Old 8th June 2007, 01:37   #16
esteem_lover's Avatar
Thanked: 451 Times
Hey kev, you seem to be more frustrated than the assassin, are you hand in glove ??? LOL. Get the thing fixed man before you have a situation where you have to scoot in reverse.
Many European cars have this safety mechanism so as to avoid any chances of a person engaging a reverse gear accidently when he wanted to move to the 4th gear instead.
And not any have done this in india even after many years, why are the Europeans so paranoid ?
Old 8th June 2007, 02:30   #17
rohitgaur's Avatar
hi
the same part was broken in my car, the time taken to find the white plastic base on the shifter was long , but it took 3 hrs of labour & 1000 odd bucks
for details call me 9315802135
rohitgaur is offline   Reply With Quote
Old 8th June 2007, 11:14   #18
kpzen's Avatar
Thanked: 1,655 Times
John....! Own a F I A T n u'll know.....
Anyways thats not my car either.....
Old 8th June 2007, 11:31   #19
vinodv001's Avatar
Thanked: 105 Times
hi,
You can see the plastic mechanical lock inside the gear lever cover. I think you can try to fix ( lift the lock and hold) it somehow and take to service centre. Thats what i feel on looking at the gera knob of my Palio 1.2 EL.
Its not the plastic ring(for reverse) on the lever which is broken...!!! The lever n clip on it are fine
Somewhere the connection of the nob with the gearbox is broken because now while slotting it in reverse it falls into fourth gear...
Its a Palio 1.2 ELX NV 04 model....
vinodv001 is offline   Reply With Quote
Old 12th June 2007, 06:48   #20
hey, the clip is a safety feature but you can do without it as i ve intentionally removed mine. you just have to remember what yuo ve done when you engage 5th.
air870 is offline   Reply With Quote
Old 12th June 2007, 10:23   #21
kpzen's Avatar
Default Update...!!
The car was taken to Vivek Automobiles.
The clip was replaced & the gearbox is back to normal now.
Total cost of Repair - Rs 1500
Old 12th June 2007, 11:18   #22
rishibravo's Avatar
What was the breakup...Labour and parts...Did they take the gearbox down
rishibravo is offline   Reply With Quote
Old 23rd December 2007, 21:58   #23
Default similar failure
My 04 indica lsi was fine till last night. today when i took it out, it wasn't slotting in reverse gear.it either remains in neutral when i release the clutch,or gets slotted in 4th.
is it a complete gearbox overhaul or just some minor adjustments to it will do?unlike the palio, the indica doesn't have the manual lock.
bonnetsup is offline   Reply With Quote
Old 23rd December 2007, 22:29   #24
wolfinstein's Avatar
Problem with Gear Syncro, Get it checked and corrected- Can't say about the expense, but it won't be a bomb.
wolfinstein is offline   Reply With Quote
Old 25th December 2007, 12:44   #25
thanks wolf,got it rectified.the part directly below the gear stick had to be replaced,something the mech says has 4 sockets and a needle. Not sure i got that right,was in a hurry.is that the gear syncromesh?
While parking,i slot it into reverse while braking and a fraction of a second before it comes to a halt..it normally results in a thud and a mild jerk.Could that have been the culprit or does it happen?
Old 25th December 2007, 19:31   #26
hrman's Avatar
Thanked: 435 Times
The recommended way to do this is to let the car come to a standstill, wait for 3-4 seconds and then engage it in reverse gear. It works butter smooth then. Never slot it into reverse when the car is in forward motion, it will give you a grinding sound and might be the cause for your problem.
Originally Posted by namit View Post
Hi !!
Palio and Astra have this feature.
I thought many other manufacturers have this too. I had it on my earlier Indica and now on my City as well. You cant engage reverse from fifth gear.
hrman is offline   Reply With Quote
Old 25th December 2007, 20:33   #27
Not good reverse technique though, although cannot say conclusivly about direct harm or damage could have been inter-related.
Old 27th December 2007, 14:41   #28
Thanked: 20 Times
IIRC, the TATA Sumo also has this reverse gear clip
Jeep is offline   Reply With Quote
Broken Gearshift on Chevy Beat. Pin-type Gear lock bykerdawg Technical Stuff 6 10th December 2011 12:23
FIAT Petra 2004 - 5th and reverse gear do not engage rikhav Technical Stuff 41 1st June 2010 15:45
i10 gear stuck in reverse gear drkunaldas Technical Stuff 33 23rd November 2009 02:21
Palio Roof linning clip hariharans Technical Stuff 0 23rd June 2008 17:51
