Old 4th June 2007, 17:21   #1
Question Mahindra Bolero - Low torque in 2nd gear?
My Mahindra Bolero seems to have very low torque in 2nd gear though it pulls well in all other gears. Could you explain me why is so?
THE OFFROADER is offline   Reply With Quote
Old 5th June 2007, 13:27   #2
Thanked: 103,331 Times
Hi offroader
Have you compared it to other Boleros? Do all have the same problem or is it only yours? This will help us in first identifying whether the problem is unique. Or due to the gearing / turbo-lag etc. of the Bolero.
Old 5th June 2007, 15:26   #3
Spitfire's Avatar
Thanked: 707 Times
Which model? Which year? How many kms on the odo? Any recent changes to the engine? overhaul etc?
Spitfire is offline   Reply With Quote
Old 5th June 2007, 16:51   #4
Thanked: 28 Times
I used to have a IDI bolero Sportz till 2005 Aug.
I do not think Bolero has a Turbo/intercooler AOD.
The only upgrade is to a DI engine.
cheers.
PRADEEP KUMAR is offline   Reply With Quote
Old 4th June 2010, 09:15   #5
Thanked: 894 Times
I have faced the same in most Boleros I have driven. I believe it has to do with a combination of the usual RPM, Turbo Lag and Gear Ratios for the Second Gear. I might be off the mark, but someone who knows this more technically, can perhaps explain.
roy_libran is offline   Reply With Quote
Old 5th June 2010, 00:36   #6
Thanked: 660 Times
cheers.
I think, all of them now are turbocharged, except a 4x4 version, which is slx or something that uses IDI X3DP engine
Old 6th June 2010, 22:21   #7
Thanked: 235 Times
I think Turbo didn't exist before the Walrus-toothed model.
So only the walrus DI Boleros have turbos.
-- Torqy
Torqy is offline   Reply With Quote
Old 6th June 2010, 23:40   #8
jeeva's Avatar
Thanked: 558 Times
Towards the end of 2006, XD3P and DI turbos were sold side by side, at least for some time. The DI Boleros always came with turbos from the very beginning.
Mine is a 2006 Bolero Sportz (XD3P) and a Bolero Club friend owns 2006 Bolero Sportz (DI turbo): both of them have the old grille and headlights (not the bunny tooth grille).
jeeva is offline   Reply With Quote
Old 7th June 2010, 01:22   #9
Thanked: 235 Times
Slightly off-topic.
Is the old grill a straight replacement for bunny teeth?
-- Torqy
Old 7th June 2010, 08:29   #10
Thanked: 894 Times
Originally Posted by Torqy View Post
Slightly off-topic.
-- Torqy
That's a million dollar question, eh!
Old 7th June 2010, 09:58   #11
Thanked: 235 Times
I already knocked off the walrus teeth though.
Old 7th June 2010, 10:46   #12
Thanked: 894 Times
Good Job! But, the bottom-line of the entire discussion is, that the Bolero platform has so much potential and the guys at M&M just can't get it right. Some of my key thoughts:
- The 2006 Bolero Sportz Form Factor
- Redesigned Side Steps
- CRDe Engine
- 4x4
- Better Interiors
- Lower NVH
@ Less Than 8 Lac Ex-showroom
Is this asking for too much? The stuff they have been feeding us over the years, is so discouraging, for so encouraging a platform.
Old 7th June 2010, 14:31   #13
josepeter's Avatar
Thanked: 547 Times
Slightly off-topic.
-- Torqy
Yes Yes; In fact you can pull the bunny teeth off the new grill and what you are left with is the old grill + 2 holes
-- Torqy
Its the other way round; the Walrus tooths have only turbos!
Where do I get the Million now?
josepeter is offline   Reply With Quote
Old 7th June 2010, 17:18   #14
Thanked: 235 Times
I think the old grill has a different shape / curvature.
Actually, you'll be left with 4 holes.
I guess enough drifting away from the topic...before the mods notice us.
Bolero VLX Crde 2011, 29k kms done, loss of torque ? shyamk Technical Stuff 12 5th June 2014 09:30
Repeat EXAMM! The ghost of 1st low vs 2nd low descent haunts us again... and how! Tejas@perioimpl 4x4 Excursions 41 23rd September 2010 14:16
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 85 2nd September 2009 18:47
Mod for low end torque in Swift talk2anand Technical Stuff 34 31st October 2006 10:20
giving the Swift some low end torque and fatter wheels theEnd Modifications & Accessories 14 21st November 2005 19:07
