Old 10th June 2007, 22:57   #31
Alfa_Kilo's Avatar
Originally Posted by BikerSG View Post
4WD vehicles are not immune to getting stuck. They are just better at handling slippery conditions than 2WD vehicles.
When handling any condition, it is best to get out of the vehicle, plot a route and drive accordingly.
When driving on sand, you have to have wide tyres and also reduce your tyre pressure. Use of the brakes is also very important. Have given an example below using a 2WD drive vehicle. Same principle applies to 4WD also.
In case you get stuck in a 2WD vehicle where only 1 wheel is spinning, let the engine idle in 1st gear with clutch out. The wheel which is capable of traction will not spin as all the power gets transferred to the wheel with no grip (thats why the 1 wheel starts spinning). slowly apply the brake to reduce the amount of power going to the spinning wheel. At one point of time, the wheel which has grip (the one which is not spinning) will start moving, and help in getting the car out. This will of course work only if the wheel which is not spinning, is not on some slippery surface.
The important thing to remember is to do this slowly. If required you shud accelerate also while braking. This is for FWD vehicles. For RWD vehicles, use the handbrake instead of the brake.
This works with torque biased Torsen LSDs. Its barely effective on open diffs and conventional LSDs.
Alfa_Kilo is offline   Reply With Quote
Old 11th June 2007, 11:17   #32
BikerSG's Avatar
Thanked: 12 Times
actually, for cars with LSD, this is not required.
LSD does all the work without you haveing to use the brake to transfer power to the non-spinning wheel.
BikerSG is offline   Reply With Quote
Old 18th June 2007, 15:33   #33
Alfa_Kilo's Avatar
Read up on Torsen diffs.
Old 2nd December 2007, 13:59   #34
NIP
NIP's Avatar
Thanked: 94 Times
i have got stuck badly on the mahabalipuram beach in my gypsy king. the more you gas, the more it digs in. we ran the gyp on wet sand and on the waters edge without trouble, but where the sand is dry and loose, its all over !
but i also found it safe to drive on sand thats covered with weed or grass...i did this last week near auroville in pondy in my scorp. no issues:
NIP is offline   Reply With Quote
Old 3rd December 2007, 19:16   #35
Lukeskywalker's Avatar
Thanked: 1,170 Times
Tried this on a beach in Langkawi with a Proton Wira (hired), luckily did not get stuck, did some good spins and when the sand started getting deeper and deeper called it a day.
But the experience was not at all as thrilling as I expected it would be.
Lukeskywalker is offline   Reply With Quote
Old 3rd December 2007, 20:02   #36
im_srini's Avatar
Thanked: 398 Times
Hi, in my opinion the stock tires our cars are shod with are too narrow to afford romps in the sand. I've tried the brake technique, where one applies the brakes, transferring torque away from a free-spinning wheel to one that is 'stuck'. When I tried it, the car just dug itself deeper into the sand ! Rocking the car works, plus reverse in some cars is geared down more than first.
I have a friend who likes to experiment. Confronted one day with SUVs playing on the beach, he figured that the sand should pose no issues to his all-wheel drive TT. Told me that he had to pay an obscene amount to a guy in an Explorer to winch him out
im_srini is offline   Reply With Quote
Old 3rd December 2007, 21:25   #37
Thanked: 191 Times
Is this Scorpio a 2-wheel or 4-wheel drive?
Murugan is offline   Reply With Quote
Old 4th December 2007, 16:12   #38
NIP
NIP's Avatar
Thanked: 94 Times
its a 2WD scorpio
Old 7th June 2008, 11:55   #39
vinod_nookala's Avatar
Thanked: 416 Times
Never try beach driving on a 2wd. Just for the fun of it, i tried in 2wd and the vehicle dint move even a bit when i hit sand.I had to engage 4wd. 4wd is essential on sand. Once had to pull out a LSD equipped MM550 (with 4wd not in working condition) with my 4wd jeep. You need power going to all wheels on loose sand.
vinod_nookala is offline   Reply With Quote
Driving directions for Tarkarli beach, Maharashtra, Mumbai kadwad Route / Travel Queries 7 30th September 2015 17:31
Lakshadweep: The ship, the sand and the beach SwatiS Travelogues 39 3rd August 2015 12:23
Vizag: any beach resorts or beach guesthouse? romyeo4u Route / Travel Queries 4 19th March 2009 03:41
Caution reqd. for driving on Palm Beach Road, Navi Mumbai emkay456 Street Experiences 10 14th December 2006 12:30
the sand in my shorts Sam Introduce yourself 5 29th March 2004 00:09
