Old 10th June 2007, 15:53   #1
wolfinstein's Avatar
Default DOT 3 vs DOT 4- Indica Brake Oil Change
Hi,I'm planning to change the Brake-Clutch fluid in my Lancer- It specifies a DOT-4 Oil.
Now in My XETA- The Oil level over the Year has gone down to Half, and I guess it Castrol Red Colour Oil which the manual specifies as DOT3.
Can I change it to DOT 4 Mobil 1 Brake Oil same as the Lancer, Also I did not notice the Clutch Fluid Container in the XETA, Does it not need replacement of fluid.
I'm planning a road trip, so wanted the car to be in great shape, I will get getting the Balancing and Alignment done sometime soon for the Vibration > 100 Kmph problem.Thanks
wolfinstein is offline   Reply With Quote
Old 10th June 2007, 16:07   #2
kpzen's Avatar
Thanked: 1,599 Times
There are three grades of Brake oils DOT-3 , DOT-4, DOT-5..
DOT -4 has the following advantages over DOT-3
1. Higher boiling temperature
2. Higher resistance to water absorption
DOT - Department of Transportation
If there's no clutch fluid container container in XETA it means it has a mechanical clutch whereas the Lancer has a Hydraulic one.
Brake system is a critical part of the car in terms of safety so its better to stick with what the manufacturer recommend's. Please don't try anything before going for a road trip
kpzen is online now   Reply With Quote
Old 10th June 2007, 16:12   #3
So, I should put DOT 3 in the XETA and DOT 4 in the Lancer.
Do I need to flush the Old Fluid, or I leave a cloth to absorb the oil and then pour the new one. ( At least I have seen the Service Mech's do this) rather than bleed and Flush the System each time.
Old 10th June 2007, 16:16   #4
rishibravo's Avatar
wolf I dont think Indica has a hydraullic clutch hence no need for the hydraullic fluid (clutch oil). Mixing of brake oil is not recommended so dont try topping up a DOT3 with DOT4. Its your brakes you are talking about so dont take a risk...cross the road(literally ) and talk to the vivek guys about it if you have further doubts
a cloth cant guarantee the oil being completely fluched . There is always some oil in the hoses.
rishibravo is offline   Reply With Quote
Old 10th June 2007, 16:19   #5
kpzen's Avatar
Yes u'll have to flush the old fluid before to get the max out of the new brake oil.
Is it a DIY ??
Old 10th June 2007, 16:20   #6
I understand that bit, So I mean If I buy Brake Oil for both the car's seprately, How do I replace it, Or should I change it in the lancer and in the XETA wait till some more time, Currently its at Half way mark, I din't see no leaks and Braking is fine.
Old 10th June 2007, 16:34   #7
rishibravo's Avatar
It doenst need to be replaced. Just keep topping up. Isnt it getting topped up in every service. If the braking is fine and there are no leaks then you dont have to worry about it unless and until the brake oil level is below the min level..
Old 10th June 2007, 16:37   #8
Nah! They said level is fine enough.
Old 10th June 2007, 18:00   #9
rishibravo's Avatar
In that case you dont have to worry about anything
Old 10th June 2007, 18:04   #10
I would sugegst, do not change DOT3 to DOT4 , you may get premature wear of seals and rubber compnents if you put DOT4 where DOT3 is specified and vice-versa, stick to manufact specifcations.
Kinetik is offline   Reply With Quote
Anyone using DOT 5.1 brake fluid?? Shan2nu Technical Stuff 27 3rd May 2016 18:44
Brake Oil Change amtak Motorbikes 24 17th August 2010 17:17
Availability of DOT 4 brake fluid in Pune? Raccoon Motorbikes 18 18th December 2009 17:09
Disk Brake to normal brake change? ramki067 Motorbikes 10 7th August 2008 14:19
