| LinkBack | Thread Tools | Search this Thread |
| | #1 |
| BHPian | Guys I recently got my OHC's engine / radiator flushed with injector cleaning and complete servicing done. I notice that the pick up has gone down a lot, the low end seems to be terrible now with the A/C on. Even though its better with the A/C off but then I feel I need to rev a lot more or turn the A/C off to gain drivability at lower speeds. What should I check, the ECU must have reset as the battery terminal was also taken off but I tried some harsh driving and red lining her for the ECU to adapt my driving style, no luck! Is it the heat in Delhi? What effect would a change in compression ratio have (assuming that the flushing opened the natural seals?) HELP! |
| | #2 |
| BANNED Join Date: Aug 2005 Location: Kalyani, West Bengal
| Is your engine overheating? After all the work done as you describe, the car should be floating in the air but as I read, it got worse. Also get your a/c pressure checked, sometimes overfilling can lead to load on engine. |
| | #3 |
| Team-BHP Support ![]() | I'd ask the same thing : Is your engine over-heating? Please go and have your car checked by a competent garage since an engine flush only makes your engine better. |
| | #4 |
| Team-BHP Support ![]() | How old is the engine? I have heard that perfectly working old engines go down the flush after an engine flush, cause being the seals going kaput when hardened junk being dislodged. |
| | #5 |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
Thanked: 1,087 Times
| not scaring you but tsk has a point, get the car checked by a competent mech |
| | #6 |
| BHPian | The engine is not over-heating at all but a bit cooler than before. What's a/c pressure? The a/c was untouched in the process and is the same as before the work was done. @TSK: the engine is of a 98 OHC with 92k + on the odo. Where do I take her and get WHAT checked? Initially the car ran very very smooth and glided after the work, but its just in the past few days that I felt there was something wrong. |
| | #7 |
| BHPian | @ankitahuja - please check the engine oil level, i hope its not overfilled. |
| | #8 | |
| Senior - BHPian Join Date: Feb 2005 Location: cincinnati, jabalpur,chennai
Thanked: 140 Times
| Quote:
Car Repair and Maintenance Guide for New and Used Vehicles - Yahoo! Canada Autos opened thermostat symptoms look similar to ur's. | |
| | #9 |
| do a compression check first, take it from there if there is a huge variation you have a problem. sometimes the flush actually removes the 'good carbon' build up which results in compression leak. so if this test is aok move to a proper diagnosis, hook up the ecu reader and check if all the parameters are right. again check plugs and plug wires. |
| | #10 |
| Newbie Join Date: Jul 2005 Location: Mumbai
| really sad to hear this best way to flush the engine is by using new but cheap oil and running it for a while before flushing any solvents are very risky to use |
| | #11 |
| BHPian | Just read the thread: http://www.team-bhp.com/forum/techni...l-economy.html (Does Weather Affect Fuel Economy) I face a similar problem it seems, its the heat that makes the car moves like a slug and there definately seems to be a drop in some FE, say about 1kmpl. Night is fine (even though its still HOT at night as well) @Hellcat - Engine oil level is fine sir. @vivekiny2k - The engine isn't WAYY cooler at all but marginally cooler, definately a good thing, it does not seem to be a thermostat failure. @Jaggu - I got the spark plugs changed at the time of service, where should I get all this checked in central Delhi? DONT ask me to go to Honda, they suk! EDIT: @trulymad - Buddy, what do you mean??? Last edited by ankitahuja : 11th June 2007 at 21:55. |
| | #12 |
| Engine should run at its operating temp, so if its running cooler, then the sensor would be confused and send wrong ratio mixture leading to poor drivability, do a total engine scan and find out what the trouble is before it gets out of hand. |
| | #13 |
| BHPian Join Date: Jul 2006 Location: BLR
| Open radiator cap, start engine. Leave engine on for 10-15 min You must get rid of air bubbles bubbles = damage |
| | #14 |
| ankit pm one of the delhi guys they should be able to guide you to a good workshop |
| | #15 |
| Senior - BHPian | |
Similar Threads | ||||
| OHC Suspension Problem EDIT : Solved! | KSM-Vtec | Technical Stuff | 99 | 17th June 2013 14:33 |
| Engine Flush.. Royal Enfield | panky12345 | Motorbikes | 14 | 17th May 2011 18:41 |
| Diesel as an Engine Flush!!?? | cnaganathan | Technical Stuff | 21 | 28th July 2010 22:06 |
| Engine Flush | viper316 | Technical Stuff | 3 | 25th January 2008 10:17 |
| Swift Diesel - excessive engine vibration when Idle. EDIT : Solved by MUL | DieselFan | Technical Stuff | 36 | 2nd May 2007 11:37 |
