Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
LinkBack Thread Tools
Old 30th May 2007, 15:06   #1 (permalink)
aNiLdEv's Avatar
Arrow Baleno Camshaft Position Sensor - Inherent Flaw??
Hi T-BHPians,
It was only a few days back that I came across this post which would have really helped me had I found it earlier...
http://www.team-bhp.com/forum/techni...s-daytime.html (Problem with my Baleno after I run it for 10 kms in daytime)
Well, I faced exactly the same problem with my Baleno a month ago.
Let me explain the problem in detail so that Baleno enthusiasts/experts can throw some light on this problem which I suspect is an inherent flaw. Here goes the full action-packed thriller story...
I stay very close (3.5 kms to be precise) to my office in Electronics City so as to avoid commuting up and down the busy Hosur Road every day. But as Friday creeps in, I pack up my bags and head to the much greener side of Bangalore to spend the weekend with my friends. A few weeks back, I was driving (like a snail) to my friend's place on a friday evening. It's a 15 km drive to his door step and takes around 1 hour 30 minutes to reach there, thanks to the traffic. On this day, after I covered around 7-8 kms, I started getting a jerk from the engine. Initially I thought I was in the wrong gear for this speed. I confirmed it was the right gear but still the jerk was coming and then started losing power. In between I noticed that the Engine Malfunction Indicator was on which was really a bad sign. The vehicles behind me were honking so badly that I had to race the engine and make way for them. Believe me, the tacho showed 3500 rpm but I was still not getting a feeling of power. In another 2 minutes, the jerk was gone and everything seemed to be normal but for the Malfunction Indicator which was still glowing. I reached home safe but had a sleepless night
The very next day, I took the vehicle to the service center (Green Cars). To my surprise, they were not having the right equipments to diagnose the problem and so asked me 3 days time. I didn't have the patience nor the confidence in them, so headed straight to Suraksha Car Care. The mechanic explained me the probable causes and then fitted the scan tool (Tech 2) to diagnose the problem. Strangely, the tool did not detect any problems, all the sensors were working perfect. He then told me it could be due to a loose connection with any of the sensors. All the sensors were removed and fitted again ensuring the wiring harness was also intact. I felt relieved and went home happy. The mechanic did not charge me a single penny as well.
The weekend was over and it was time to get back to work. On Monday morning, with a bit of hangover, I headed for the office. It was 9:30 AM and the traffic was piling up slowly, I was not in a hurry though. I was almost reaching Electronics City when I started getting the jerk again. Disappointing, but not knowing what to do I pulled over the service road. I didn't want to run the car in this condition anymore because I read in the owner's manual the previous day that if the Malfunction Indicator still glows after the engine starts, it is not advisable to run the car. I called up the mechanic immediately and told him my concerns. He asked me to take the vehicle to their branch in Electronics City. I told them the whole story and the proposed a new idea. They would fit Tech 2 (scan tool) and then run the car till they get encounter the jerk. I wished them good luck and handed over the keys and hurried to office.
By afternoon, I got a call from the service centre. They had diagnosed the problem. It was a faulty Camshaft Position Sensor that was the culprit. But why?? The problem occurs only after running for about 8 kms or 45 minutes in peak traffic conditions. I got the sensor replaced (Rs. 2K) and now everything seems perfect. But, nobody could tell me why this occured. The mechanic too didn't have a proper answer and I attributed the issue as an old-age symptom for the sensor.
After having read a post here on the same topic, I am so eager to know more on this. Is this really a faulty sensor or something to do with the ECM which resulted in damaging the sensor?
Please pour in your thoughts/understanding on this.
Thanks,
Anil Dev
__________________
There is more to life than increasing its speed!
aNiLdEv is offline   Reply With Quote
Old 31st May 2007, 17:14   #2 (permalink)
rdkarthik's Avatar
Possible. One of my friends baleno had a camshaft sensor failure too. On a 2yr old car.
rdkarthik is offline   Reply With Quote
Old 28th June 2009, 11:28   #3 (permalink)
Default Simliar problem
I had a simiarl problem with my Baleno and took it to the workshop atleast 4 times in the last 6 months. Each time they woudl do something and the malfunction indicator would stop glowing.
But this Friday I insited they get teh Tech 2 along fit it in the car and then drive. They did so an observed the error, some code 18 and 19. They attributed the proble to some earthing wire issues and rectified.
