Old 31st May 2007, 11:53   #1
Default Speedo and Odo stopped all of a sudden
Hi guys,
Today as usual I started my car for office. I have a 2000 Zen.
After driving abt 5 to 6 kms I noticed my speedo does not work even though the car was going at 50-60 km/hr. Also the odometer has stopped and it does not go forward.
Any idea what might be the reason.
Waiting for replies before taking the car to the workshop.
Thanks and regards,
Kamat
kamat2004 is offline   Reply With Quote
Old 31st May 2007, 17:06   #2
risga's Avatar
Thanked: 46 Times
There is a cable which connects to the odometer, which is likely to have snapped. A replacement should do the trick.
risga is offline   Reply With Quote
Old 31st May 2007, 18:14   #3
esteem_lover's Avatar
Thanked: 451 Times
check the speedo cable kamat2004, nothing else is wrong
Old 4th June 2007, 13:41   #4
Thanks Guys,
I went to the maruti workshop yesterday. They checked fot the cable and put a new one also ...but it did not solve the problem.
According to them ...it has to do something with the gear box. They said some plastic part which connects to speedo/odometer might be the problem. They have asked me to come by Friday. Guys what do you think might be the problem.'
Kamat
Old 4th June 2007, 14:19   #5
Kamat,
If they are referring the worm which turns the speedo cable then they are right, in my opinion there should not be anything wrong with the gear box
kiranpashtakar is offline   Reply With Quote
Old 4th June 2007, 16:53   #6
Jaggu's Avatar
Thanked: 8,682 Times
yup i think kiran is correct the speedo worm might be the issue
2007 Indica Xeta: Engine losing power all of a sudden and regaining power after mins mohandas Technical Stuff 17 3rd May 2016 07:37
Swift : Sudden Surge in Power during accl and Kut kut sound at Braking lambuhere1 Technical Stuff 7 10th November 2009 15:01
my speedo ended !!!- zen needle crosses last point on speedo speed0mania Street Experiences 81 11th August 2006 12:22
Non-functioning speedo and Tacho Deeps Technical Stuff 1 3rd October 2005 12:10
speedo & odo error chandan Tyre & Alloy wheel Section 5 22nd July 2005 01:04
