Old 10th June 2007, 16:02   #1
Default Skoda Oct. 1.9 Tdi: Vibrates during takeoff and in the reverse gear
Dear All, I am new to the forum and also, this is my first post. I am amazed to see the enthausiam over here. Its full of energy.
I have a Skoda Oct. 1.9 Tdi Classic. Somebody recently noticed my tires vibrating during Takeoff and while reversing the car. This only happens at very slow speeds.
Is it normal?
Anand
Mods note: Do not use font tag/colour tag for post.
abhargava75 is offline   Reply With Quote
Old 10th June 2007, 16:34   #2
Hello. Welcome to Team-BHP. Do introduce yourself in the Introductions section. From your explanation, it is not normal. My uncle's octavia 1.9 tdi has done close to 60k km and there is no vibration during reverse and forward slow speeds. I think your bearings are weak? I'm not sure, just a guessing. But vibration of the wheels could mean anything else.
Wait till the others drop in their opinions..
A
Absar is offline   Reply With Quote
Old 10th June 2007, 17:02   #3
Thanked: 245 Times
Usually this problem relates to wheel alignment and balancing or a damaged rim/worn out tyres.
Old 10th June 2007, 18:17   #4
rishibravo's Avatar
Whats the odo reading. That should tell a lot
rishibravo is offline   Reply With Quote
Old 10th June 2007, 18:27   #5
Check your CV joints for wear.
Gurkha is offline   Reply With Quote
Old 10th June 2007, 18:52   #6
Vid6639's Avatar
Thanked: 21,086 Times
I shudder to tell you that during takeoff if your car's vibrating it mostly is due to the clutch worn out causing clutch shudder.
This will be pronounced in 1st gear starting off and in reverse as well. The wheels vibrating or rather shaking is because of the same shudder.
How many kms has your done? Could you give us more details?
It wont be due to alignment and balancing as it is at slow speeds. You will feel that at higher speeds if it vibrates at the steering it is due to the balancing.
Old 10th June 2007, 19:22   #7
flipsyde's Avatar
Thanked: 62 Times
used to happen in my friends alto. was later diagnosed to have a worn out clutch. problem was solved after the clutch was replaced.
flipsyde is offline   Reply With Quote
Old 10th June 2007, 19:59   #8
Thank you all for responding so promply. The car is only 6 months old and has run 4500 Kms.
Old 10th June 2007, 20:05   #9
Couple of more inputs:
1) It only happens when the wheel starts rolling
2) It stops as soon as they start rolling
3) I am very particular about clutch usage, there are no other symtoms
Initially I thought, it might be because of the engine vibration coming on to the type, because of low RPMs. It happens more when reversing the car.
Please enlighten.
Anand
Old 10th June 2007, 20:20   #10
Vid6639's Avatar
hmmmm, do you release the clutch too early. try increasing the rpm and rolling. basically slip the clutch a tad.
now that you say it's only 6months and 4500kms it can't possible be the clutch. has to be something else but I guess other skoda owners should be able to help you.
Old 10th June 2007, 21:54   #11
Wow! 4,500 km/6 months and a suspect of faulty clutch? Can't be! Must be some other reason.. Or even if its the clutch, don't worry, warranty is alive..
Wait for some inputs from other Skoda owners like how vid6639 mentioned
A
Old 11th June 2007, 01:32   #12
I had a word with a Mechanic from the Skoda Showroom. He says its normal. Its true for all Skoda Oct. TDi versions. I wonder.
Waiting for the Skoda Oct. owners to comment.
Old 3rd August 2015, 23:19   #13
somebodystopme's Avatar
Thanked: 17 Times
Default Re: Skoda Oct. 1.9 Tdi: Vibrates during takeoff and in the reverse gear
Hi Friends
I am planning on buying a used superb 1.8TSI AT 2012. I have test driven it enough to know it works fine. Today i took it skoda and they refused to do any check up since appointment is only by booking and not available for 12 days.
Anyway I was test driving the car once out of service station while taking a U turn it shuddered a little when picking it up from low speed. Now i have real a few threads which state its a sign of clutch problem and for automatics it can be worse. Please guide. If needed i ll take it to okhla workstation where i can actually get an appointment. Quick reply in this case will be much appriciated. Since i need to close the deal in a day or two and have already paid good amount of money.
somebodystopme is offline   Reply With Quote
Old 4th August 2015, 11:54   #14
Ardy's Avatar
Thanked: 86 Times
Originally Posted by somebodystopme View Post
Hi Friends
Was the shudder while turning and in the steering? Driveshaft could be the culprit it there's no shudder in straight line.
Cheers,
Ardhendu
Ardy is offline   Reply With Quote
Old 4th August 2015, 12:01   #15
Thanked: 11,110 Times
IT is the dual mass flywheel giving up. Means replacing the clutch. Will cost you arouns Rs 35000
i10 gear stuck in reverse gear drkunaldas Technical Stuff 33 23rd November 2009 02:21
We are Rockin GOA !!! 02 Oct 09 - 05 Oct 2009 swiftnfurious Travelogues 14 19th November 2009 16:28
I will be in Jaipur EDIT: 11th Oct to 22nd Oct 2009.. Like to meet TBHPians there. dushmish The Team-BHP Meet Section 8 8th October 2009 10:49
Bangalore Vahan Yatra 2005 from 7th Oct to 16th Oct protege Shifting gears 10 21st September 2005 02:00
