| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #31 (permalink) |
| Team-BHP Moderator ![]() Join Date: Oct 2005 Location: Hyderabad
| Interesting! Bloody damn interesting. Almost sounds like a magic potion for cars... something equivalent to "what's that stuff" in which Obelisk fell. I gotta check this out now. Where do I get this stuff here in Hyderabad? |
| | #32 (permalink) | |
| Senior - BHPian | Quote:
Do you think you can do a repeat compression test after about 1 tankful of gas and let us know the results. Viper
__________________ NO ONE DARES COME CLOSE | |
| | #34 (permalink) |
| BHPian Join Date: Feb 2006 Location: New Delhi
| Depndeds on how well you kept your OHC @ 62,000 I had the lancer flushed for the first time at 50,000 K, Never missed a schedule-STP for the first day did great next day, Clutch seal failed, So I had to get it replaced. But After That I had the Oil replaced last month to Castrol Magnatec from GTX, So flushed it with STP again, keeping fingers crossed..! and guess what Nothing happened, The car runs great, sound great..No leaks !
__________________ " When was the last time, You did something for the first time " |
| | #35 (permalink) | ||
| BHPian | Quote:
You would need to call one of the distributors and find out for Hyderabad. Xado India | XADO | Engine Treatment | Engine Oil Additives | Reconditioning Technology Quote:
Hmmmm.. Danke!
__________________ • åĐïğŧėđ Tŏ Ÿoů... Virtuous sensibility, escape Velocity! | ||
| | #36 (permalink) |
| BHPian | UPDATE: I'm about to complete the required 500kms very soon. The immediate FE I got after the work has increased to almost 14kmpl with 100% AC on in the city as compared to the 12.5 I got on the highway!
| | #37 (permalink) |
| Team-BHP Moderator ![]() Join Date: Feb 2004 Location: Bombay / New York
| Guys, Dont get too excited about this "miracle drug". As the saying goes - If its too good to be true, it probably is. I'm not 100% sure if this Xado stuff is what i'm talking about, but it is what is usually used by a lot of dealers and mechanics just before a severly used car is to be resold on the market. The thing is that the effect is not permanent, and in certain cases it may just suddenly blow through while you are driving, and you'll notice an immediate decrease in performance again. So just keep that in mind. cya R |
| | #38 (permalink) | |
| BHPian | Quote:
thats an amazing FE for the OHC ( 1.5 i guess ) - really unbelivable. !!! but well worth the effort.... | |
| | #39 (permalink) |
| BHPian | @Rehaan: You are right about the stuff suddenly blowing out, that's exactly what I was told and so to drive the car really gently (revs under control and speeds under 50-60) else I WILL blow the stuff out and loose all benifits till it settles down properly. I guess the website also states that, so I'm very hopeful! @narayan: If I can recall properly, the FE I used to get from the 1.5 was super a couple of years ago before the air filter or muffler, guess the driving style makes a big difference now. It's 14kmpl now also cuz of the way I have been driving, but then im sure I have atleast some gains.
| | #40 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: New Delhi
| just a query...sorry for sounding like a newbie. I was reading xado india website, the gel revitalizant for diesel page. I want to use this in my Indica, but have a couple of doubts: 1. It says "Open oil mouth" does it mean the place where the engine oil is poured in? 2. It says bring the car to optimum temperature acc to chart given below. There is no chart. 3. Ankit said that Pandit guy used 1 gel in one cylinder initially. Now whats that? How can I differentiate between cylinders in my Indica? All i Could find is an engine and some openings. May be Petrol and Diesel engine difference? Help Guyz....
__________________ SINGH IS KINNNNNNNG.. |
| | #41 (permalink) | ||||
For diesel, its an Oil additive with a difference. Quote:
| | #42 (permalink) |
| BHPian | Sounds good, but agree with "Rehaan". we will know only after the car has done few thousand kms. But if it really works and is permanent it would be fantastic! Xado India | XADO | Engine Treatment | Engine Oil Additives | Reconditioning Technology Ankit please keep us posted.
__________________ " I'd rather live with the consequences of my actions rather than the regrets of my inactions." |
| | #43 (permalink) | |
| BHPian | Quote:
lets hope ankit keeps the thread alive with the compression tests
__________________ 332kmph 1999 unrestricted GSXR1300R ROYAL ENFIELD MACHISMO 1992 636 RB20DET NISSAN | |
| | #44 (permalink) |
| thanks dadu, but Pandit used the same gel (though petrol variant) in cylinders after opening up the engine when its supposed to be added with Oil? this confuses me.
| | #45 (permalink) |
| Senior - BHPian | Dont get confused, there are many products for different uses by Xado. XADO Gel Revitalizant for Petrol/Diesel Engines Can be Used to Treat : - Low-pitched dead sounds from the bottom of the crankcase, which intensify noticeably with the increase in rotational speed of the crankshaft (wear of the main bearings) - Steady ringing metal sounds, which intensify with increased loading (wear of the crankpin bearings) - Engine overheats - Muffler smoke - Power loss - High fuel consumption - Low pressure and high oil consumption - Intense vibration and noise. XADO Gel Revitalizant for Cylinders (used by pandit) Benefits of the Treatment : - Option to treat selective cylinders - Compression increase in the cylinder - Restoration of the geometry of the cylinder, removal of scuffs - Protection of rubbing parts from wear-out at cold start - Eliminates sticking of piston rings - Decrease in noise and vibration - Increase in engine capacity - Fuel saving - Decrease in CO and CH contents. Also for cylinder treatment, engine does not need to be opened up, the gel can be fed mixed with Engine oil using a syringe by unscrewing the plug out of the cylinder, the gel is fed onto the cylinder wall and not the piston. Last edited by dadu : 20th August 2007 at 16:35. |
| Thread Tools | |
Similar Threads | ||||
| Engine Flush | viper316 | Technical Stuff | 3 | 25th January 2008 10:17 |
| Idling problem in my WagonR Lxi..EDIT : Now solved. | ramki067 | Technical Stuff | 8 | 17th December 2007 10:19 |
| For Sale - OHC Vtec Engine, Gearbox, Ecu, Wiring, Free Flow EDIT: Now Sold | viper | Shifting gears | 7 | 14th December 2007 11:48 |
| Swift Diesel - excessive engine vibration when Idle. EDIT : Solved by MUL | DieselFan | Technical Stuff | 36 | 2nd May 2007 11:37 |
| Whats the mystery on bsmotoring.com? EDIT : Now SOLVED on page 3 | Sahil | The Indian Car Scene!! | 40 | 1st September 2006 16:15 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
