Closed Thread
Old 31st May 2007, 14:37   #1
Tharamal's Avatar
Exclamation Impact of cruising on neutral!
Hi folks,
There are times, specifically while driving along the larger roads/highways, that when you are cruising along at a good speed and see a crossing or a stop ahead, I put the gear into neutral and let is continue to glide till the point of braking.
Does this affect the engine in any way? I tend to do this even in city driving, when you see a traffic signal looming ahead and push the gear into neutral and let the vehicle glide on till the need to brake!!
Views/feedback on this habit please.
Tharamal is offline
Old 31st May 2007, 16:28   #2
ghostrider4385's Avatar
Thanked: 7 Times
I'm sure this topic has been discussed before. And if I remember right, that's not a very bright thing to do.
1. Brakes tend to be less effective when applied in neutral, in comparision to when you brake in gear. In other words, can prove dangerous if you are cruising in neutral and something darts across the road, as is common in India.
2. Brake pads (I think) tend to fade at a greater rate when regularly used in neutral.
ghostrider4385 is offline
Old 31st May 2007, 16:49   #3
tsk1979's Avatar
Thanked: 16,420 Times
Note from mod: Thread closed, please use search function before posting
tsk1979 is offline
Closed Thread
Shifting to Neutral or Pressing the Clutch when Braking - Is this right? netarchie Technical Stuff 412 2nd June 2016 22:18
Switch off / Park in first gear or neutral? devnull Technical Stuff 49 18th December 2015 16:57
Santro gear shifts suddenly into neutral nura Technical Stuff 18 11th August 2008 14:21
Gear slipping to neutral? - Wagon R johy Technical Stuff 32 25th March 2008 19:01
Re: Gear "jumping" to neutral??? johy Technical Stuff 9 9th November 2006 21:45
