Old 3rd June 2007, 12:44   #1
Default scorpio braking issue
guys yesterday when i was crusing at 80km/h when i pressed the breaks the breaks became hard for a moment...what might be the reason.
i observed that if i press the break only once its working fine but when i press the break 2 to 3 times at the same time its becomming hard.
what might be he reason guys.....
zenopio is offline   Reply With Quote
Old 3rd June 2007, 13:02   #2
kpzen's Avatar
Thanked: 1,598 Times
Why are u breaking your Scorpio instead of braking???
Old 3rd June 2007, 13:04   #3
hehehe ...i was braking only... mods please change the title to scorpios braking issues
Old 3rd June 2007, 13:37   #4
humyum's Avatar
Thanked: 2,188 Times
Might be a vaccume leak in the brake booster.For first time there must be enough pressure for the workin of the brake booster but durin the 2nd and third application due to the leak it might not be able to generate enough pressure for smooth operation
Old 3rd June 2007, 13:40   #5
I think guess that the brakes would had regained its bite after you down shifted?
Anyway,it is the brake booster problem and is due for a replacement. When the diaphragm(Booster) has worn out hence it does not create enough vaccum for repeated braking, however on facing such a situation suddenly,it is recommended to downshift to the lowest gear(say 4th to 2nd) possible,here you will find brakes pressure coming back.
But as i said please have your brake booster checked
Desert fox is offline   Reply With Quote
Old 3rd June 2007, 13:43   #6
madhav's Avatar
Thanked: 15 Times
I had the same problem with my truck and it was because of the booster. I had to get the booster and the master cylinder replaced... but it was done FOC as it was covered under warranty!
madhav is offline   Reply With Quote
Old 3rd June 2007, 13:43   #7
planet_rocker's Avatar
Thanked: 365 Times
IMO...i have observed this in my car as well. you are basically pumping the brakes and hence more fluid is pumped. this makes the brake paddle hard and braking is more effective. this also allows you to control locking up the wheels just as ABS i guess.
planet_rocker is offline   Reply With Quote
Old 3rd June 2007, 21:01   #8
Its a booster issue and quite common on Scorpio, the one I drove in Calcutta needed double pedalling constantly to give any sort of braking, don't take it lightly, it could lead to dangerous situations, one that could be fatal, have it rectified ASAP by the dealer.
Gurkha is offline   Reply With Quote
Pulsar 220 F inadequate rear braking issue! makanaka Motorbikes 20 2nd June 2017 13:51
Suzuki Kizashi: Common Steering Vibration Issue when Braking rockporiom Technical Stuff 64 15th January 2014 21:56
Strange Braking issue with the Esteem amohit Technical Stuff 6 9th February 2012 18:00
Major error in Autocar March issue & Overdrive April issue as well Guna Shifting gears 20 11th May 2010 11:15
Braking issue with my Skoda Octavia classic_rider Technical Stuff 2 24th November 2009 19:36
