Old 7th June 2007, 00:53   #1
rOaD AsSaSin!!'s Avatar
Thanked: 18 Times
Default Fiat Palio's Reverse Gear Clip Broken!
Hi guyz!!
my friend own a fiat palio...
his reverse gear clip is broken due to which the reverse gear is not applicable...
can i know what is the role of the clip in the gearbox and approx how much it would take to get it repaired??
rOaD AsSaSin!! is offline   Reply With Quote
Old 7th June 2007, 09:52   #2
rishibravo's Avatar
If just the plastic nob is broken then just the gear nob will be replaced...so it will cost you the complete gear nob + labour. I hope its not the leather padded sports gear nob which comes in sports model as the availability for that is a problem. Ask you friend to pay a visit to vivek Auto (its pretty close to Faridabad)
rishibravo is offline   Reply With Quote
Old 7th June 2007, 10:58   #3
kpzen's Avatar
Thanked: 340 Times
Its not the plastic ring(for reverse) on the lever which is broken...!!! The lever n clip on it are fine
Somewhere the connection of the nob with the gearbox is broken because now while slotting it in reverse it falls into fourth gear...
Its a Palio 1.2 ELX NV 04 model....
Old 7th June 2007, 15:01   #4
rishibravo's Avatar
Go straight to the service station maan....If the gearbox has to be brought down then the labour charges are Rs 1500 bucks
Old 7th June 2007, 22:32   #5
Thanked: 18 Times
thanks for the info but i wanted to know the usage of the reverse gear clip???
is it that much necessary??
Old 7th June 2007, 22:39   #6
wolfinstein's Avatar
Thanked: 12 Times
Rishi just advised, considering the Gear Shift Problem, In any case it appears to be a broken shifter...Get it checked.
wolfinstein is offline   Reply With Quote
Old 7th June 2007, 22:43   #7
kpzen's Avatar
Thanked: 340 Times
How will u slot the reverse gear with a non-functional clip?? n Can u drive the car without a reverse gear???
Old 7th June 2007, 22:47   #8
Thanked: 18 Times
arey i mean why is it provided only in palio then??
dont all the cars have a reverse gear??
Old 7th June 2007, 22:53   #9
Thanked: 12 Times
I think he meant " The Reverse Gear Shifter" is a slight step based shifter, which needs to be pulled up for engaging reverse gear..like the Cielo..!
I remember spending an Hour in the summer heat, 5 years back in my Uncles New Palio, Figuring how to get the car in reverse mode.
Old 7th June 2007, 22:53   #10
kpzen's Avatar
Thanked: 340 Times
There are many cars with such kind of reverse gear mechanism like Astra, Verna , Corsa n some European cars...Japanese cars dont have such clip system...
Old 7th June 2007, 22:57   #11
Thanked: 12 Times
Ya, but it was one of first ever for me, considering the cars I had seen..!
Old 7th June 2007, 22:59   #12
kpzen's Avatar
Thanked: 340 Times
I think the first car in India which had this kind of reverse gear system was Opel Astra...
Old 8th June 2007, 00:23   #13
rishibravo's Avatar
you have to get the car to the service station in any case. I would suggest not to continue driving without a reverse gear.
Old 8th June 2007, 00:29   #14
kpzen's Avatar
Thanked: 340 Times
No its been parked in the garage for the last two days....
Old 8th June 2007, 00:37   #15
namit's Avatar
Thanked: 20 Times
Hi !!
Many European cars have this safety mechanism so as to avoid any chances of a person engaging a reverse gear accidently when he wanted to move to the 4th gear instead.
Palio and Astra have this feature.
Hope that explains and you may now ask your friend to contact Vivek Auto for corresponding repairs.
namit is offline   Reply With Quote
Shifting Gear gets harder - Fiat Palio MJD 1.3 Black_Beast Technical Stuff 10 9th December 2010 23:47
FIAT Petra 2004 - 5th and reverse gear do not engage rikhav Technical Stuff 41 1st June 2010 15:45
i10 gear stuck in reverse gear drkunaldas Technical Stuff 33 23rd November 2009 01:21
Palio Roof linning clip hariharans Technical Stuff 0 23rd June 2008 17:51
