| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Jul 2006 Location: Pune
| Hey guys, I own a 2004 diesel Indica. A couple of questions on some problems I am facing: 1. Recently I observed that at slow speeds the steering wobbles and the car pulls a bit to the left at slow speeds. eg. when I am starting off from a dead stop. The steering feels like the car is going over a bump / pothole. When the car picks up speed, it becomes less. What is the issue? 2. The car has done exactly 3 years and 38K Kms. I have done all the regular servicing at 5K intervals. What are the pre-emptive measures I need to take to keep my car is good order? I read someone mention engine de-carb etc. Please let me know the list of maintenance tasks I need to take up at this point in time to make my car remain good. Thanks in advance. Regards, Kaustubh
__________________ be happy for no reason |
| | #2 (permalink) |
| Team-BHP Moderator ![]() | 1. The Steel belt in your tire is kaput. Change the tyre(exchange front rear). A more serious issue could be problem with the axle/hub. did you hit a bump or a crator at high speed. Inspect rim for bend. If problem goes away by changing tires, then it was a steel belt issue in tire, otherwise damaged axle/hub(Rare), bent rim(less rare) could be culprit. 2. Maintain it regularly, it will be fine. Make sure you do engine flush every 25000kms or so. Oil change interval of 7000kms will do you fine. My indica engine feels great and performance is adequate even at 80K+ kms.
__________________ Reclaiming.....! |
| | #4 (permalink) |
| BHPian | Hi, I had a similar issue with my Indica few months back. It was rectified with balancing and alignment of front wheels.There was a small bend in the rim too. Wobbling was very less (not like going through a bump or pothole). I think you can try this too.
__________________ Swift VDi, May 2007, 30K+ kms |
| | #5 (permalink) |
| Team-BHP Moderator ![]() | Common synthetic oils available for diesel confirm to very old specifications (API-CF). I think mobil 1 is synthetic. I was also recommended Delo 400 (chevron). It has detergent content of 3600+ twice that of Castrol GTX or Castrol GTX diesel(API-CI oil which I use currently). Before this I used to be on Castrol GTD and oil change was done every 6000kms or so. So as long as you stick to or exceed API-CF specifications you should be fine. Get Castrol GTX diesel, and if you are going synthetic I would recommend anything with rating more than API-CH (API-CH4, API-CI4)
| | #7 (permalink) | |
| BHPian | Quote:
Problem 2 - Do company recommended periodic services correctly. Replace E.oil every 5k! Do wheel alignments and balancings every 5k! This will make your steering a bit hard incase yours is a non-powersteering one!! No need for decarbonising till 60k. Tell the mech to check the timing belt every 5k! Full water service every 2.5k will be tooo good! Thatz it! Your car is as good as fresh I guess!! No need of any major repairs at 35K in 3 yrs!! Replace the tyres if it is due. Get the car checked for engine oil / coolant leakages. Get the battery checked! drive on!!
__________________ MISSED the action!!! :-( Guess another one has already started happening!! :-) | |
| | #8 (permalink) |
| Hi guys, Problem fixed. I exchanged the front tyre with the spare wheel and the wobbling stopped completely. Observations: The problem was with a bent rim. Some days back, during parking I had bumped against a footpath. :(. That had caused it. Another thing I noticed is that the tyre was badly damaged. Could the damage be caused because of driving around for 1 week on a bent rim? Thanks for your suggestions guys.
| Thread Tools | |
Similar Threads | ||||
| Tata Indica - List Of Problems | Ferrari1976 | Technical Stuff | 133 | 11th August 2008 23:44 |
| Starting problems Indica DLG | vfmanuel | Technical Stuff | 19 | 13th December 2007 23:09 |
| Pickup problems in My Indica DLS,2005 | KVS | Technical Stuff | 10 | 21st September 2007 19:03 |
| Indica Xeta LPG or Indica Turbo Diesel?? | nobreaks | Hatchbacks | 12 | 1st September 2006 23:29 |
| Any problems with Fiesta 1.4 diesel ?? | tanishq | Sedans | 1 | 10th May 2006 17:17 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
