Thread Tools
Old 20th June 2007, 16:03   #16 (permalink)
risga's Avatar
Originally Posted by eflanker View Post
Open radiator cap, start engine.
Leave engine on for 10-15 min
You must get rid of air bubbles
bubbles = damage
This process will automatically happen due to the pressure release system in the radiator cap. No need to open the radiator cap.
risga is offline   Reply With Quote
Old 21st June 2007, 01:29   #17 (permalink)
ankitahuja's Avatar
Lot of sad/bad things happened recently so got no time go to a garage.
What I notice now is that since the weather is cooler now, the condition is better but there is still something wrong somewhere. I might have gotten used to the heavy revving somewhere but the FE has gone down.
It used to do 150kms in 500 bucks but now its no more than 120kms MAX.
Will go and show her this saturday and know what the hell went wrong!
__________________
åĐïğŧėđ Tŏ Ÿoů...
I got BULLed!
ankitahuja is online now   Reply With Quote
Old 5th August 2007, 19:26   #18 (permalink)
ankitahuja's Avatar
Thumbs up
Sorry guys, posting after a long time. Was too busy sorting out life!
Drove to Jaipur last week, my OHC returned 12.5kmpl with 100% AC and out of the 650kms I drove, about 20% was city driving. I've got much better FE in the city! Could reach a 100-110 kmph easily but she was grunting after that so decided it is time to set things right!
I went to Pandit & Co yesterday morning. After a TD and discussing the symptoms, we did a compression test. Saw that it had gone down to 150.
CULPRIT: The Abro motor flush was too strong for her and that engine flushing is NOT recommended for older engines especially who have not been flushed regularly.
There was an expensive treatment available and so decided to test on just one cylinder first.
It was a small tube holding 9ml of chemical that was put into cylinder 1 with a squirt or 2 of machine oil. The plug + wire were put back on but the switch wire (which powers the electricals) was taken off. The engine was cranked for 2-3 seconds a few times and then the switch was put back on and the engine was fired and idled for 10-15 minutes, with light revs in the end, exhaust smoking!
RESULT: After this, the plug was removed and the compression was tested in the cylinder. Ok, in the beginning, we were expecting the compression to rise to about 170 (+/- 5) but it went up to a 180, which was unbelievable. (185 is a new engine)
I was asked to drive and see if I saw a difference but it would take time for the treatment to take full effect in any case. I drove around for about 45 minutes and could see a difference for sure (or maybe it was psychological).
Anyway, I went back there and decided to get the remaining 3 cylinders treated as well. Same procedure, but we let her idle for an hour. The best part was, in about 20-30 minutes, the engine sound VANISHED, it sounded dead silent and like a fresh engine that was so full of life.
We didn't do any more compression tests after this but I am in the process of making the best of the treatment right now.
CONCLUSION: Have to drive her under 50-60 and very gently, no red lining and be very gentle, have to do this until 500kms (this will cause regular heat expansion and contraction and seal the internals for compression to remain intact), and return for the final compression test and to get the plugs and injector cleaning done. Was warned that if I don't be gentle then I'd just blow up the $$ spent, out of the exhaust ;-)
Did about 140 kms yesterday with speeds under 60 and low revs (FOOT ACHED!) Managed to get FANTASTIC FE until now, haha, I think she is coming back to life!
__________________
åĐïğŧėđ Tŏ Ÿoů...
I got BULLed!
Old 5th August 2007, 19:44   #19 (permalink)
Jaggu's Avatar
Great that things are getting sorted out, do post the name of the product the garage used.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 5th August 2007, 20:17   #20 (permalink)
iraghava's Avatar
Congratulations Ankit! Glad to know the problem got solved finally. Now, as a lesson I hope you'll stop going to the best tuner in Delhi for your engine flushes
Jaggu - I think the product is called Khaado. Not sure about the speeing though.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
iraghava is online now   Reply With Quote
Old 5th August 2007, 20:19   #21 (permalink)
toiingg's Avatar
Please let us know the price also.
__________________
Sarvagya
toiingg is online now   Reply With Quote
Old 5th August 2007, 20:22   #22 (permalink)
ported_head's Avatar
Google knows not what you speak of. Please tell more.
Ankit, can also please elaborate more of what was used to bump up your compression again? Ideally also take a pic or two of the packaging.
