Old 13th February 2009, 02:53   #211
Smile
Thanks Happy Wheels.... I 've clocked 16452 kms and my third free service was done at 9215 kms .... So, i'm nearing for my fourth service. I was expecting it to be somewhere around Rs2500. But 4500 makes me think again and again whether to get it done from MASS or get it done from somehwere outside... Is it nessary to change the spark plugs, Barke Oil, Gear Oil, Coolant this time around coz I have checked all levels for Brake, Gear oil and coolant. They are all topped up.
I also have an M800 which has clocked arnd 1,14000kms on one change of spark plugs and still doing very strong.
911turbo is offline   Reply With Quote
Old 13th February 2009, 06:29   #212
Thanked: 128 Times
Spark plugs change???!!!
I do not think this is required. And for the oil change, nope, just a top up! For 15k kms service, 4500Rs is definitely on the HIGH side!
Even then I woudl suggest to go to a MASS; just because your's is a relatively new car and still will be under warranty. Do check with some other service centers for the pricing for the 4th service.
Unless these guys are cooking things themselves, all MASS should be having the same rates.
And do check the owner booklet. That is the bible and will tell you what needs to be changed, top-uped or tightened at what service.
BR.
HappyWheels is offline   Reply With Quote
Old 13th February 2009, 08:04   #213
akroy's Avatar
Thanked: 29 Times
911turbo, I do service every 5K km and oil changes, spark plug changes as mentioned in manual.
Suggest you to go through my LTO where I have mentioned all services information in detail along with the FE chart till date.
http://www.team-bhp.com/forum/long-t...dated-35k.html
Abhi
akroy is offline   Reply With Quote
Old 13th February 2009, 09:52   #214
14000rpm's Avatar
Thanked: 584 Times
Originally Posted by gpa View Post
Hi there,
  1. Drive with a light foot and anticipate traffic ahead so that you don't accelerate (burn fuel) and brake (waste enegry generated by acceleration) to slow down.
  2. Shift into the right gear at the right time. Since my Alto does not have a tacho, I use the following speeds to shift gears - 1 to 2 at 15kmph, 2 to 3 at 25 kmph, 3 to 4 at 35 kmph and 4 to 5 at 45 kmph.
  3. When going up an incline, don't crawl up in 4th or 5th gear lugging the engine, what you are doing is increasing the load on the engine and ruining the internal working parts of your car's cylinders. Shift down to 3rd to optimally use all fuel fed into the engine.
  4. In the city, try and keep a steady speed of 55-60 kmph. On highways, keep a steady speed of 80-90 kmph.
  5. Change your engine oil at correct intervals and above all, keep your air filter clean. I use a vacuum cleaner to blow out dust and small leaves that are stuck in the filter every fortnight.
Try these few tips and you will see a definite rise in the overall mileage of your Alto.
Cheers,
gpa
i'm trying all the above...don't think any improvement is visible.Maybe it'll improve after the 10K service.
14000rpm is offline   Reply With Quote
Old 13th February 2009, 11:19   #215
ASHISHPALLOD's Avatar
Thanked: 285 Times
Your alto's fourth service will due at 20000km run.
according to manual, it is major servicing.
all oil change, coolant change, spark plug change, filter change, alignment and balancing is necessary.
1] engine oil change-@rs 600
2] coolant change-@ rs 400
3] spark plug change-@rs 300
4] oil filter change-@rs 150
5] gear oil change-@rs ??[max 500]
6] alignment and balancing-@ rs500.
7] labour--@rs 350.
8] others if any--@rs 200.
your bill will max rs 3000.
go for full servicing. it will be beneficial for your car health.
ASHISHPALLOD is offline   Reply With Quote
Old 13th February 2009, 17:46   #216
Thanked: 416 Times
I had my 4th service (paid one) at MASS (in Noida) and the bill came around 4500. So I guess that is what you can expect to shell out this time I was also surprised as it seems on the higher side.
joslicx is offline   Reply With Quote
Old 13th February 2009, 17:59   #217
Eddy's Avatar
Thanked: 4,674 Times
Ashish: The service cost would be around 700 bucs instead of the labor cost. Plus brake oil. Plus some additives that they might use.
Eddy is online now   Reply With Quote
Old 14th February 2009, 02:11   #218
Thanked: 658 Times
correction
1] engine oil change-@rs 430/- Shell MGO
2] coolant change-@ rs 230 Golden Crusiser MGO, plus Rs.20 for 2 liter distilled water.
3] spark plug change-@rs 270
4] oil filter change-@rs 90
5] gear oil change-@rs 230 for 2 liter, but you won't need now.
6] alignment and balancing-@ rs120 for alignment 4xRs.50 plus cost of weight for balancing.
7] labour--@---. free I guess
Now do the math.
Old 27th May 2009, 20:48   #219
gpa
gpa's Avatar
Thanked: 273 Times
Has there been any improvement post the 10K service?? I noticed a big change in the FE of my Alto post the 10K service.
Do keep us updated.
Cheers,
gpa
Old 28th May 2009, 10:47   #220
14000rpm's Avatar
Thanked: 584 Times
Do keep us updated.
Cheers,
gpa
oh yes. there has definitely been a tremendous diference after 10k service. i sued to get only 15-15.5 before service but as soon as the odo showed 10k, even b4 service, i got 18kpl..this eventually went upto 19.5 once but i never got that FE again.now it averages b/w 18-18.5 without ac and 17.5 with ac.
Old 28th May 2009, 11:27   #221
gpa
gpa's Avatar
Thanked: 273 Times
That is good news. I also average about between 18.5 kmpl to 19 kmpl in the city with very minimal use of the AC.
I want to test the car to see what is thw worst figure I can get in the city by having the AC on 100%. I reckon it should be between 16.5 to 17 kmpl.
Old 28th May 2009, 11:29   #222
Ramsagar's Avatar
Thanked: 38 Times
Is it in the city or highway?
Ramsagar is offline   Reply With Quote
Old 28th May 2009, 12:05   #223
mithun's Avatar
Thanked: 49 Times
How old is your car ? Are you getting this FE in Bangy traffic ?
Old 28th May 2009, 13:38   #224
gpa
gpa's Avatar
Thanked: 273 Times
Hi mithun,
Yes, I am getting this FE in Bangalore. My car is just a year old and just covered 15,300 kms on the odo.
I drive with minimal use of the AC and usually drive on smooth roads with minimal traffic as I leave before the peak hours both in the morning and evenings.
If you wanted detailed info on the FE of my car you can take a look at this thread where I have a detailed LTO review - http://www.team-bhp.com/forum/long-t...10000-kms.html
Cheers,
gpa
Old 29th May 2009, 19:19   #225
14000rpm's Avatar
Thanked: 584 Times
you are right.It should be between 16.5 to 17
the figures i quoted are for city drive only. on the highway i've been driving flat out so i couldn't expect more.
my car is 10 month old and it is always driven in bangalore traffic.
A/C and fuel economy & How to use aircon optimally. Lukeskywalker Technical Stuff 115 15th June 2014 12:09
Does Weather Affect Fuel Economy wolfinstein Technical Stuff 34 20th August 2009 00:57
A New type of engine -> NEVIS Engine, 2x Fuel Economy, 2 Stroke 2 Cyl 1000 cc 250hp 1Day Technical Stuff 16 2nd January 2009 18:24
Electronic ways of IMPROVING fuel economy Godfather Technical Stuff 8 1st October 2006 08:50
Tyre pressure vs fuel economy sbasak Technical Stuff 15 27th February 2006 23:31
