Old 9th December 2012, 22:23   #76
Thanked: 31 Times
Default Re: OHC trouble after engine flush. EDIT : Now Solved!
Reviving this thread after a few months. The official website of Xado India
http://xado.co.in/. The contact numbers work.
Can anyone confirm if anyone has used the revitalizant on Honda Civic?
Originally Posted by ankitahuja View Post
1. Refer to my response on page 2, (if it might help).
2. Check out the exact instructions on the Xado website.
3. Check out YouTube.com for videos on how it's done.
Vivek5870 is offline   Reply With Quote
Old 9th December 2012, 22:50   #77
infotech58's Avatar
Thanked: 217 Times
If that helps, six months ago, I tried XADO Gel Revitalizant for cylinders (Blister) on a 92+k done Lancer in my family and the results were impressive. After two rounds of application, the engine is as responsive as it was at around 20-22k and the noise levels are down to some extent.
This is the product i used:
http://www.amazon.com/XADO-Chemical-...&keywords=xado
EDIT: Why do you want to try on Civic? It is highly unlikely that a 2008 Civic would have lost enough power to try such treatments.
infotech58 is offline   (1) Thanks Reply With Quote
Old 9th December 2012, 23:24   #78
Thanked: 31 Times
Thanks Infotech58, I dont want to use a treatment to increase power of engine or cylinders. I am planning to use the revitalizant that is mixed with the engine oil. The product description says that it reduces the noise of the engine. I just want to have a dead silent engine of my civic. Currently, it has a very mild noise which I want to cure with this treatment.
[quote=infotech58;EDIT: Why do you want to try on Civic? It is highly unlikely that a 2008 Civic would have lost enough power to try such treatments.[/quote]
Old 10th December 2012, 16:52   #79
ankitahuja's Avatar
Thanked: 46 Times
You may give the Atomic range a try. I have one with me which I will be using once my partial built engine completes 5000 kms.
These products are quite effective I'd say! You can even send out a query to their technical team (E-mail address on the website) and explain your problem/requirement and the team responds in 48 hours.
ankitahuja is offline   (1) Thanks Reply With Quote
The story of my Honda Dio. EDIT: Horrible after sales! audioholic Motorbikes 108 12th March 2018 11:49
To flush or not to flush..that is the question. hell_rider Technical Stuff 58 23rd February 2018 15:46
OHC Suspension Problem EDIT : Solved! KSM-Vtec Technical Stuff 101 13th January 2014 21:08
Linea Diesel: No one is able to solve engine problem EDIT: Now solved ! Travelbug Technical Stuff 35 21st November 2013 23:39
Engine Flush viper316 Technical Stuff 3 25th January 2008 11:17
