Closed Thread
Old 14th April 2004, 21:05   #1
hey guys
my zen lost all its pickup esp wen AC is on ....... i got the decarbonizing done,carburator adjusted etc etc.............. it has chocked 96000+odd kms done. *it did not improve after all this.............. can any one give suggestions reg this
ravi
ravi_28_8 is offline
Old 15th April 2004, 02:09   #2
Hi
i also use a zen, which has done 1,70,000.km.I had also faced such type of problem after 1lackm.The car could not idle the average had also fallen to8to9km on the highway.But after detecting the problem it was with the return valve in the carb.But after changing the part it gives 15to17km on the highway with ac on.So please check the carb of ur zen.
santosh2322 is offline
Old 15th April 2004, 13:13   #3
Thanked: 89,258 Times
Ravi,
I dont know of the maintainence schedules that you have followed for your Zen, and therefore cant gauge if the engine is due for a piston/ring replacement. But do get a cylinder compression test done.
Else, it may be a carb setting thing.
GTO is offline
Old 15th April 2004, 19:24   #4
hi all
thanks gto and santosh for ur sugestions. car was given to servicing regularly. oils were changed time to time. technical guys say that compression is weak and it is common. i complain abt millage and they say it will improve but it never did. it returns me 10 with ac. i got frustated n got it gas converted 1 month back........ it is working good and costing me 1.8 to 2Rs/km as compaired to 3.8/km........
i dont know how good was my decision, but with this iam not burnning my pocket as of now.....
plz suggest me with any options.
once again thanks
regards
ravi
Old 16th April 2012, 15:39   #5
vzamindar's Avatar
Default Re: Zen lost its Kick
Did you check the timing?
Has this appeared after doing a particular service or changing a particular part or did it just happen gradually?
The compression can also be lost because of bad piston rings.
vzamindar is offline
Old 16th April 2012, 16:05   #6
invincible7's Avatar
Thanked: 131 Times
This topic is 8 yrs old dude.
invincible7 is offline   (2) Thanks
Closed Thread
2011 i10 Asta A/T - its Korean, its new, its fast, its red, and its coming. nirupesh Test-Drives & Initial Ownership Reports 1 8th January 2011 10:45
Its a bird....Its a plane...Its our Cycleman WhiteKnight Street Experiences 15 3rd September 2008 19:21
Please Guide Us: How to stop a car that has lost its brakes dhananjay Technical Stuff 32 8th September 2006 12:10
Kick Ass Setup... lancer_mania In-Car Entertainment 39 24th February 2006 21:43
hey...im new, im lost and i need help with my zen!!! ghostrider4385 Technical Stuff 36 22nd December 2005 15:15