__________________
BE 6.5 You lose some, you lose some.
ported_head is offline   Reply With Quote
Old 5th August 2007, 20:52   #23 (permalink)
ankitahuja's Avatar
@Jaggu - Mentioned the garage in the beginning buddy - Pandit & Co, Okhla.
@iraghava - Ya bud, thanks. It's not called Khaado / Khaadu? And the trips have stopped to the 'best tuner' ever since. I called you that day when I was there but guess you were sleeping or hung over!
@toiing - It was to cost me 2k per cylinder so 8k in total but I got a discount, maybe it was my enterprising nature or possibly being referred by Ishan! (But they don't deal in tyres man!!!)
@ported_head - I've tried explaining everything in detail sir, it was not complicated and as simple as I have written it :-)
The product is called XADO, used by the French to clean rifles, as I was told, its made in Ukraine. Some serious product here.
The pictures:
The small tube
Details on the backside
__________________
åĐïğŧėđ Tŏ Ÿoů...
I got BULLed!
Old 5th August 2007, 20:52   #24 (permalink)
iraghava's Avatar
Not to worry my car runs on the same stuff. Will be going to the garage in a day or two, so if Ankit doesn't have any pics I'll get some alongwith more information.
Well I did call you back later but you didn't take the call! I was sleeping since I'd been reading some stuff till 5:30-6am!!
__________________
Old 5th August 2007, 20:58   #25 (permalink)
wolfinstein's Avatar
So is this a Flush Alternative or Compression Enhancer !!!
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 5th August 2007, 22:18   #26 (permalink)
Jaggu's Avatar
dont go so far as ukraine, india site Xado India | XADO | Engine Treatment | Engine Oil Additives | Reconditioning Technology
__________________
Old 5th August 2007, 22:18   #27 (permalink)
They have some interesting stuff. Might want to try out some of it, someday.
Xado UK - Increase Compression | Performance | Reduce Consumption | Emission | Environmentally Friendly | Fuel Consumption | Reduce Fuel Consumption Technology - Engine Compression
But at 2k a cylinder, he is making quite a cut. Presuming that he used one tube per cylinder, each of which retails at around 9 pounds.
__________________
Old 5th August 2007, 22:43   #28 (permalink)
narayan's Avatar
GUYS !!!
is it recommended to do an engine flush periodically ? my OHC has done 62k and havent done a flush yet...shud i be getting this done ? what precautions be taken to avoid what ankits ohc went thru...
also - OT - is 62k time enuf to chek our the suspension ? ever since i upgraded to 195/55/15 - im seing a terrible drop in ride quality ( is it due to an ageing suspension ??)
narayan is offline   Reply With Quote
Old 6th August 2007, 00:45   #29 (permalink)
ankitahuja's Avatar
It's not a flush alternative. The website gives some interesting information.
Hmm. That's a good margin then!
Originally Posted by narayan View Post
GUYS !!!
I seriously do not recommend flushing on your OHC since I have had such a bad experience. Our older engines are sealed by the carbon deposits which is good and since you have never used a flush before, it's better not to now.
Suspension check is important, will save you unnecessary kharcha if not checked and corrected in time. Could also be due to the alloys specs, someone will enlighten you on that one.
__________________
åĐïğŧėđ Tŏ Ÿoů...
I got BULLed!
Old 6th August 2007, 00:49   #30 (permalink)
ankitahuja's Avatar
Oh hell you did!! Sorry I was watching a movie then and totally forgot about it.
You used this on your OHC, what were the before and after results on the compression?
__________________
åĐïğŧėđ Tŏ Ÿoů...
I got BULLed!
Thread Tools
Engine Flush viper316 Technical Stuff 3 25th January 2008 10:17
Idling problem in my WagonR Lxi..EDIT : Now solved. ramki067 Technical Stuff 8 17th December 2007 10:19
For Sale - OHC Vtec Engine, Gearbox, Ecu, Wiring, Free Flow EDIT: Now Sold viper Shifting gears 7 14th December 2007 11:48
Swift Diesel - excessive engine vibration when Idle. EDIT : Solved by MUL DieselFan Technical Stuff 36 2nd May 2007 11:37
Whats the mystery on bsmotoring.com? EDIT : Now SOLVED on page 3 Sahil The Indian Car Scene!! 40 1st September 2006 16:15
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
