Old 9th June 2007, 11:31   #31
gd1418's Avatar
Thanked: 655 Times
You did not express your views about the SHELL Rimula..
Originally Posted by Gurkha View Post
Harpreet Lubricants is located in Patel Nagar, Delhi, as soon as you leave Pusa Road and and enter Patel Nagar, after the residences end and first market appears on your left, you will find it there.
Old 9th June 2007, 11:52   #32
Basic diesel oil, nothing spectacular, even the Rotella does OK but not great in UOA, Delo 400 or Delcav are the chaps of HDEO.
Gurkha is offline   Reply With Quote
Old 9th June 2007, 11:56   #33
gd1418's Avatar
Thanked: 655 Times
These abbreviations kill me. My mind goes wild with imagination while deciphering...
What are UOA and HDEO??
BTW, would you be having Harpreet Lubricants contacts?
Old 9th June 2007, 12:07   #34
UOA= Used Oil Analysis
HDEO= Heavy Duty Engine Oil
Sorry, no address of Harpreet Lubricants but follow my directions given and you won't get lost.
Old 9th June 2007, 18:30   #35
tsk1979's Avatar
Thanked: 15,646 Times
I went to khan market to get suspension work done.
Checked out a few shops, not chevrol DELO 400.
But there was a Mobil DELVAC 1 synthetic oil(5W40). It was so expensive that I wanted to run away.
Then there was Mobil DELVAC MX, API-CI4. but it had trucks and tractors drawn on it and said
"Heavy duty commercial diesel engine oil". It was around 900 for 5L
Due to silhouettes of trucks, tractors, mini trucks etc., on this oil I did not purchase it.
So how come this heavy duty oil is different from normal passenger car oil?
Old 9th June 2007, 19:47   #36
Its a multi-fleet oil, don't let the tractors and trucks scare you, diesel C rated oil goes through far more stringent requirements than gas oil, in fact it exceeds the highest specification required for gas oil, if you looked carefully on the container, you would have seen the words multi fleet and suitable for diesel and gas as well as the API gas rating there. Next time don't run, pick one up and start using it, your car will thank you. Delvac-1 is the best synth oil, sadly its quite costly and the justification is extreme use, like -30c and don't think we all will ever get into that kind of predicament, Delvac MX or Delo 400 would do fine for you.
Old 9th June 2007, 22:45   #37
tsk1979's Avatar
Umm, C rated oil is far superior, right, but whats the difference between Delvac MX which says, for commercial vehicles, and Castrol CI-4 GTX diesel which is made for cars.
Both are API-CI4 but one says cars and other says trucks.
Old 9th June 2007, 23:30   #38
kpzen's Avatar
Thanked: 1,598 Times
API-CI4 is a diesel engine oil meeting a set of test parameters. Mobil has major commercial vehicle business in US which is why the delvac says commercial vehicles.
GTX has been Castrol's brand name for passenger cars...
Sulphur in diesel fuel, Lubricity of diesel fuel & & diesel engine oil are three different topics n all getting mixed up here..
Old 10th June 2007, 00:36   #39
tsk1979's Avatar
Well we are looking for a diesel engine oil which will best offset the low lubricity of the LSD sold in India.
Old 10th June 2007, 06:18   #40
Thats because the intended audience in general for HDEO is trucks and commercial vehicles, if you read the label, you will see its rated for cars as well, both diesel and gassers. I have a Swift as well as high mileage Esteem, both belongs to my friends, all are on Delo 400 and also a Toyota Innova. They get excellent results vis a vis oil life, cleanliness of engine, fuel consumption and lower noise in general as compared to other oils.
Old 10th June 2007, 15:15   #41
tsk1979's Avatar
Okay, since Delo 400 is not available, next time I go to khan market I will pick up a 4L can of Delvac MX mineral oil.
It has around 2400ppm detergent level instead of Delo 400(3600ppm) or GTX diesel(1800ppm)
Will STP engine oil treatment mean more detergent in the oil?
Also LSD has poorer detergent qualities, so does it mean high detergent oil will help offset this?
Old 10th June 2007, 15:55   #42
kpzen's Avatar
Lubricity of LSD is tackled by refineries. To the extent i know the required additives are added before marketing the LSD by the Oil companies in India & special tests like HFRR are used to determine lubricity of fuel.
Adding engine oil to a diesel fuel is not a generally an accepted procedure to achieve required lubricity in FI pumps.
AFAIK the Indica V2 the fuel pump is lubricated by the fuel itself & not by a separate engine oil so searching for suitable diesel engine oil to solve the problem of LSD doesn't appear to be a worth while process.
Old 10th June 2007, 18:26   #43
Use additive diesel and add Elf Dalf or STP diesel treatment every third or fourth filling, that will keep the pump happy, for your engine, Delo 400 or Delvac will keep it happy for a long time, Delo 400 is ISOSNYTH and therefore doesn't need higher detergent package of Delvac-MX which is group I oil, either way, no need for the extra buck on STP with these two oils.
Old 10th June 2007, 18:48   #44
tsk1979's Avatar
Huh, who said we are adding engine oil to diesel?
Actually DELO 400 has 3600+ppm detergent, 1100ppm more than the Delvac MX.
Anyways, I will go for Delvac MX on next change
Old 11th June 2007, 09:03   #45
Jomz's Avatar
Thanked: 289 Times
Excusez Moi Senoir... No Engine OiI wiff offset the low lubricity of Indian fuel unless you mix oil with fuel.. the Oil and fuel circuits are completely different in an Engine.. and special care is taken so that Oil and fuel never mix up.
Tell me guys.. How does the so called premium Oils reach the fuel pump which is the only item affected By diesel lubricity???
And eventhough the Suphur content is less nowadays Lubricity is easily taken care of by additives as rightly told by KPZEN
And again. We get 300 ppm Diesel, Europe Gets 50ppm diesel.. Does that mean that the fuel pumps over there are conking off because of lack of lubricity .NO.
Don' t tell itz because of the high grade oil they use because..again the oil doesn't come even near the pump.
IMO this thread is misleading..
Jomz is offline   Reply With Quote
Relocating to Singapore, need information ! any BHPians there? amya Shifting gears 71 4th December 2017 22:12
Yercaud-->Been there, Roamed there and Enjoyed shishir_bn Travelogues 50 8th December 2010 21:25
Hello, is there anybody in there? comfortablynumb Introduce yourself 18 22nd July 2009 15:06
any gypsy's out there revtech Shifting gears 6 23rd February 2005 19:19
R there any "NFS 5" fans out there!!! Shan2nu Shifting gears 71 16th May 2004 16:12
