Thread Tools
Old 13th June 2007, 13:07   #1 (permalink)
finneyp's Avatar
Question How to remove minor dents?
On the way home today on my Car, out of the blues, someone chased a Cow to the main road and thud, the cow hit the side of my Car. There are two very minor dents on the front left fender
Is there anyway we can ourself remove such minor dents, instead of taking it to a Workshop and they charging a bomb to repair it?
__________________
Drive Safe, your loved ones need you!!!
My Passion is not driving Cars, but driving a FIAT!
Finney, Bangalore
Palio 1.2 NV - 2004
finneyp is offline   Reply With Quote
Old 13th June 2007, 13:10   #2 (permalink)
manikjeet's Avatar
if you could provide a pic it would be very helpfull in providing you help for a DIY
__________________
MANIK NANDA
manikjeet is offline   Reply With Quote
Old 13th June 2007, 13:56   #3 (permalink)
finneyp's Avatar
Default Pics
Here are the pics, please help!
__________________
Finney, Bangalore
Palio 1.2 NV - 2004
Old 13th June 2007, 13:57   #4 (permalink)
finneyp's Avatar
The dents looker bigger in the pic, but is quite minor actually.
Any ideas to get rid of it?
__________________
Finney, Bangalore
Palio 1.2 NV - 2004
Old 13th June 2007, 13:58   #5 (permalink)
vid6639's Avatar
Is the cow ok or did it get hurt?
__________________
\ / ][ |) `/ [_] "!"
(o.o)
( X )
This is Bunny. Copy Bunny into your signature to help him achieve world domination.
vid6639 is offline   Reply With Quote
Old 13th June 2007, 14:00   #6 (permalink)
Okay, first of all you should be able to reach these spots from the inside.
Next remove the indicator light and the "1.2" logo. Take a small wooden plank like a 1" plyboard palm sized orwhich can go inside and place it from the inside on the center of the dent, hit the plank with a hammer but not very hard but just firmly so that the dent comes out.
Old 13th June 2007, 14:02   #7 (permalink)
yes you can remove your self. at the same spot on both fenders my indica got dented, even spot was same, near blinker.
remove fender, try to force by hand, metal should springback to original shape,as there is n streching or sharp edging visible in picture.other wise use a soft mallet.
take your towing hook, wrap heavily with a soft cloth, carefully ding from back of fender(not too hard), it worked for me. i have got left fender back to original shape. right one i will do sometime when i am free.
__________________
Arun
arunforu1 is offline   Reply With Quote
Old 13th June 2007, 14:04   #8 (permalink)
just found this one on net, dont know if it works.
IndianPad / Remove Car Dent With Airduster
__________________
Arun
Old 13th June 2007, 14:39   #9 (permalink)
finneyp's Avatar
Thanks Arun & Dadu for the tips!
Will try it out.
Vid, Cow is hale n hearty!
But I am sad with those dents on my baby! :(
__________________
Finney, Bangalore
Palio 1.2 NV - 2004
Old 13th June 2007, 14:39   #10 (permalink)
anonymous's Avatar
On a serious note-I think you can also go for "Sookhi Denting". Just find a good denter in your area to do the job but remember, this type of denting will only work well, if the paint of affected area is fine.
anonymous is offline   Reply With Quote
Old 13th June 2007, 14:47   #11 (permalink)
tsk1979's Avatar
Sookhi denting is the solution. The hammer on the inside or use suction and dent comes out. Its a real clean job and costs 200rs.
If you like to spend money go to a authorized service station, they will repaint the fender and make sure it never matches with rest of the car.
__________________
Reclaiming.....!
Old 13th June 2007, 14:59   #12 (permalink)
kpzen's Avatar
Dry Denting is the only solution but u will have to find an expert for this job.
__________________
Prajesh
ECLIPSEd
kpzen is online now   Reply With Quote
Old 13th June 2007, 15:11   #13 (permalink)
rishibravo's Avatar
Go to your friendly neighbour denter/painter and get dry denting done... I had the dent near the indicator not once but twice and got it removed for less than 150 bucks. They will take the rubber lining under the fender and clip out the indicator, apply some rubbing and some mild shots of their hammer and you wont be able to notice it..
__________________
Boyz will remain Boyz.......Only their Toyz change
rishibravo is offline   Reply With Quote
Old 13th June 2007, 16:04   #14 (permalink)
abhi182's Avatar
The neighborhood denter is the best solution....
They have years of expertise on this and have the right set of tools and expertise to do this....
DIY, you'll end up applying too little/too much force without the right tools and would perhaps end up chipping the paint too
abhi182 is offline   Reply With Quote
Old 13th June 2007, 16:22   #15 (permalink)
manikjeet's Avatar
the dents are minor
is the dented area repaired
if its not dent you can do a DIY
i think no need for tools when you open it you can just apply a little force and they will come out
have done it many times on my alto( the fenders and the rear hatch)
the sheet is so thin that if anybody leans over it they get dented
__________________
MANIK NANDA
Thread Tools
Fixing small dents - a secret that garage owners would not like you to know team suzuki Technical Stuff 93 15th August 2008 11:16
How to avoid people making dents on your doors! arunkumar_rec Shifting gears 28 21st December 2007 08:07
Removed dents successfully by DIY arunforu1 Shifting gears 6 24th May 2007 16:50
Fixing dents. Pankaj9 Modifications & Accessories 5 29th August 2004 21:58
Small body dents Rudra Sen Technical Stuff 1 5th June 2004 19:29
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
