Old 30th May 2007, 19:35   #1
sumeethaldankar's Avatar
Thanked: 1,160 Times
Default M800 -Wheel Problem
Hi guy i have 97 m800 carb engine.I have been experiencing a problem whose cause i am unable to identify.whilst driving in 1st tww gear especially while accelerating i notice a tug at the front left wheel.I had the cv joint boots replaced on both sides.Still the problem occurs.I have noticed that the problem seems to be less when the tyres have been properly inflated.Could the drive shaft be at fault?
Has anyone faced a similiar problem.Also wanted to know wheter having a high idle speed will affect FE of the car.
thanks
sumeethaldankar is offline   Reply With Quote
Old 31st May 2007, 07:33   #2
mithun's Avatar
Thanked: 59 Times
Have you checked the wheel alignment/balancing lately?
Having a high idle RPM will surely affect the FE, but not much ?
Old 31st May 2007, 15:32   #3
Hi had it done but problem still persists.
Old 31st May 2007, 17:15   #4
risga's Avatar
Thanked: 46 Times
@mithun
Can you provide more details as to when you first noticed this? What kind of tyres you are using - radials or cross-ply? Do they have the same wear & tear? Any visit to the service centre recently? How is the suspension - have you got a overhaul done given the age of your car?
Answer to these questions might help in diagnosing the problem.
risga is offline   Reply With Quote
Old 31st May 2007, 17:46   #5
Hi
i have MRZ Zigma radials on all 4's.I had overhauled the bushings of the suspension but still the problem persist.Also the tyres have not worn out and are in good condition.The problem occurs when i press the accelerator in 1 or second gear the wheel seems to be tugged at with a dull thud sound.
Old 25th June 2007, 19:21   #6
fiery enzyme's Avatar
Thanked: 23 Times
Hey I have an 800 and it too seems too be suffering from a similar problem.
In first or second gear there is a lurch when you accelerate like the wheel and chassis are not firmly fixed like how when in a train if the engine pills the carriages move with a lurch. Is it a suspension problem..
Guys help me out too.
fiery enzyme is offline   Reply With Quote
Old 26th June 2007, 10:54   #7
risga's Avatar
Thanked: 46 Times
Seems to be a suspension issue. The rubber bushes are worn out and would need to be replaced. Suggest you get the car inspected and get suspension overhauled.
Old 26th June 2007, 13:12   #8
Jaggu's Avatar
Thanked: 8,693 Times
engine and gear box mounts if its thud sound
Old 26th June 2007, 18:52   #9
Thanked: 23 Times
Thanks for the info guys will get my suspension and mounts checked.
BTW I want to upgrade to 165/60R12 71H form my stock 145/70R12 69S.
Will this affect the ground clearance as already my car has an untolerant clearance?
M800 problem sidharth_j Technical Stuff 32 18th January 2008 19:04
Low rev problem in M800 (Carb Model - 1996) Jeep Technical Stuff 2 29th November 2007 17:44
Wheel spacer for M800? Sankar Tyre & Alloy wheel Section 26 9th November 2007 17:44
AC problem in M800 humyum Technical Stuff 6 20th August 2007 18:27
m800 vs ikon (what comp can a M800 be?) manaa45 Street Experiences 13 31st March 2005 12:06
