Old 20th August 2007, 16:31   #46
panky12345's Avatar
Thanked: 31 Times
Oh Lord....Thanks so much for explaining Dadu.
Would this gel be as effective as XADO used by pandit?
Old 21st August 2007, 05:02   #47
ankitahuja's Avatar
Thanked: 26 Times
Neat discussions going on here guys.
panky - Dadu explained it well, what Pandit used was XADO Gel Revitalizant for Cylinders which is for the cylinder treatment and not for the engine, so it was not added to the engine.
What I meant by saying that one unit of gel was added to a cylinder initially was that I got only ONE cylinder treated to check it the gel actually made any difference and later got 3 units each added to the remaining 3 cylinders. (I hope it makes sense)
I will definately keep the thread alive and post the updated figures. Will visit them this weekend most probably so will know then.
Old 21st August 2007, 16:22   #48
panky12345's Avatar
Thanked: 31 Times
ankit, can you please check if the deisel engine wali gel is effective enough (as and when you go to pandit again) and whats the MRP. I'd been trying XADO India office #, but couldnt get through.
One number is wrong i.e. 30929236; second # is fax and when I googled, I found an entry on bizearch.com. the contact name was Vishal rastogi and his # 9871388333 is constantly switched off. I'm clueless where to find these products. Checked out with few, they even havent heard the name.
Old 21st August 2007, 17:11   #49
Thanked: 172 Times
Why dont you send a mail to them, might work or worst come worst goto basant lok office personally, might as well watch a movie at PVR, when there.
Old 21st August 2007, 17:15   #50
panky12345's Avatar
Thanked: 31 Times
did that dadu, no reponse. basant lok = too far! I'm at other end of Delhi.
Old 22nd August 2007, 10:02   #51
Thanked: 172 Times
Try this number, I doubt they will have two faxes.
26153669
Old 22nd August 2007, 12:58   #52
panky12345's Avatar
Thanked: 31 Times
26153669
Nobody picks up! thanks anyway dadu.
Old 22nd August 2007, 13:28   #53
Thanked: 172 Times
Try mailing vishal rastogi, same guy, vr@noritaglobal.com, he's the registrar for this website or write to info@xado.com the parent company for the right contact details for delhi, INDIA office.
I believe Norita global is/was only an agent for them, might have changed/moved.
Old 22nd August 2007, 13:37   #54
panky12345's Avatar
Thanked: 31 Times
ahhh....thanks dadu, allwhois didnt come into my mind.
Old 22nd August 2007, 16:07   #55
ankitahuja's Avatar
Thanked: 26 Times
Sure bro, once I go there, I will get all the information.
Better still, Irags can find this out too if he's going before me, so PM him.
Old 22nd August 2007, 16:13   #56
Rahulk76's Avatar
Thanked: 84 Times
Ahhh.. read up the whole thing mentioned on the website of Xado India | XADO | Engine Treatment | Engine Oil Additives | Reconditioning Technology.
It does sound genuine and as per experiences cited by fellow bhpians...
I am thinking of using this in my 2nd hand bike done 80k..I tried searching for it in Pune, but couldnt..If anyone comes across let me know
Rahulk76 is offline   Reply With Quote
Old 22nd August 2007, 16:21   #57
panky12345's Avatar
Thanked: 31 Times
Update : I got an immediate response from vishal rastogi which reads:
Dear Mr. Vohra
We are in the process of moving our offices, and will be unable to serve you at present.
We will get in touch with you as soon as we restart our operations.
Vishal Rastogi
Old 21st May 2009, 01:27   #58
ankitahuja's Avatar
Thanked: 26 Times
Bumping up this thread after nearly 2 years.
The car has done over 120k kms now. The compression is still intact. Have got it checked at 2 different occasions and have been given a thumbs up!
So this miracle / wonder drug really does work
Old 21st May 2009, 12:36   #59
Thanked: 40 Times
^^ Ankit, Good of you to come back and update this thread ( that too after 2 years).
And it is good to hear that the compression is still holding out. So the treatment is working.
You still haven't posted the compression figures that you had post the 500kms run-in.
HappyWheels is online now   Reply With Quote
Old 21st May 2009, 14:57   #60
ankitahuja's Avatar
Thanked: 26 Times
Thanks HW.
Yes, I will post figures soon after I see them with my own eyes. It was tested and confirmed OK at the workshop.
OHC Suspension Problem EDIT : Solved! KSM-Vtec Technical Stuff 97 21st February 2012 11:42
Engine Flush.. Royal Enfield panky12345 Motorbikes 14 17th May 2011 18:41
Diesel as an Engine Flush!!?? cnaganathan Technical Stuff 21 28th July 2010 22:06
Engine Flush viper316 Technical Stuff 3 25th January 2008 10:17
Swift Diesel - excessive engine vibration when Idle. EDIT : Solved by MUL DieselFan Technical Stuff 36 2nd May 2007 11:37
