Thread Tools
Old 14th June 2007, 10:07   #1 (permalink)
Default Some problems
Hello Friends,
I own a SWIFT VXI for last 1.6 years and running is about 11K till date.I am feeling few problems as below:
1.When the AC is on engine knocks when I shift gears from 2nd to 3rd and from 3rd to 4th.Is it problem related to release of clutch or I need to get vehicle checked?
2.I feel some vibration in clutch padle.
3.Yesterday it was raining and I felt that my vipers are not cleaning the windscreen properly.I mean the windscreen was not getting crsystal cleaned.Infact I noticed somewhat misty from outside.What should I need to check?
Please guide me.
Thanks and Regards,
Rajendra
raja748 is offline   Reply With Quote
Old 14th June 2007, 12:02   #2 (permalink)
CrAzY dRiVeR's Avatar
Has this been there for quite sometime? Sure the petrol you filled was from a reputed bunk?
Check the clutch assembly. Swift is known to have clutch related problems, specially if you drive in the City and has the habit of riding the clutch.
Wiper blades!
__________________
I'm far from perfect. I hope i can improve.
Thats why i'm here!
Old 14th June 2007, 13:07   #3 (permalink)
ad75's Avatar
raja748, try changing the wiper blades,they tend to get brittle leading to inefficient clening of the windshield.
was the AC on when you found mist outside? could be because of the lower temp inside the cabin.
ad75 is offline   Reply With Quote
Old 14th June 2007, 13:46   #4 (permalink)
suren181's Avatar
@Raja: Guess you need to change your source of Petrol, that should help with the engine knocking problem. Regarding your Windscreen, as someone suggested do change your wiper blades and you could try Bosch brand blades they have really helped me. Added to it ensure that your windscreen is spotlessly clean by washing it with shampoo or some other windscreen care solution to remove oil, soot and grime deposits. While wiping of your windscreen it is advisable to use Newspaper when the windscreen is damp/wet to clean it on a regular basis. After changing your blades, do remember to often clean the edge of the blades with a soft damp cloth.
suren181 is offline   Reply With Quote
Old 14th June 2007, 16:09   #5 (permalink)
Hello Friends,
Thank you for your replies.
1.Yes,I have indeed changed my petrol pump and this may be the reason for under performance.But now I have already about 35 ltrs.of fuel in my tank as I have cery recently tankfulled the car.How should I proceed about now?Will it damage my car?and if I go to some good filling station,there will be some amount of petrol in the tank.What should I do?
2.Ok.I'll get clutch assembly checked
3.Regarding wipers,I am trying to find out where can I get BOSCH in Pune.Yesterday,AC was ON and there was no mist inside,but the windscreen was not getting cleaned properly from outside.I forgot to tell you that I have added a pouch of screen cleaner (MGA product).
Please let me know any more suggestions if you guys have.
Old 14th June 2007, 19:37   #6 (permalink)
Jaggu's Avatar
if you can, drain the old fuel but this being an expensive proposition, top the tank with good fuel once you reach 3/4 tank.
unless and until the petrol is absolutely adulterated your car should survive for now, if you are really caring go drain the fuel and put new gas in.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 15th June 2007, 10:29   #7 (permalink)
Default One more thing
I forgot to add one more problem.Many times there is some burning smell in the car.I am not habitual of riding clutch and use it for changing gears only and then I take off my foot.Last time I had it checked at MUL dealer's workshop,but they informed me that everything is fine.
Please suggest me.
Thread Tools
IKONic problems danlalan Technical Stuff 76 28th September 2008 11:03
Ebay problems Revvhead Shifting gears 3 12th March 2008 23:35
Three problems with my vtec sunith Technical Stuff 24 10th October 2006 13:35
Tyre problems GeekSrik Technical Stuff 0 19th September 2006 17:23
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
