deepak Honnalli.
deepakhon is offline   Reply With Quote
Old 30th May 2007, 12:50   #7 (permalink)
DieselFan's Avatar
rear tire punctures are difficult to detect as the rear of the car is usually loaded less. If you are driving alone most of the car weight is taken by the two front tires (Most of the car weight is under the hood). Hence rear tires are less prone to puncture too. Also damage on the tire and tube because of driving on a punctured tube is minimal if it happens on the rear wheel. Hope this answers your question.
DieselFan is offline   Reply With Quote
Old 30th May 2007, 12:51   #8 (permalink)
HellwratH's Avatar
Yep, I have faced the same problem with my Wagon-R and the situation was similar. The puncture was on the rear tyre and I drove for almost 4 kms and someone pointed out. But the worst part is, the nail was still on the tyre and had to face problem of multiple punctures on the tube.. :(
HellwratH is offline   Reply With Quote
Old 30th May 2007, 12:55   #9 (permalink)
iraghava's Avatar
Originally Posted by DCEite View Post
Yes rear wheel.
That explains. See what happens is, in a car with a single person it it there is hardly any load over the rear suspension so when you get a puncture in the rear two it's hard to feel in any car let it be a WR or any other. In a front puncture it is much easier to detect since the car starts pulling to one side. However, if your car is fully loaded & you get a puncture in the rear you'll get to know very soon.
As for the M800 vs WR comparison, can't say much been too long since I drove them last.
__________________
Old 30th May 2007, 12:55   #10 (permalink)
sivadas's Avatar
Tubeless behaves that way. But you get relatively less feed back from rear puncture any way (assume that you were not having any body in the back seat).
sivadas is offline   Reply With Quote
Old 30th May 2007, 13:14   #11 (permalink)
extreme_torque's Avatar
Even I had a puncture few days back and I drove till the office. After I came back to leave office did I saw the puncture. Unfortunately the tube had been screwed, I got no feedback at all while driving. Mine is a Palio 1.2 ELX.
extreme_torque is offline   Reply With Quote
Old 30th May 2007, 13:20   #12 (permalink)
abhilashvk's Avatar
I failed to notice the drag which was very negligible when I was driving my friends Santro in the Bangalore City. The puncture was on the rear left tyre. Also I failed to notice the power in my Accent CRDi on Mysore road when the rear left tyre punctured, however after a few Kms I could feel slight vibration thats when i stopped the car to inspect. Both the cases I had to change the tube and sides of the tyre were worn out.
Now I decided to replace my car tyres to tubeless cos I drive Bangalore - Calicut in the night and I dont want a flat in the middle of the night inside Bandipur forest...with all those wild elephants around!!!
__________________
Abhi
Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves.
abhilashvk is offline   Reply With Quote
Old 30th May 2007, 13:25   #13 (permalink)
anonymous's Avatar
Its quite normal and happened with me 3/4 times. When you are the only person in the car and rear tyre gets punctured, its very difficult. In fact I have seen few people driving their car with rear tyre punctured and there are 3/4 people in the car, I used to shout them or indicate them about the tyre. Some people understand it and some simply ignore me.
anonymous is offline   Reply With Quote
Old 30th May 2007, 13:26   #14 (permalink)
suren181's Avatar
Ditto problem for me too... on my Santro i.e.. Has happened to me on my earlier Tubed tyres many times. Fully laden on the highway, a rear tyre has a puncture and it has someone to point me out to my predicament and there was no feedback in the car. In the city in a couple of occassions, rear tyres again and would know when pointed out or only after I roll to a stop. The tubeless tyres however have let me down just once in their 15600kms service and was while I was taking the car out of the parking in the morning. Hence no idea as to the feedback or feel that the tyre is punctured.
suren181 is offline   Reply With Quote
Old 30th May 2007, 13:29   #15 (permalink)
n_aditya's Avatar
happened to me one when i was drivin to blore late in the evening.
The rear left tire (tubetype JK Ultima) was punctured and a biker noticed and informed me within few mins (lucky me). the tire was not damaged in any way... phew!!!
I did not feel a thing even though the car was loaded with people in the rear seats and some articles in the trunk.
Now i have shifted to tubeless michelin's and yet i check the tires visually everyday. any tips guys? how do we figure out a puncture in such scenario's as above?
__________________
RIP Tootie !!! Missing you terribly.
Thread Tools
DIY Guide: How to repair a Tubeless tyre puncture! iraghava Tyre & Alloy wheel Section 35 12th October 2008 15:32
Tricks Puncture/Tyre shops play: "Beware of nails on roads" and other experiences team suzuki Street Experiences 42 14th January 2008 15:47
Puncture (tubed tyre) and tyre type/age rex_varghese Tyre & Alloy wheel Section 2 13th November 2007 19:19
Any feedback on this tyre sealant system with compressor? deepakvrao Technical Stuff 0 16th August 2007 00:08
Sidewall puncture in tubeless tyre naveendhyani Tyre & Alloy wheel Section 15 9th January 2007 14:13
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