I took it for a road test y'day and got the issue again. This time the Tech 2 showed and ECD sensor failure. So they replace that with a stansby they had and again the roda test - but this time aroudn the error occured again with a different code.
So i have left them to figure out what is the problem. They said would get back to me by this monday.
Note: although the malfucntion indicator glow I hae not experienced noticale problem with pickup or greaing. One other think that I noticed is that the Fan (coolent fan) has not been kicking in always - nto sure if that could be the problem too.
Shall keep you guys posted on what happens - any pointers/help is much appreciated.
Note from Mod : Please take the time to re-read your post for typos and spelling errors before submitting. Some browsers like FireFox also provide an in-line spellcheck feature which could be worth using. Thanks.
Last edited by Rehaan : 1st July 2009 at 12:39. Reason: Please take a look at the note that has been placed at the bottom of your post.
samnemani is offline   Reply With Quote
Old 29th July 2009, 15:22   #4 (permalink)
Did you trace the problem? Interested, since this describes a new type of malfunction. Please update.
__________________
Baleno Vxi 05
Ritz Zxi 09
filcord is offline   Reply With Quote
Old 26th October 2009, 09:47   #5 (permalink)
Default Problem identified and fixed
Hi All,
First up apologies for the typo errors in my earlier post.
The problem recurred a few weeks ago and I gave my car to Varun Motors in Begumpet, Hyderabard. This time I gave for a normal service and also told them about the MIL (Malfunction Indicator Lamp) glowing continuously. They kept the vehicle for 3 days and test drove it for abt 100 - 110 kms to zero down on the problem. It was identifeid to be a problem with the ECT Sensor (Engine Coolent Temperature). The problem with this sensor also causes the raditor fan not to startup up and stop as desired.
They replaced the ECT sensor and I am not seeing the problem for the last few days. Will post an update after a longer run and more running in.
One symptom for an issue with the ECT sensor is that the raditor fan does not start and stop regulary or as desired - if you observe that and also see the MIL glowing continuously, then the it could be a problem with the ECT sensor.
Hope this helps.
Old 29th October 2009, 15:47   #6 (permalink)
Thanks mate. glad to know this was a one-off. Let us know if the fix has lasted.
__________________
Baleno Vxi 05
Ritz Zxi 09
Old 29th October 2009, 16:40   #7 (permalink)
Originally Posted by samnemani View Post
Hi All,
Hope this helps.
I think if you would have mentioned the radiator fan not running. The issue would have been plain as a day to identify.
arunmur is offline   Reply With Quote
Old 29th October 2009, 18:20   #8 (permalink)
DRC
DRC's Avatar
cam position sensor and crank shaft position/TDC sensor are basically hall effect sensors casted in specific shapes to fit the mechanicals.
Most common failure modes for these sensors are bias voltage and temperature. both are likely in a cars engine bay.
__________________
_____________________
2004 Fiat Petra 1.6, 100 16V
2008 Suzuki swift ZXi
DRC is offline   Reply With Quote
Old 31st October 2009, 07:33   #9 (permalink)
My baleno is having occasional start up problem. It refuses to crank even though the battery is fine. I have to start the car in 2nd gear then the problem will not recur for the next few days. Does anybody have this problem? Is this due to any sensor issue or wiring problems? Actually i do not trust the MASS as the quality of work i got is really bad during last service and i had to lodge a complaint to maruti. Please help me.
__________________
Baleno LXI BSiii 2006 185/65/R14 GT3 Alloys
Wagon R Lxi 2007
Tvs Star City 2006
premdiv is offline   Reply With Quote
Old 2nd November 2009, 08:06   #10 (permalink)
Originally Posted by premdiv View Post
My baleno is having occasional start up problem. It refuses to crank even though the battery is fine. I have to start the car in 2nd gear then the problem will not recur for the next few days....
Sounds like starter motor problems. Get it serviced soon, don't start the car in 2nd gear!
__________________
Baleno Vxi 05
Ritz Zxi 09
Thread Tools
Cam Sensor-Crank Sensor-TDC Sensor. Are They The Same Thing? genesis Technical Stuff 8 5th October 2009 11:17
Does Unicorn have an inherent problem of stability? saleem_k Motorbikes 19 14th May 2009 11:41
1971 Triumph STAG Camshaft cover Gasket tsk1979 Post-1950 15 27th November 2008 16:56
wanted camshaft Cyrus43 Shifting gears 0 16th September 2007 13:05
Powered by vBulletin
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2000 - 2010, Team-BHP.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652
