Old 31st May 2007, 17:21   #1
gopz's Avatar
Default Better battery for M800?
Anyone knows if we can do any mods and fit a bigger battery in a M800? I heard that a Honda City battery can be fit with slight modifications? What are the pros and cons?
gopz is offline   Reply With Quote
Old 31st May 2007, 17:36   #2
risga's Avatar
Thanked: 46 Times
Sure, it can be done. You just need to be able to fit a larger battery inside. Why would you like to do this?
Pros - if you are having lots of electrical accessories, then it would possibly help
Cons - cant think of any
risga is offline   Reply With Quote
Old 1st June 2007, 13:55   #3
gopz's Avatar
Originally Posted by risga View Post
Well I have 2 amplifiers, 1 subwoofer, 100/90 halogens and A/C is on most of the times, so I was advised for a bigger battery because my engine doesnt crank sometimes (I currently have a 1 year old Exide battery). The battery guys said that my battery is fine but the load is high so it doesnt crank sometimes.
Which battery should I go in for?
Old 1st June 2007, 14:44   #4
Pankaj401's Avatar
You should probably switch off all electrical accessories while cranking. That should help.
Pankaj401 is offline   Reply With Quote
Old 1st June 2007, 14:45   #5
Thanked: 11 Times
Which amps and sub do you have ?
Right now how much amp battery do you have ?
Just check the width,length and height and than ask battery dealer to give you battery with more amp capacity but same size.
Mugen_Power is offline   Reply With Quote
Old 1st June 2007, 14:51   #6
gopz's Avatar
I currently have 35amp Exide battery, the dealer told me that I can go in for Honda City's battery (45 amps) with a slight modification to the 'battery holder box'
he said it would cost 5.5k. will it really help me?
Old 1st June 2007, 14:52   #7
risga's Avatar
Thanked: 46 Times
With so much of electrical load, you will need to invest in an alternator with larger capacity too, as I feel your existing alternator cannot take the electrical load and be able to charge the battery.
Why dont you reduce the un-necessary load?
Old 1st June 2007, 15:10   #8
Thanked: 11 Times
5.5k for 45 amp battery and holder modification ? there is no need to change the alternator.
Old 1st June 2007, 22:21   #9
gopz's Avatar
Yeah, 5.5K for Exide batt (B&W) and also holder modification. Can I go in for it?
Old 1st June 2007, 23:06   #10
Thanked: 11 Times
Which 45 amp model ? What is the prize of current 35 amp battery ?
if you can reduce the load than do not spend for battery.
Old 1st June 2007, 23:58   #11
veyron1's Avatar
Thanked: 38 Times
Heard of Amaron? That "last-long-really-long" jig ain't for fun. It's actually true.
Go for an Amaron ultra (48 month warranty). 45 amps should be fine, although with the accessories that you mentioned, you'd probably require 50. Alternator change isn't required, unless you run all your accessories with the engine off, frequently.
First off, is yours an MPFi? If yes, be careful about cranking the engine with a weak battery. Not good.
veyron1 is offline   Reply With Quote
Old 2nd June 2007, 00:10   #12
noidaboy's Avatar
Thanked: 260 Times
i have 800 also,i have got my battery replaced 4months back with a 40-45amp exide which is working great it costed me around 4000 and only thing i had to change was the terminals,rest all is working great
noidaboy is offline   Reply With Quote
Old 3rd June 2007, 16:14   #13
gopz's Avatar
Yes, mine is an MPFI car. I will check out the Amaron..thank you!
Old 28th December 2007, 11:48   #14
gopz's Avatar
I am planning to get a better battery this weekend. Any suggestions on which model I should buy? 45 amp or 55 amp? Exide or Amaron or Panasonic?
Old 28th December 2007, 11:55   #15
Ajaybiz's Avatar
Thanked: 141 Times
Upgrade from 35 to 45 amp is not good better go for 50-60 amps and Amaron is best bat.
Ajaybiz is offline   Reply With Quote
Battery question - Can I use Indica Spec Battery in Scorpio, or other such swaps? shekharlele Technical Stuff 18 7th September 2010 09:05
Fog lamps for M800. Battery upgrade required? ssengo Technical Stuff 8 13th April 2010 10:16
Using a battery tender to revive discharged battery xxaarraa Technical Stuff 2 14th May 2008 19:56
m800 vs ikon (what comp can a M800 be?) manaa45 Street Experiences 13 31st March 2005 12:06
